Landings in phase 1 of flight test
Old September 18th 09, 12:45 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Landings in phase 1 of flight test
"pittss1c" wrote
The flight test period is also the same weather you are testing a new
radical design or your 3rd RV with a lycosaurus.
Not so. If you are using an engine and propeller combination that was
certified in any certified aircraft the flight test may be, and probably
will be, reduced to 25 hours.
Jim in NC
Old September 18th 09, 03:30 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
I don't know how the DARs do it, but in the old days when the FAA did
inspections they could set any restrictions they wanted.
Including things like time of flight - 6:00AM to 6:01AM.
It all depended on how they felt about the design, workmanship, and
pilot capabilities.
One story goes that it was the FAA reps that vetoed John Dyke's intent
to use foam cored fiberglass for primary structure in the Dyke Delta.
To radical for the times.
Remember, any particular DAR is NOT obliged to approve your project.
For what it's worth...
Richard
Old September 18th 09, 04:30 PM posted to rec.aviation.homebuilt
pittss1c[_2_]
Not so. *If you are using an engine and propeller combination that was
Jim in NC
Right. I think if you were to take one right from the overhaul shop or
new from the box, that is easily the case.
When it comes off an existing experimental, it is not so easy.
Besides, I think the dataplate was removed from the pan to comply with
the letter of the law, so there is no chance of it being considered a
certified engine (even though it has 100% certified parts, and has 300
hrs of proven operation)
Mojave Civilian Flight test center accident...Rutan SpaceShip II propellant test explosion. Blueskies Piloting 3 July 27th 07 11:47 PM
Phase 1 flight. Gig 601XL Builder Home Built 3 March 27th 07 05:31 PM
Commercial 250nm VFR flight - all 3 landings on the same day? Jim Macklin Instrument Flight Rules 39 December 20th 06 12:11 PM
New 18m Class ship - First Flight - The JS1 starts proving flight phase [email protected] Soaring 2 December 14th 06 02:06 AM
