Emergency Descents with ATC COMS - Video
Old August 25th 09, 02:12 PM posted to rec.aviation.piloting
Ricky
Default Emergency Descents with ATC COMS - Video
On Aug 23, 8:17*am, Robert Moore wrote:
Jeeze...damn amateurs.......
Jeeze...grumpy, retired, ex-military, old men.......lighten up. Your experience and knowlege is very valuable here, but it would be much more well received with some grace and kindness.
Bob Moore
P-3B
P-3, huh? I am cutting my A&P teeth on a rehab of a P-3, which is what
my company does. My first P-3 is about to take it's maiden flight
after a 3 year rebuild, and after we get all the tank leaks sealed
(again).
Ricky
Old August 25th 09, 03:27 PM posted to rec.aviation.piloting
Robert Moore
When someone "preaches" as much BS as Flaps_50! did in his post, someone
needs to call it BS in no uncertain terms.
If Flaps_50! wants to instruct pilots, maybe he should study some more
himself.
Bob Moore
CFIing since 1970
Old August 31st 09, 02:08 PM posted to rec.aviation.piloting
Flaps_50!
Ah, I see YOU say BS 'cos you think the newsgroup is american. LOL
Cheers
Old August 25th 09, 03:36 PM posted to rec.aviation.piloting
a[_3_]
Bob Moore
P-3B
(again).
Ricky
The M20J is a wet wing tank sealed with something that was found to
like to disolve in what ever is added to 100 octane low lead. We had
to fix the leaks a couple of times in an early M20J, I expect the
problem has been solved a long time ago. What is the nature of the
leaks your P-3 has: inital sealant a little better than bubble gum?
Old August 27th 09, 05:05 PM posted to rec.aviation.piloting
Ricky
Bob Moore
P-3B
(again).
Ricky
Well, you may know the P-3 is a wet-wing also, with a wet belly tank,
too, just behind the bomb bay. The sealing procedure is very, very
extensive after all external and internal reapairs & work have been
done on the wings and belly. Every single Hi-Lok, rivet, Cherry-Max,
bolt, screw, plank, doubler, tripler, etc, etc. is a potential leak.
So, there are literally hundreds, perhaps thousands, of potential
escape routes for the Jet-A. The sealant we use is fine, great,
actually, but with so many potential leaks, it is simply impossible to
aassure the sealant job is leak-proof in every single place.
We pressurised the tanks for the first time 2 weeks ago & there were
several leaks, albeit small ones. This means we must find the leak,
then do a re-sealant job to that area. After two weeks we finally have
almost 100% integrity with the fuel tanks. We have started engine runs/
testing and the plane will go to the paint shop soon, then back into
service until the ancient (but wonderful) bird is retired or replaced
by 737s.
Ricky
Light gun work with ATC COMS - Video [email protected] Instrument Flight Rules 25 July 19th 09 12:07 AM
Light gun work with ATC COMS - Video [email protected] Piloting 5 July 15th 09 03:20 AM
Pop up IFR clearance with ATC COMS - Video [email protected] Piloting 0 November 15th 08 05:05 PM
Pop up IFR clearance with ATC COMS - Video A Lieberma[_2_] Owning 0 November 15th 08 05:04 PM
Pop up IFR clearance with ATC COMS - Video [email protected] Instrument Flight Rules 0 November 15th 08 05:04 PM
