#21
On Aug 15, 11:18*am, "RST Engineering - JIm"
wrote: KGOO (formerly O17, Grass Valley CA) has a 3% slope to the runway. *The firebombers (air tankers Grumman S2Ts) always take off downhill and land uphill. *Night operations for everybody are notamed the same because of the trees at the east end of the runway. Jim On Aug 11, 1:18 pm, john89 wrote: Apparently there are just now "absolute" true rules such as: Airplanes always land in the same direction as they took off.- Hide quoted text - - Show quoted text - Jim, a 3% slope would mean 3 feet of altitiude change per 100 feet of runway. On a 4000 fooot runway that means 120 feet. My question is, if the tiedowns are near the low end, when the altimeter is set to local pressure, if the altimeter is calibrated and the field elevation is taken as the highest point on the runway, there would be a 120 foot 'error'. For a pilot starting an IFR flight who didn't know better, that's outside the 75 foot error allowed. Are there special procedures published for that airport or others like it? SInce the takeoffs there are downhill, the altimeter would read within tolerance if checked during run-up at the take off end (if one knew of the problem) but I am wondering about the more general case. |
My error. We did a massive cut and paste job on the runway about 15 years
ago and took an average 3% slope down to 2.1% But that's not the point. THe point is that both ends of the runway are surveyed and the elevation at that end marked for altimeter setting. THe other point is that instrument approach charts list TDZE (touch down zone elevation) for just this reason ... not many airports have EXACTLY the same elevation at both ends, not even in Kansas, Toto. Jim "a" wrote in message ... On Aug 15, 11:18 am, "RST Engineering - JIm" wrote: KGOO (formerly O17, Grass Valley CA) has a 3% slope to the runway. The firebombers (air tankers Grumman S2Ts) always take off downhill and land uphill. Night operations for everybody are notamed the same because of the trees at the east end of the runway. text - - Show quoted text - Jim, a 3% slope would mean 3 feet of altitiude change per 100 feet of runway. On a 4000 fooot runway that means 120 feet. My question is, if the tiedowns are near the low end, when the altimeter is set to local pressure, if the altimeter is calibrated and the field elevation is taken as the highest point on the runway, there would be a 120 foot 'error'. For a pilot starting an IFR flight who didn't know better, that's outside the 75 foot error allowed. Are there special procedures published for that airport or others like it? SInce the takeoffs there are downhill, the altimeter would read within tolerance if checked during run-up at the take off end (if one knew of the problem) but I am wondering about the more general case. |
ASTER Global Digital Elevation Map | AGL | Soaring | 1 | June 30th 09 03:11 PM |
Elevation info for Garmin Glide Ratio functionality | Jack Glendening | Soaring | 1 | July 30th 07 04:49 PM |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
How do I get MSL out of National Elevation Dataset? | Kyler Laird | General Aviation | 0 | January 12th 04 08:12 PM |
