On Jul 27, 8:12*pm, Adam wrote:
On Jul 26, 1:46*pm, " wrote: just revisited this software in its current version 5.2 Have to say this software has really matured and I was most impressed with it whilst flying with it yesterday. I particularly liked the custom terrain and waypoint downloading when setting it up. Check outhttp://xcsoar.org Cheers Al I've been using it for 2 years now and like it a lot. However, with my latest install (5.2.2?) in a newer pocket PC, I cannot get the wind alorithm to work (ie, perform the calculation and show me the vector based on circling drift, it always read "0"). Ideas on that?? /Adam Page 5 "Glide Computer" ... is you're 'Auto wind' set to "Both"? The options a Manual Circling ZigZag Both Cheers |
On Jul 27, 9:47*pm, Uncle Fuzzy wrote:
On Jul 27, 8:12*pm, Adam wrote: On Jul 26, 1:46*pm, " wrote: just revisited this software in its current version 5.2 Have to say this software has really matured and I was most impressed with it whilst flying with it yesterday. I particularly liked the custom terrain and waypoint downloading when setting it up. Check outhttp://xcsoar.org Cheers Al I've been using it for 2 years now and like it a lot. However, with my latest install (5.2.2?) in a newer pocket PC, I cannot get the wind alorithm to work (ie, perform the calculation and show me the vector based on circling drift, it always read "0"). Ideas on that?? /Adam Page 5 "Glide Computer" ... is you're 'Auto wind' set to "Both"? *The options a Manual Circling ZigZag Both Cheers- Hide quoted text - - Show quoted text - For you guys looking for a cable solution for the PNA's..........Make one out of a simle car cell phone charger. It steps 12V down to 5V for most cell phones. For club ships we have a small gel cell comitted to the PNA that get's moved between gliders. XCSoar Rocks! I've had it on Ipaq's, a MIO Moov (that got stolen), and now a teletype 7060 with a 7" screen. I am convinced however that the HP310 is the way to go, and it's great help to have the PNA on a ground retrieve too. We're all looking forward to the OLC problem getting worked out!! |
one out of a simle car cell phone charger. *It steps 12V down to 5V for most cell phones. For club ships we have a small gel cell comitted to the PNA that get's moved between gliders. Ipaq 31x chargers output 3.3vdc on pins 2 and 3 in addition to 5v and neg on pins 1 and 5. Failure to feed it that will allow it to continue draining internal power while in use. USB pins are limited to 500mA and the 310 eats 700-800mA on full brightness so a standard single pin 5v arrangement is not adequate. The extra voltage kicks it into 'fast charge mode' and allows it to drink external power while preserving it's internal battery... Having a loose gelcell sounds like a potential missile or control jamming hazard (assuming the club ships do not have a proper battery box to mount it in...). There are slick/small/cheap and readily available 5-5.5vdc lithium-ion backup batteries around that even come with their own chargers and work quite well (get one that can discharge at 700mA or better for a 31x...) for this purpose. Commonly the 3500mAh model is used for this, which is smaller than a deck of cards but provides some 5 hours of power for a 31x on full brightness. I have a 7200mAh (almost exactly the size of a card deck) unit for using it outside my own ship which is equipped with a 12Ah 12v SLA batt to a 5v converter. All the 31x external battery solutions still require a cord with pins 2 and 3 jumped to the 5v pin, either bridged with the appropriate resistors (my preference) or resistor network, or even just straight bridged so they all have 5v (others have told me this is OK for power, but not communicating data). The stock car charger/cig lighter cord for the 31x already has this built in of course, should one want to use 12v batteries and keep life simple (which goes completely against being a glider pilot ![]() for portability as the 5v options using a modded cord... -Paul |
To charge my 310, I carefully sawed the end off the car charger, then
