![]() "Mike Ash" wrote in message ... In article , Stealth Pilot wrote: if you were forced to use a gps unit for speed you could correct the apparent value using the metrological forecast winds for the altitude. it is a simple speed triangle calculation that could be done on a circular sliderule like the jeppeson cr5. The GPS unit could also derive the actual winds if you can fly a couple of different headings at the same speed, or make a circle. Glider-oriented GPS units typically do this automatically since it's so useful to have and we tend to fly in circles all the time anyway. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon I did not think that "glider oriented GPS units" computed the wind. It's the software that correlates a reasonably constant diameter circle to compute a center point of the circle and then correlates the movement (drift) of the center point over the ground to compute a "best guess wind" from the drifting. Poor pilot thermaling techniques will result in poor wind estimates from the software. ?? BT |
"BT" wrote: "Mike Ash" wrote in message ... In article , Stealth Pilot wrote: if you were forced to use a gps unit for speed you could correct the apparent value using the metrological forecast winds for the altitude. it is a simple speed triangle calculation that could be done on a circular sliderule like the jeppeson cr5. The GPS unit could also derive the actual winds if you can fly a couple of different headings at the same speed, or make a circle. Glider-oriented GPS units typically do this automatically since it's so useful to have and we tend to fly in circles all the time anyway. I did not think that "glider oriented GPS units" computed the wind. It's the software that correlates a reasonably constant diameter circle to compute a center point of the circle and then correlates the movement (drift) of the center point over the ground to compute a "best guess wind" from the drifting. Poor pilot thermaling techniques will result in poor wind estimates from the software. I believe there are a couple of techniques depending on the data available. A pure GPS unit is going to be stuck doing what you describe. A unit which also has access to pitot/static data will be able to compute airspeed as well as groundspeed and direction, and will be able to derive wind from a couple of straight legs flown at different angles. I believe both techniques can be found in practice, but I'm not familiar enough with actual devices to say what does what. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Extra slow flight - Ground speed that is! - Video | [email protected] | Piloting | 9 | March 1st 09 09:04 PM |
Extra slow flight - Ground speed that is! - Video | A Lieberma[_2_] | Owning | 0 | February 27th 09 10:42 PM |
Extra slow flight - Ground speed that is! - Video | [email protected] | Instrument Flight Rules | 0 | February 27th 09 10:41 PM |
Ground speed control | Roger Long | Piloting | 2 | July 7th 04 10:13 PM |
Ground speed control with leaning | Roger Long | Piloting | 11 | June 8th 04 09:22 PM |
