OK someone help me
Old September 8th 09, 02:01 PM posted to rec.aviation.soaring
vontresc
Default OK someone help me
On Sep 8, 12:45*am, Brad wrote:
On Sep 7, 10:30*pm, Steve Leonard wrote:
To get it to validate, you will need to run Carl Ekdahls conversion
program. *Do a Google Search on "cai2igc4olc". *Let this program make
your .igc file, and it will upload as a valid file for OLC.
All sorts of little de-coder rings you've got to have when you enter the
electronic age with old school electronics!
Steve
Steve,
If I convert a garmin gdb file to and igc file using that Carl Ekdahls
conversion program, can I get rid of the V in the red circle? I log
using a Garmin map 60 and also XC-Soar, XC-Soar logs an igc file, it
gets scored but is never valid!
thanks,
Brad
Brad, check out the list of approved software for the OLC here.
http://www2.onlinecontest.org/validate.php
The easiest solution would be to use SeeYou as it can download
directly from your Garmin IIRC, but you will need to buy the software.
If you are a frugal glider pilot like we all are you can use G7toWin,
which will download directly from your Garmin unit, and create an olc
valid .igc file.
http://www.gpsinformation.org/ronh/g7towin.htm
Peter