soldered on two wires, strain reliefed them with a zip tie and hooked them to the 12V ships power. The 310 "on" button glows orange for a few minutes while charging off ships power, then turns green when the internal battery is charged and the unit starts running off ships power. I was taking it out of the ship and hooking it to the AC charger after flying, but found that things worked better if I just left it in the ship. I run the 310, a radio and a transponder off (2) 7AH lead acid batteries tied in parallel and generally fly for 5 - 6 hours. So far everything is performing great. XCSoar is wonderful on the 310. BTW, we have 2 ClearNav's at my club now. It is the brightest display that I have ever seen. Standing behind the wing before takoff in bright sunlight, it was clearly readable. Wow! Brian Ipaq 31x chargers output 3.3vdc on pins 2 and 3 in addition to 5v and neg on pins 1 and 5. Failure to feed it that will allow it to continue draining internal power while in use. USB pins are limited to 500mA and the 310 eats 700-800mA on full brightness so a standard single pin 5v arrangement is not adequate. The extra voltage kicks it into 'fast charge mode' and allows it to drink external power while preserving it's internal battery... Having a loose gelcell sounds like a potential missile or control jamming hazard (assuming the club ships do not have a proper battery box to mount it in...). There are slick/small/cheap and readily available 5-5.5vdc lithium-ion backup batteries around that even come with their own chargers and work quite well (get one that can discharge at 700mA or better for a 31x...) for this purpose. Commonly the 3500mAh model is used for this, which is smaller than a deck of cards but provides some 5 hours of power for a 31x on full brightness. I have a 7200mAh (almost exactly the size of a card deck) unit for using it outside my own ship which is equipped with a 12Ah 12v SLA batt to a 5v converter. All the 31x external battery solutions still require a cord with pins 2 and 3 jumped to the 5v pin, either bridged with the appropriate resistors (my preference) or resistor network, or even just straight bridged so they all have 5v (others have told me this is OK for power, but not communicating data). The stock car charger/cig lighter cord for the 31x already has this built in of course, should one want to use 12v batteries and keep life simple (which goes completely against being a glider pilot ![]() for portability as the 5v options using a modded cord... -Paul |
On Jul 28, 7:30*am, Brian Bange wrote:
To charge my 310, I carefully sawed the end off the car charger, then soldered on two wires, strain reliefed them with a zip tie and hooked them to the 12V ships power. The 310 "on" button glows orange for a few minutes while charging off ships power, then turns green when the internal battery is charged and the unit starts running off ships power. I was taking it out of the ship and hooking it to the AC charger after flying, but found that things worked better if I just left it in the ship. I run the 310, a radio and a transponder off (2) 7AH lead acid batteries tied in parallel and generally fly for 5 - 6 hours. So far everything is performing great. XCSoar is wonderful on the 310. BTW, we have 2 ClearNav's at my club now. It is the brightest display that I have ever seen. Standing behind the wing before takoff in bright sunlight, it was clearly readable. Wow! Brian Ipaq 31x chargers output 3.3vdc on pins 2 and 3 in addition to 5v and neg on pins 1 and 5. Failure to feed it that will allow it to continue draining internal power while in use. *USB pins are limited to 500mA and the 310 eats 700-800mA on full brightness so a standard single pin 5v arrangement is not adequate. The extra voltage kicks it into 'fast charge mode' and allows it to drink external power while preserving it's internal battery... Having a loose gelcell sounds like a potential missile or control jamming hazard (assuming the club ships do not have a proper battery box to mount it in...). There are slick/small/cheap and readily available 5-5.5vdc lithium-ion backup batteries around that even come with their own chargers and work quite well (get one that can discharge at 700mA or better for a 31x...) for this purpose. Commonly the 3500mAh model is used for this, which is smaller than a deck of cards but provides some 5 hours of power for a 31x on full brightness. I have a 7200mAh (almost exactly