OK someone help me
Old September 8th 09, 06:45 PM posted to rec.aviation.soaring
Greg Arnold
Default OK someone help me
Brad wrote:
On Sep 8, 6:56 am, brianDG303 wrote:
On Sep 8, 6:07 am, jcarlyle wrote:
When I used a Cambridge 25, I also had an iPAQ 3950 running Glide
Navigator II. At the end of the flight GNII would save the log file in
both .cai and .igc form onto the SD card, which I took home. SeeYou
did its magic and uploaded to OLC. Quick, easy, and almost fool-
proof.
-John
Steve Leonard wrote:
At 05:59 08 September 2009, Greg Arnold wrote:
You can also open the CAI file in SeeYou, save it in Seeyou as an IGC
file, then upload that IGC file to OLC.
That would be assuming you have bought SeeYou. Not too likely with a
borrowed logger! But, yes, that will also work.
Brad, not sure, but I kind of doubt it. You might look at your garmin
file and see if it looks like the same format for the data as a .cai file.
If it does, try saving it with a .cai file extension, and try the program.
You don't have anything to lose but a few minutes of time and a few "k"
of memory on the old machine!
And for what it is worth relative to SeeYou, etc, I am talking to my
loggers with an old TI Extensa running Windows 98, and talking with it
through a REAL serial port. No USB hub there! But to get any further, I
have to save it to a floppy, the use my USB floppy drive on a newer
computer to read the file, convert it, and upload. All my tlaking to the
logger is done with the old Cambridge DOS program, as is initial viewing.
Later viewing is done using the upgraded AeroExplorer II.
Still Old School for sure,
Steve- Hide quoted text -
- Show quoted text -
It might be possible to use SeeYou without buying it. Andej doesn't
disable many features in his trial versions of SY and SYM, I flew 15
flights on the trial version of SYM before buying it.
Brian
I do have a licensed copy of SeeYou for the PC. I got the key after I
realized that it really turns to cripple ware after the trial.
I open my XCsoar generated igc files to view at them in SeeYou before
I post to OLC.............should I do a save or a save-as from SeeYou
to validate the igc file?
File/Save As
Thanks,
Brad
Old September 8th 09, 07:30 PM posted to rec.aviation.soaring
Edward
At 16:59 08 September 2009, Brad wrote:
in
proof.
-John
an
I=
GC
That would be assuming you have bought SeeYou. =A0Not too likely
with=
a
borrowed logger! =A0But, yes, that will also work.
Brad, not sure, but I kind of doubt it. =A0You might look at your
gar=
min
cai
file.
=A0If it does, try saving it with a .cai file extension, and try
program.
=A0You don't have anything to lose but a few minutes of time and
a
fe=
w "k"
my
with
i=
t
through a REAL serial port. =A0No USB hub there! =A0But to get any
fu=
rther, I
newer
computer to read the file, convert it, and upload. =A0All my
tlaking
to the
view=
ing.
Brian
Thanks,
Brad
XCSoar isn't on the OLC approved list
http://www2.onlinecontest.org/validate.php
so your file won't be valid.
If cai2igc4olc doesn't convert your Garmin gdb file, try this site:
http://www.gpsvisualizer.com/gpsbabel/
