Double Release Failure
Old September 8th 09, 08:52 PM posted to rec.aviation.soaring
bildan
Default Double Release Failure
On Sep 8, 1:16*pm, FBCompton wrote:
Probably less than the number of understrength ropes/weak links. *But
that's a different issue being addressed by regulatory authorities.
Bill,
Which regulatory authorities and where are they doing the addressing?
The FAA & NTSB based on a conversation during a recent accident
investigation. The NTSB showed up at an accident site that would not
normally be on their radar - i.e. a minor accident with no in-flight
breakup, fire or fatality.
Their main interest was the weak link, ring set and release hook
maintenance/replacement records. They were obviously educating
themselves while building a data set for a report leading to further
action.
Another point which arose in that discussion is that if your POH says
you need a 650 KG weak link with a + or - 10% tolerance for both winch
and aero tow, the old 80 - 200% rule doesn't satisfy that
requirement. In most cases, the POH value falls within the 80-200%
range. but if it doesn't, the POH weak link value trumps the 80-200%
rule.
You (Double-A) broke it, so you fix it. Michael Baldwin, Bruce Products 0 November 30th 06 05:01 AM
Double (or more) posting flying_monkey Soaring 1 September 1st 06 03:54 PM
Double tow [email protected] Soaring 2 October 25th 05 07:16 PM
Double Tow Doug LS4 Soaring 5 October 11th 05 02:37 AM
Rare V-2 Double Launch Pic, WW2 robert arndt Military Aviation 0 July 8th 03 05:02 PM