the size of a card deck) unit for using it outside my own ship which is equipped with a 12Ah 12v SLA batt to a 5v converter. All the 31x external battery solutions still require a cord with pins 2 and 3 jumped to the 5v pin, either bridged with the appropriate resistors (my preference) or resistor network, or even just straight bridged so they all have 5v (others have told me this is OK for power, but not communicating data). The stock car charger/cig lighter cord for the 31x already has this built in of course, should one want to use 12v batteries and keep life simple (which goes completely against being a glider pilot ![]() for portability as the 5v options using a modded cord... -Paul- Hide quoted text - - Show quoted text - Oddly (normal for me) I decided that with all the things I own that will plug into a cigarette lighter, it made sense to me to mount a cigarette lighter socket in my glider. |
will plug into a cigarette lighter, it made sense to me to mount a cigarette lighter socket in my glider. I tried that first, but found that the cigarette lighter socket that I bought was not secure enough to trust in turbulence. I also didn't want the USB wire bundled up and hanging off the instrument panel. So now things are hard wired, bundled and behind the panel with only a few inches of USB cable hanging out to plug the 310 into. Brian |
On Jul 28, 10:30*am, Brian Bange wrote:
Oddly (normal for me) I decided that with all the things I own that will plug into a cigarette lighter, it made sense to me to mount a cigarette lighter socket in my glider. I tried that first, but found that the cigarette lighter socket that I bought was not secure enough to trust in turbulence. I also didn't want the USB wire bundled up and hanging off the instrument panel. So now things are hard wired, bundled and behind the panel with only a few inches of USB cable hanging out to plug the 310 into. Brian the latest release of XC Soar is out, as of today. I've loaded it on to my iPAQ 310 and am giving it a go. Won't be able to fly with it for a bit, but in the sim mode on the couch it looks pretty cool! available he www.bware.it/xcsoar Brad |
Hi,
I sell a very popular cable for connecting a Socket Mobile Power Pack to an iPAQ 310. You can see details he http://www.cumulus-soaring.com/godda...mini-USB-Pwr-1 I also sell one for use with the Goddard PS-5a 12V to 5V power converter. It has also been quite popular. http://www.cumulus-soaring.com/goddard.htm#I310-PS5a-1 Best Regards, Paul Remde Cumulus Soaring, Inc. "Bryce" wrote in message ... On Jul 27, 9:47 pm, Uncle Fuzzy wrote: On Jul 27, 8:12 pm, Adam wrote: On Jul 26, 1:46 pm, " wrote: just revisited this software in its current version 5.2 Have to say this software has really matured and I was most impressed with it whilst flying with it yesterday. I particularly liked the custom terrain and waypoint downloading when setting it up. Check outhttp://xcsoar.org Cheers Al I've been using it for 2 years now and like it a lot. However, with my latest install (5.2.2?) in a newer pocket PC, I cannot get the wind alorithm to work (ie, perform the calculation and show me the vector based on circling drift, it always read "0"). Ideas on that?? /Adam Page 5 "Glide Computer" ... is you're 'Auto wind' set to "Both"? The options a Manual Circling ZigZag Both Cheers- Hide quoted text - - Show quoted text - For you guys looking for a cable solution for the PNA's..........Make one out of a simle car cell phone charger. It steps 12V down to 5V for most cell phones. For club ships we have a small gel cell comitted to the PNA that get's moved between gliders. XCSoar Rocks! I've had it on Ipaq's, a MIO Moov (that got stolen), and now a teletype 7060 with a 7" screen. I am convinced however that the HP310 is the way to go, and it's great help to have the PNA on a ground retrieve too. We're all looking forward to the OLC problem getting worked out!! |
HP310 and XCSoar | Jim White[_3_] | Soaring | 2 | January 14th 09 06:15 PM |
XCSOAR | Travis Beach[_2_] | Soaring | 3 | May 24th 08 03:36 PM |
XCSoar vs SoarPilot? | Frank | Soaring | 0 | December 16th 06 08:07 PM |
XCSoar | jorgie | Soaring | 2 | November 2nd 04 12:05 AM |
XCSoar | Robert Danewid | Soaring | 2 | February 7th 04 01:30 PM |
