GPS and ground speed
Old July 29th 09, 04:11 AM posted to rec.aviation.piloting
Mike Ash
Default GPS and ground speed
"BT" wrote:
"Mike Ash" wrote in message
Stealth Pilot wrote:
if you were forced to use a gps unit for speed you could correct the
apparent value using the metrological forecast winds for the altitude.
it is a simple speed triangle calculation that could be done on a
circular sliderule like the jeppeson cr5.
The GPS unit could also derive the actual winds if you can fly a couple
of different headings at the same speed, or make a circle.
Glider-oriented GPS units typically do this automatically since it's so
useful to have and we tend to fly in circles all the time anyway.
I did not think that "glider oriented GPS units" computed the wind. It's the
software that correlates a reasonably constant diameter circle to compute a
center point of the circle and then correlates the movement (drift) of the
center point over the ground to compute a "best guess wind" from the
drifting. Poor pilot thermaling techniques will result in poor wind
estimates from the software.
I believe there are a couple of techniques depending on the data
available. A pure GPS unit is going to be stuck doing what you describe.
A unit which also has access to pitot/static data will be able to
compute airspeed as well as groundspeed and direction, and will be able
to derive wind from a couple of straight legs flown at different angles.
I believe both techniques can be found in practice, but I'm not familiar
enough with actual devices to say what does what.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Extra slow flight - Ground speed that is! - Video [email protected] Piloting 9 March 1st 09 09:04 PM
Extra slow flight - Ground speed that is! - Video A Lieberma[_2_] Owning 0 February 27th 09 10:42 PM
Extra slow flight - Ground speed that is! - Video [email protected] Instrument Flight Rules 0 February 27th 09 10:41 PM
Ground speed control Roger Long Piloting 2 July 7th 04 10:13 PM
Ground speed control with leaning Roger Long Piloting 11 June 8th 04 09:22 PM
