#11
"Denyav" wrote
Stealth is used today to "knock down the door" and the rest of the stuff does the grunt work. The B-2 and other stealth assets are used to knock down the electronic systems (radar, Yeah right,It proved its abilities,albeit under full ECM support aganist defences of Panama,Afghanistan,Iraq,Serbia etc. (In Balkans two ECM failures meant two f117 damages,but nevermind) The US Military uses ECM and decoys. They would use them whether or not stealth aircraft existed. I wonder how they would fare against US ,UK or German counter LO systems? I don't know what UK and German "counter LO" systems are deployed and integrated into their air defense system, or even if it exists. Today you can detect and track a LO aircraft even more easily than conventional aircraft with multistatics. Your sentence doesn't make sense, so I'm assuming that English isn't your native language, and will leave it at that. The stealty airborne platforms have only a PR value today,and thats the reason why Air Force put them on display on every occasion,even though the passive stealth is an extremely "sight-sensitive" technology !. Fine, Fine. Whatever... |
integrated into their air defense system, or even if it exists. But probably you know that an US system exists,so a Mitchell style demonstration would be very useful to settle differences. Your sentence doesn't make sense, so I'm assuming that English isn't your native language, and will leave it at that. It makes excellent sense for the ones who want to understand but a clarification for you,multi static designers love everything that stealth designers do to reduce backscatter. Fine, Fine. Whatever... Spending hundreds of taxpayer billions for an obsolete technology is not fine,I guess. |
![]() "Denyav" wrote in message ... Spending hundreds of taxpayer billions for an obsolete technology is not fine,I guess. What do you care if US taxpayers spend billions on obsolete technology? |
Trouble with the F15 and F14 - and the rest of the fleets - is that
fighters wear out. You can replace part after part but when the basic airframe reaches its fatigue life - better scrap it and make pots and pans out of it or you're going to have inflight failures. During my career this happened to the F84, F86, F100, F105, KB29 and KB50, B47, B52, C130, A26 and F4, to mention but a few. I lost a good friend to inflight failure in an F4 on a training mission. As for stealth, first let me mention I spent some 4000 hours sitting behind a radar scope in a fighter. In the F102A and the F4 I could detect another fighter at ranges up to 70 miles. The 104A's scope only went out to 20 miles but it still beat the naked eye. Now a stealth fighter wouldn't have this vulnerability, nor would it be detected at night or in the weather until well after it detected an unstealthy fighter. Upon detection of a target one manuevers into the target's stern and then - do what is necessary. One does not have to lock on to do this. It is quite easy to determine the target's approximate course by monitoring target motion on the radar scope and, after moving into the stern quarter, determining his exact course and altitude is simple. Most radar warning gear will not indicate AI scanning so the target will be unaware what is happening. Of course if you are in an IR equipped fighter the target's problem is even worse - his first indication of a problem is when (if) his missile warning gear detects a missile launch in his six.l Walt BJ |
![]() "WaltBJ" wrote in message om... As for stealth, first let me mention I spent some 4000 hours sitting behind a radar scope in a fighter. In the F102A and the F4 I could detect another fighter at ranges up to 70 miles. The 104A's scope only went out to 20 miles but it still beat the naked eye. Now a stealth fighter wouldn't have this vulnerability, nor would it be detected at night or in the weather until well after it detected an unstealthy fighter. How does a stealth fighter detect an unstealthy fighter? Upon detection of a target one manuevers into the target's stern and then - do what is necessary. One does not have to lock on to do this. It is quite easy to determine the target's approximate course by monitoring target motion on the radar scope and, after moving into the stern quarter, determining his exact course and altitude is simple. Most radar warning gear will not indicate AI scanning so the target will be unaware what is happening. Of course if you are in an IR equipped fighter the target's problem is even worse - his first indication of a problem is when (if) his missile warning gear detects a missile launch in his six.l Walt BJ |
Actually, over Baghdad, they didn't use active jamming for the F-117
sorties. It would have warned the defenses that an attack was coming. Since there were well over a thousand sorties over Baghdad, with zero losses and zero damage, it's amazing that you keep trying to I am talking about DS I,not DSII,During DSI several guided launches aganist f117 have been detected and spoofed by jammers. If Jammers failed during DS I,you would not have to wait till Balkan Conflict for f117 losses. About a year ago I posted some data about f117 performance during DS I,they were under ECM protection all the way/ A quote from DS I f117 driver explains all "Jammers are like American Express,never leave home without them" Nope. That's just something the less-honest multistatic guys are suggesting as a sales method. They still haven't gotten the system to work that well against any aircraft, and certainly not good enough to track and target any of the stealth aircraft. They are doing exactly that almost on daily basis,plus they can also image stealth aircraft with their multistatics.(they can even find out the type of skin material) Except for that whole "flying them on combat missions" thing, not to mention the "buying more of them" bit. Since everyone in the world who's building combat planes is doing *some* stealth and low-observable design, it's odd that they haven't gotten the message yet. Most of "new" stealth projects involve some kind of active stealth which is a completely different animal. You keep using that "sight-sensitive" phrase, and it's still wrong. Thats the truth ,passive stealth is an extremely "sight-sensitive" techonology and in 70s and 80s you definitely needed to know the hardbody shape to counter it,thanks to rasant development of multi statics and UWB radars thats not the case anymore. |
Because its my money and I have every right to say how things should be done in this country,even if you disagree with my views. |
![]() "Denyav" wrote in message ... Because its my money and I have every right to say how things should be done in this country,even if you disagree with my views. It's US citizens' money. |
Exactly,so its my money too. Fair enough? |
Stealth homebuilt | C J Campbell | Home Built | 1 | September 15th 04 08:43 AM |
SURVEY on manuals - most important for builders, but never good?? | T-Online | Home Built | 0 | January 23rd 04 04:37 PM |
F-32 vs F-35 | The Raven | Military Aviation | 60 | January 17th 04 08:36 PM |
How long until current 'stealth' techniques are compromised? | muskau | Military Aviation | 38 | January 5th 04 04:27 AM |
Israeli Stealth??? | Kenneth Williams | Military Aviation | 92 | October 22nd 03 04:28 PM |
