![]() "Jay Honeck" wrote We replaced our prop adjustment cable in the Pathfinder this year. It was probably the original cable from 1974. It was getting stiffer and stiffer over time. Upon removal it was obvious that a few strands of the sheathing had broken, and were scraping on the cable every time we moved the blue lever. How this happened is a mystery, but after 25 years we figured it didn't owe us anything. (Although it is a real SOB to change...) Yep. Some things will not last forever, and cables are one of them. Once they get enough age and use and age on them, switch them out, as part of a good preventative maintenance program. After all, what good is keeping fuel in the tank, airspeed under the wings, and a good running engine and airframe, if you can't control the damn thing! g That is one important piece of twisted up steel, going from your hand to the engine and prop. The OP did a great job getting the plane down safely. No argument from me on that point! -- Jim in NC |
get enough age and use and age on them, switch them out, as part of a good preventative maintenance program. I always wonder how to implement something like this, and with which items. Control cables, for example, are obviously critical -- yet I don't recall ever hearing about them being changed on condition, let alone preemptively, even on our 61 year old Ercoupe. Sure, they're inspected every year, and occasionally adjusted, but apparently they never wear out? Yet surely they must, someday. Just another one of those things you think about when you're flying an antique aircraft. Right up there with "golly, that wing is only held on with two bolts", and "gee, I wonder how many bouts of turbulence a six-decade-old wing spar can withstand?" :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 Ercoupe N94856 www.AlexisParkInn.com "Your Aviation Destination" |
In article pQ_pm.36760$5n1.23712@attbi_s21,
"Jay Honeck" wrote: Some things will not last forever, and cables are one of them. Once they get enough age and use and age on them, switch them out, as part of a good preventative maintenance program. I always wonder how to implement something like this, and with which items. Control cables, for example, are obviously critical -- yet I don't recall ever hearing about them being changed on condition, let alone preemptively, even on our 61 year old Ercoupe. Sure, they're inspected every year, and occasionally adjusted, but apparently they never wear out? Yet surely they must, someday. Just another one of those things you think about when you're flying an antique aircraft. Right up there with "golly, that wing is only held on with two bolts", and "gee, I wonder how many bouts of turbulence a six-decade-old wing spar can withstand?" :-) How about, "Those wings are only held on with two pins *which I just installed myself an hour ago*." Or, "Gee, those pins that hold the body to the wings are smaller than my thumb, and there's only two on each side." Flying an aircraft you assemble yourself each time you fly it is much like flying an antique aircraft in that respect. (Flying an antique you assemble each time you fly is even better yet.) -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Jay Honeck wrote:
/snip/ Control cables, for example, are obviously critical -- yet I don't recall ever hearing about them being changed on condition, let alone preemptively, even on our 61 year old Ercoupe. Sure, they're inspected every year, and occasionally adjusted, but apparently they never wear out? Yet surely they must, someday. /snip/ Jay, Control cables are absolutely changed out on condition. They will tend to fray where they pass over pulleys, especially if the cable tension is a bit loose (it will tend to "bounce" against the pulley), or the pulley doesn't turn as freely as it should. During maintenance checks, a mechanic will run their fingers over all cables at these locations, and any broken strands will be felt, as they tend to stick out. Not super common on light GA aircraft, but not at all unheard of. Corrosion can also be a problem. Advisory Circular 43.13 has an entire section devoted to cable inspection and condition. Happy Flying! Scott Skylane |
On 2009-09-10, Jay Honeck wrote:
Just another one of those things you think about when you're flying an antique aircraft. Right up there with "golly, that wing is only held on with two bolts", and "gee, I wonder how many bouts of turbulence a six-decade-old wing spar can withstand?" Or... "Good grief, the wing is only held together by 64 year old glue!" The joys of worrying about wood wings :-) |
A few from - Last Week 00.jpg (0/1) | RustY© | Aviation Photos | 1 | May 23rd 08 02:01 PM |
More Evidence Bush Was Actually Declared a Deserter | WalterM140 | Military Aviation | 9 | August 23rd 04 11:36 PM |
Declared "minimum fuel" | O. Sami Saydjari | Instrument Flight Rules | 14 | April 4th 04 02:43 AM |
A record: 1 in 73 US households declared bankruptcy in '03 | Krztalizer | Military Aviation | 7 | March 15th 04 09:27 PM |
