Question: Elevation --- RWY
Old August 10th 09, 08:41 PM
john89 john89 is offline
Junior Member
First recorded activity by AviationBanter: Aug 2009
Default Question: Elevation --- RWY
Hello everybody,
I got a question regarding the so-called "elevation", i.e. the highest point of a runway. I have been told that the elevation is usually at the threshold, right before the touchdown zone, in order to ensure an easier take-off.
However, as airplanes land in the same direction as they take off, isn't the descending RWY a problem for landing? My (admittedly unprofessional) reasoning suggests that it would be better for aircraft to land on RWYs increasing in altitude.
Am I completely off the track? Any experts out there, please help ;-)
John
Old August 11th 09, 03:50 AM posted to rec.aviation.piloting
Mike Ash
john89 wrote:
Hello everybody,
easier take-off.
Don't forget that most runways are also used in both directions
depending on wind, so that a sloping runway which is uphill for takeoff
in one direction becomes downhill for takeoff in the other.
Most runways are roughly level. If the money is available and the
terrain is amenable enough to be able to decide that one point on the
runway should be the highest point, then it should be enough to decide
that the runway should be level altogether and not have a single highest
point. This is usually considered the goal of making a runway.
Many runways are only roughly level, and contain small but noticeable
slopes. This is especially true at smaller airports. These slopes are
usually hard to discern from the ground (although I'm sure people will
chime in with counterexamples here) and don't affect aircraft
performance significantly.
There are a few airports whose runways are significantly sloped. You are
correct that aircraft are better off taking off downhill and landing
uphill. On runways like this, the aircraft will do exactly that, and
thus will take off and land in opposite directions. In a case like this,
using the slope appropriately is more important than operating into the
wind, so the typical performance reason for taking off and landing in
the same direction isn't there.
So in short, most runways are more or less level, and so takeoff/landing
direction isn't determined by slope. When the slope is significant, take
off downhill, land uphill.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Old August 11th 09, 04:23 AM posted to rec.aviation.piloting
quietguy
Field elevation is the elevation of the highest point on the usable
portion of the runway(s). Its location can't be assumed, and the only
place I've ever seen it precisely indicated is on geodetic survey maps.
Old August 11th 09, 04:37 AM posted to rec.aviation.piloting
D Ramapriya
I seem to remember that the runway in my hometown Bangalore had its
maximum elevation at roughly the center
and don't affect aircraft performance significantly.
From what I've heard, (a) aircraft are certified for a 2% slope and
(b) you're barred from employing flexible takeoffs where the runway is
sloped (I don't know if this applies to *any* slope).
The other aspect this influences - and I think this doesn't apply for
GA aircraft - is the maximum takeoff weight. FAR 121.189(e) mentions
runway gradient as a factor in MTOW calculations.
Ramapriya
Old August 11th 09, 04:54 AM posted to rec.aviation.piloting
Ron Reagun
"john89" wrote in message
Hello everybody,
easier take-off.
John
http://204.108.4.16/d-tpp/0908/00769IL9.PDF
An IFR chart will gir you the touchdown elevation for the runway your
landing on.
john89
Old August 11th 09, 06:12 AM posted to rec.aviation.piloting
bod43
Hello everybody,
easier take-off.
John
landing on.
Here is one where you land uphill and takeoff
downhill - everytime.
http://www.youtube.com/watch?v=uNFNFZq2BFY
Courchevel, France.
http://www.youtube.com/watch?v=LDY1-...eature=related
Here is the biggest visitor I can find.
De Havilland Canada DHC-7-102 Dash 7
http://www.airliners.net/photo/Tyrol...bd7361540d25e9
Rumours of a Citation.
Old August 11th 09, 08:17 AM posted to rec.aviation.piloting
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Courchevel, France.
Another:
http://www.jetphotos.net/viewphoto.php?id=152136
http://www.airliners.net/photo/0364044/M/
Tenzing/Hillary airport, Lukla, Nepal. If you miss it, you
won't have a chance to go around.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iD8DBQFKgRkYyBkZmuMZ8L8RAidWAKC/OwqUj4Q43Y8Jzd5cyc4+sAqPmwCg1W7i
gcsCfEaBQxV1oui7070nwss=
=rdjP
-----END PGP SIGNATURE-----
Old August 11th 09, 07:18 PM
Junior Member
Thanks a lot guys,
very detailled and informative answers!
Apparently there are just now "absolute" true rules such as:
Airplanes always land in the same direction as they took off.
Airplanes take off downhills and land uphills.
Airplanes both take off and land with headwind. etc...
Alas, no rule without exception ;-)
Still, the elevation of the RWY being in its centre (as claimed by D Ramapriya) still denies any logic as far as I can see.
John
Old August 11th 09, 07:57 PM posted to rec.aviation.piloting
jan olieslagers[_2_]
That's true enough, but on top of that the rules that do exist have
their bounds, geographical or other.
One example: here in Belgium, we have the notion of an "active runway"
and this is communicated either per radio (on controlled aerodromes) or
in the signal square. But in France the concept of an active runway is
not universally applied (to say the least), I remember hearing a
visiting pilot inquiring what run runway to use, and getting for answer
"ah, you know, there's not too much wind, you just pick the 12 or 30 as
you prefer..."
KA
Old August 11th 09, 08:49 PM posted to rec.aviation.piloting
C Gattman[_3_]
easier take-off.
This information is available to pilots and updated periodically in
the Airport/Facilities Directory and the US Terminal Procedures, etc.
The A/FD defines it's "elevation" figure as "the highest point of an
airport's usable runways measured in feet from mean sea level." In
addition, the A/FD lists runway slope when it is .3 or greater for
airports that have instrument approaches and elaborates based on other
runway criteria ( or than 8000', etc)
For IFR purposes, the A/FD and approach plates include a Touchdown
Zone Elevation (TDZE) for specific runways.
Pilots, particular under IFR, are expected to be familiar with runways
of intended use and, if required, alternate airports. We're strongly
encouraged to study other airports along the route in case we need to
divert. Cheers!
-Chris
CFI, KTTD
ASTER Global Digital Elevation Map AGL Soaring 1 June 30th 09 03:11 PM
Elevation info for Garmin Glide Ratio functionality Jack Glendening Soaring 1 July 30th 07 04:49 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
How do I get MSL out of National Elevation Dataset? Kyler Laird General Aviation 0 January 12th 04 08:12 PM
