xcsoar
Old August 10th 09, 07:07 AM posted to rec.aviation.soaring
Al[_7_]
Default xcsoar
On Aug 9, 5:18*pm, Papa3 wrote:
PS...............I recently bought aniPAQ310and have gotten that to
work as well, only flew with it 1 time as a test and it seemed to work
fine.- Hide quoted text -
- Show quoted text -
Hey all,
So, I picked up a used IPAQ 310 on eBay and am trying to get this
stuff sorted out. * The unit I received shipped with the battery
almost completely depleted and the guy must have misplaced the special
face-plate for the charger/adapter. * So, I'm working off the slower
charge from another mini-USB adapter until I can get the face plate.
This means that I haven't had a chance to really figure out a few of
the basics of loading the software. * So far I have:
- *Downloaded the version of XCSoar for CE 5.0
( XCSoarPPC2003X.ARMV4.5.2.4)
- *Dumped this .CAB file onto an SD card
- *Stuck the SD card into the IPAQ
In the few minutes of working time I got to glance at the 310 user
interface before it powered down, I didn't see any way to get directly
to the CE shell. * *Which begs the question "how do I install on the
310?"
Can anyone give me a preview of what to expect in terms of installing
once I get enough juice into this sucker to be able to work on it for
a while? * The XCSoar Wiki just says to go to the CE File Explorer (or
whatever the equivalent is) and click on the .CAB file. * *Not having
played with CE, not sure what to expect.
TIA
P3
Download this version....
http://www.bware.it/xcsoar/LK8000alfa9.zip
in the Zip package there is a PDF the explains all.
I got mine working but the 310 I got did not ship with a charger so I
am stuck as well with the trickle charge which is no good.
Running the LK8000 version today on an Ipaq 3900 I was impressed with
it for sure.
The 310 I will fly with once I get the Blue Tooth serial and the
charging stuff figured out.
Cheers
Al
Old August 10th 09, 03:38 PM posted to rec.aviation.soaring
Papa3
Default xcsoar
Download this version....http://www.bware.it/xcsoar/LK8000alfa9.zip
Al- Hide quoted text -
Downloaded the recommended zip file, which included several different
executables but no PDF. The Readme file and history files aren't very
helpful in terms of "installation." After poking around a bit now
that the 310 has enough juice to at least let me navigate around the
system:
- Doesn't seem to be any way to access the CE shell directly.
- I copied the PNA executable onto my SD card in the root directory,
but the IPAQ doesn't seem to give me any way to access files on the SD
card (at least not that I could find after reading the skimpy manual
from HP)
I've got to believe there's a way to run the application from the SD
card (i.e. not requiring me to use ActiveSynch to configure and load),
but maybe I'm wrong.
If anyone has access to the instructions for making XCSoar work with a
310, I'd appreciate it.
P3
Old August 10th 09, 03:44 PM posted to rec.aviation.soaring
Brad[_2_]
Default xcsoar
executables but no PDF. *The Readme file and history files aren't very
helpful in terms of "installation." * After poking around a bit now
system:
- *Doesn't seem to be any way to access the CE shell directly.
- *I copied the PNA executable onto my SD card in the root directory,
from HP)
P3
Put all the files from the latest PNA version into the root directory
of the SD card.
Insert the card into the PNA card slot
Reboot the PNA using the stylus, poking it into the restart hole just
below the mini-USB port
the 310 will boot into the shell
then select the SDMMC folder (you'll need glasses to see it!)
browse down to the SIM or the Flight .exe file and select it
that works for me.
Brad
Old August 10th 09, 04:46 PM posted to rec.aviation.soaring
Papa3
Default xcsoar
system:
from HP)
P3
of the SD card.
that works for me.
Brad- Hide quoted text -
Well, I'm making progress...
Managed to figure out how to get to the CE shell just prior to seeing
your post.
However, I'm now less clear on which version is the "PNA Version". I
tried the one from the Italian site referred to by Al above, but after
extracting the files to the SD Card and trying to run the PNA
executable, I get an error message that one of the components is
missing. I tried extracting all files to the root and also
maintaining the original folder names (ie. with XCSoardata) but
neither approach worked.
Old August 10th 09, 05:25 PM posted to rec.aviation.soaring
Brad[_2_]
Default xcsoar
system:
from HP)
P3
of the SD card.
that works for me.
your post.
However, I'm now less clear on which version is the "PNA Version". * I
missing. * I tried extracting all files to the root and also
I am running LK8000alfa9
downloaded from:
www.bware.it/xcsoar
Brad
Old August 10th 09, 08:53 PM posted to rec.aviation.soaring
Papa3
Default xcsoar
system:
from HP)
P3
of the SD card.
that works for me.
your post.
downloaded from:
www.bware.it/xcsoar
Thanks to all who responded on and offline. Turns out I had
downloaded the wrong base version, so I was missing a bunch of DLLs
and other config files. Once that got sorted out, I was off and
running.
P3
Old August 10th 09, 09:14 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default xcsoar
missing. I tried extracting all files to the root and also maintaining
the original folder names (ie. with XCSoardata) but neither approach
worked.
What was the missing component?
Its difficult to diagnose the problem without that information.
You probably need to know that GRecordDll.dll is normally missing from
PNA alpha and beta releases. IIRC its absence is silently ignored: XCSoar
runs without it but won't create IGC log files. You can get it by
downloading the latest stable version (5.2.2), and dropping its copy of
GRecordDll.dll into the 310 alongside the exes. Or contact me off list
and I'll send you a copy.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 10th 09, 09:55 PM posted to rec.aviation.soaring
Papa3
Default xcsoar
On Aug 10, 4:14*pm, Martin Gregorie
missing. * I tried extracting all files to the root and also maintaining
worked.
martin@ * | Martin Gregorie
org * * * |
Well, there were a number of DLLs that ship with the 5.2.2 PNA version
missing. Once I loaded the 5.2.2 version onto the SD Card then the
new LX8000alfa, everything seems to be just fine. I think I had
previously loaded a version designed for the PC by accident...
Old August 11th 09, 01:57 AM posted to rec.aviation.soaring
Al[_7_]
Default xcsoar
worked.
org * * * |
missing. * Once I loaded the 5.2.2 version onto the SD Card then the
new LX8000alfa, everything seems to be just fine. * I think I had
So what do you think of it?
HP310 and XCSoar Jim White[_3_] Soaring 2 January 14th 09 06:15 PM
XCSOAR Travis Beach[_2_] Soaring 3 May 24th 08 03:36 PM
XCSoar vs SoarPilot? Frank Soaring 0 December 16th 06 08:07 PM
XCSoar jorgie Soaring 2 November 2nd 04 12:05 AM
XCSoar Robert Danewid Soaring 2 February 7th 04 01:30 PM
