The rope is polyproplene, we have been using it on our Skylaunch at
Camphill for over 12/15 months. Drum capacity is a problem at over 1000 yds, and it cannot be used on the smaller capacity Tost winch drums. It seems to wear as well as steel on grass, and is cheaper. BTW, Camphill too still bungee launches, but usually only at Vintage glider meetings. Dave At 16:45 04 August 2009, Del C wrote: We had that Denbigh winch at Lasham for a trial period, before we invested in two new Skylaunch winches. It was a very nice winch and gave really smooth launches. On arrival it was fitted with 9.5 mm Skyrope cables, which I think is polypropylene, but due to our longer runs this was replaced with 4.5mm stranded steel cable. You can't get enough poly rope on the drum for much more than about a 1000 metre run. Is was fitted with an 8.2 litre 'Hi Torque' engine of about 350hp, but due to the power required to launch our DG1000Ts on still days, our new ones have the 'Hi Power' engines of 450hp. They are also fitted with pulley heads rather than rollers. The Mynd retrieve winch is fitted with 2.5mm stranded steel cable. The other 6 drum winch sounds like a MEL Van Gelder. Derek Copeland At 16:00 04 August 2009, Peter Higgs wrote: At 20:00 03 August 2009, Derek Copeland wrote: Hi Pete, What club do you normally fly at, because the Mynd doesn't have an abrasive tarmac runway, or for that matter much mud except in the Winter; just nice smooth short grass well lubricated with sheep dropping. Also to the best of my knowledge they have always used steel cable, rather than Dyneema. Hi, the club with the tarmac and Skylaunch was the now defunct Denbigh club. I am not too sure what the replacement plastic rope was, only that it was a turquoise green colour, and I could very easily splice it using about 6 'interlocking twists'. I only ever had one accidental cable break, and that was at 850ft when a severe attack of turbulent air was encountered, which bust the weak link. You are quite right about Long Myndd, they use the 4.5mm steel cable, with a lighter (~ 3mm) retrieve cable to the retrieve winch at the launch end. If they have gliders lined up, it's about one every two minutes, on their one and only cable. The old Sealand club used to have a very large 6 cable winch, which could launch 6 sequentially, before the land-rover had to bring all the cables back. I don't know what that winch was, but it may have been the sort used at other RAF gliding sites. Pete |
Saturday 072807 in Oshkosh Pt 2 - the C17 [08/14] - "08 C17 hope they used the really thick bungee cords on the cargo.JPG" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 30th 07 10:48 PM |
AOPA Expo, meeting JayB, getting stuck in Lancaster on the way home,fulfilling the commercial certificate long solo x-c...long | Jack Allison | Piloting | 6 | November 19th 06 02:31 AM |
nose bungee replacement concern | Dick | Owning | 1 | November 1st 06 03:58 PM |
Puchacz shock cord (bungee) failure | [email protected] | Soaring | 4 | July 1st 06 09:18 PM |
Another Long Cross Country: HPN to PAO in 6 Days (long) | Journeyman | Piloting | 19 | June 15th 06 11:47 PM |
