cavelamb wrote:
However an open canopy would effect handling (and I can see nightmares there), there is one point we've kind of skipped over... If the canopy latches were not damaged, then I would surmise that it was not latched. That would be pilot error - pure and simple. The fact that the latches weren't damaged doesn't mean the canopy hadn't been latched when the takeoff run began. Doors/canopies do pop open. It can sometimes be a matter of rig, so that there wouldn't necessarily be obvious evidence on the latch hardware post-crash. According to Phillips' geocities page, the plane had a pumped seal on the canopy. That may have applied some opening force in a case where latch wasn't up to snuff...or if it wasn't properly latched to start with. Are these kinds of seals normally interlocked with the canopy latches, so they won't inflate unless the latches are set? The NTSB report doesn't mention any previous problems with the latch...seems like any of Phillips' friends would have cued the NTSB investigator in if he'd been having problems with it. The plane was built by a "hired gun," so Phillip wouldn't have had a builder's understanding of how the system worked. The downwind takeoff does imply he was in a hurry, and thus more likely to forget to latch the lid. If the seals *were* interlocked with the latches, seems like the additional noise if the seals AREN'T filled would quickly cue the occupants that the canopy wasn't latched. But if the seals were able to be inflated with the canopy unlatched, there wouldn't be any sound cues...until the difference in pressure overcame the seal's friction and popped the canopy up. Ron Wanttaja |
Badwater Bill - Janice Phillips contact | BobR | Home Built | 1 | October 24th 08 02:46 PM |
NTSB report - ILS and ATC. How does it all come together? | Montblack | Piloting | 1 | June 19th 06 11:26 PM |
NTSB report - ILS and ATC. How does it all come together? | Montblack | Instrument Flight Rules | 1 | June 19th 06 11:26 PM |
Preliminary NTSB report on Walton accident | ChuckSlusarczyk | Home Built | 11 | July 12th 05 04:23 PM |
Prelim NTSB report, Pilatus accident in PA | vincent p. norris | Piloting | 15 | April 11th 05 02:52 PM |
