Expanding a bronze bushing?
Old September 15th 09, 07:29 PM posted to rec.aviation.homebuilt
Dan[_12_]
Default Expanding a bronze bushing?
Steve Hix wrote:
In article , Dan
Peter Dohm wrote:
"Dan" wrote in message
Peter Dohm wrote:
"brian whatcott" wrote in message
Michael Horowitz wrote:
I have a small bronze bushing whose OD I'd like to expand slightly so
it fits the ID of a tube.
I seem to recall there was a way to expand the OD slightly with
something like a knurling tool. Does that sound familiar? Is there an
easy way to do this? - Mike
That method is generally recognized as cowboy engineering.
You might hope for better life from using a metal powder filled epoxy
to fill the gap, and that's no great shakes either.
Pick a bigger bush and reduce it, if you possibly can.
Brian W
What??? Is "cowboy engineering" the newest politically correct version
of political incorrectness in describing a "kluge" or generally
unacceptable practice?
Peter ;-)))
You're gonna upset some guys who're real good with .44s
.44 is for sissies, try .500 S&W magnum. In any event knurling isn't a
good solution for something on which your life may depend. There simply
isn't enough surface generated by knurling. I have done it for toy steam
engines, but would never do it for something that has significant forces
applied. Bear in mind bronze and the tube material have different
temperature expansion rates.
If you don't need to apply a lot of force to it you can use a prick
punch to stipple the outside of the bushing if you don't have access to a
lathe and knurling tool.
If you choose to make your own bushing bear in mind there are different
bronze alloys each with its own characteristics. I use phosphor bronze for
most of my bearing applications.
Dan, U.S. Air Force, retired
AFAIK, the .44 was the percussion cap wheel gun that became the .45 Long
Colt, a/k/a The Gun That Won The West, and extremely popular amoung cowboys
during the brief period of the Old West.
In any case, I agree with you about knurling.
Peter
Oh, THAT 44 Mine is a replica Colt army. Did you know if one
doesn't crimp the caps correctly they all drop off when the first one is
fired? Not that anything like that ever happened to me or anything.
And then you're left with trying to decide whether scrabbling on the
ground to pick up caps and try again, or to get a new batch out of the
tin will be less obvious to onlookers.
Generally, they won't notice, being doubled over, laughing hysterically.
Never happened to me, either. Nope.
Have you ever noticed a truly good foul up is almost always
accomplished with an appreciative audience?
?replace bushing on compressor wheels? mhorowit Home Built 4 September 22nd 08 03:43 AM
Expanding my flying comfort zone (long) Ron Lee[_2_] Piloting 2 December 8th 07 03:02 AM
Enlarging a bushing hole? Michael Horowitz Home Built 18 September 17th 07 11:57 AM
(CNN & AP) U.N: Iran expanding rather than freezing nuclear program AirRaid[_3_] Naval Aviation 3 February 26th 07 06:49 PM
Rubber Bushing Replacement Boelkowj Home Built 8 December 12th 03 12:45 AM
