A 14" wheel and tire will just fit vertically across the trailer
without contacting the wing. If it's 13", as many older trailers were, there will be plenty of room. Mount it so the tire rests on the floor so there is less stress on the anchoring bolts and upright. It sounds like you've already had to remove the storage bin, so forward space may be at a premium. An earlier (1988) trailer fit the 13" wheel between the tracks and under the glider's nose, lying on the floor with a bolt through it and secured with a wing nut. Best to reinforce the floor to do that mod. A thin alloy plate on the underside should do the trick. You may also find the fuselage will rub the spare tire if the tire is too wide (perhaps anything above a 185) so use a narrow tire for the spare. Incidentally for anyone with 13" wheels who would like more ground clearance, Spindelberger builds a lift kit (25mm or 50mm height) which goes between the axle and frame. Much less scraping the tail, and if you have a storage drawer it will last longer. I think the kit was only 60 or 80 Euros and was easy to install on an empty trailer sitting on four jack stands. It will be a special order item. Jim I'm looking for ideas how to mount the spare up front now. *The under nose option above sounds promising -- how do you anchor down the tire? *I'm also thinking of using some angle iron so that the tire can hang on the front of the column, but it will be more vertical. *Will it fit? Thanks, -- Matt |
cobra trailer brake lever gas strut failure? | Frank[_1_] | Soaring | 11 | March 31st 09 08:59 PM |
Trailer tire rims | Gary Carter | Soaring | 7 | January 21st 05 03:15 PM |
Trailer spare - who woulda thunk? | Bill Daniels | Soaring | 7 | May 20th 04 04:47 PM |
Tire Stiffness & trailer swaying - resolution | chris | Soaring | 6 | October 26th 03 03:50 PM |
Tire Stiffness & trailer swaying | chris | Soaring | 42 | October 22nd 03 03:51 AM |
