Darryl Ramm wrote:
On Sep 27, 8:39*am, John Cochrane wrote: Starbrite Marine Polish with FTPE is very good. It's designed for gel coat to be put in water (boat). It was recommended to me by Dave Nelson after he did some refinishing work. Rub on, wipe off, shiny. John Cochrane And from the MSDS (http://www.sunworld.net.au/starbrite/msds.html, I could only find the OZ one) that also seems to contain silicone. Maybe relaying as much that silicone worry is a non-issue if people who do glider refinishing are happy to use it themselves as with the Star Brite or the Mequiars wax. Still you won't see me cleaning bugs off my glider with Pledge any time soon. Presumably the Star Brite is really a polish not just a plain wax. But maybe for use on gelcoat a bit if hand polish is a good thing. Darryl Maybe it has other brand names, but I use Carlack (or PolyLack because it has a sailplane on the label). Easy to use and silicone free as far as I know. |
At 20:56 27 September 2009, Gilbert Smith wrote:
Darryl Ramm wrote: On Sep 27, 8:39*am, John Cochrane wrote: Starbrite Marine Polish with FTPE is very good. It's designed for gel coat to be put in water (boat). It was recommended to me by Dave Nelson after he did some refinishing work. Rub on, wipe off, shiny. John Cochrane And from the MSDS (http://www.sunworld.net.au/starbrite/msds.html, I could only find the OZ one) that also seems to contain silicone. Maybe relaying as much that silicone worry is a non-issue if people who do glider refinishing are happy to use it themselves as with the Star Brite or the Mequiars wax. Still you won't see me cleaning bugs off my glider with Pledge any time soon. Presumably the Star Brite is really a polish not just a plain wax. But maybe for use on gelcoat a bit if hand polish is a good thing. Darryl Maybe it has other brand names, but I use Carlack (or PolyLack because it has a sailplane on the label). Easy to use and silicone free as far as I know. Carlack cuts a little while Polylack doesn't descriptions from product search on this site: http://www.afeonline.com/ (virus msg when trying to use tinyurl) |
as I know. I would bet that repair shops clean, clean and grind all old areas back to degree that there will be no problems with any product used on a surface. There are so many contaminants floating around that a repair shop must go through a careful cleaning of the damaged area before any work is started. So, I doubt that it makes any difference as to the brand/type of polish used. Your opinion may vary. Jump in. Bob |
Robert Gaines wrote: Easy to use and silicone free as far as I know. I would bet that repair shops clean, clean and grind all old areas back to degree that there will be no problems with any product used on a surface. There are so many contaminants floating around that a repair shop must go through a careful cleaning of the damaged area before any work is started. So, I doubt that it makes any difference as to the brand/type of polish used. Your opinion may vary. Jump in. Bob Been in a number of glider repair shops. Usually see empty New Finish bottles lying around... |
On Sep 28, 11:09*am, Berry wrote:
Been in a number of glider repair shops... It was your partner's fault, ehhh ? |
In article
, Dave Nadler wrote: On Sep 28, 11:09*am, Berry wrote: Been in a number of glider repair shops... It was your partner's fault, ehhh ? Never my own glider (yet) thankfully. A wonder considering how often I land out! |
Many years ago I attended at talk on gelcoat maintenance by Mr. Schneider
(the "S" in LS) He clearly stated that it does not matter at all if polish used on glider surfaces contain silicone. The reason: exactly what Bob also notes, no professional repairs can be done unless the surface is ground way beyond the depth to which silicone can penetrate. I guess he should know. I have since then used silicone based polishes on my gliders, and I have also had them repaired (dont ask..) without any complaints from the shops Happy (silicone assisted) soaring, Lars Peder DG-600 EE, Denmark "Robert Gaines" wrote in message ... Easy to use and silicone free as far as I know. I would bet that repair shops clean, clean and grind all old areas back to degree that there will be no problems with any product used on a surface. There are so many contaminants floating around that a repair shop must go through a careful cleaning of the damaged area before any work is started. So, I doubt that it makes any difference as to the brand/type of polish used. Your opinion may vary. Jump in. Bob |
On Sep 28, 1:26*pm, "Lars Peder Hansen"
wrote: Many years ago I attended at talk on gelcoat maintenance by Mr. Schneider (the "S" in LS) He clearly stated that it does not matter at all if polish used on glider surfaces contain silicone. The reason: exactly what Bob also notes, no professional repairs can be done unless the surface is ground way beyond the depth to which silicone can penetrate. I guess he should know. I have since then used silicone based polishes on my gliders, and I have also had them repaired (dont ask..) without any complaints from the shops Happy (silicone assisted) soaring, Lars Peder DG-600 EE, Denmark "Robert Gaines" wrote in message ... Easy to use and silicone free as far as I know. I would bet that repair shops clean, clean and grind all old areas back to degree that there will be no problems with any product used on a surface. *There are so many contaminants floating around that a repair shop must go through a careful cleaning of the damaged area before any work is started. So, I doubt that it makes any difference as to the brand/type of polish used. Your opinion may vary. * Jump in. Bob- Hide quoted text - - Show quoted text - I'm by no means an expert (just a guy who does an ocaisional minor cosmetic repair or refinish now and again), but my mentors taught me to start every project with copious amounts of 3M Prep Solvent (or equivalent) to remove wax, oil, grease, etc. This usually meant two passes using new (clean) paper towels for each pass. Never had any problems with gelcoat adhesion... P3 |
On Sep 27, 1:56*pm, Gilbert Smith wrote:
[snip] Maybe it has other brand names, but I use Carlack (or PolyLack because it has a sailplane on the label). Easy to use and silicone free as far as I know. Well Polylack seems to claim no silicon and Carlack does contains silicone at least that is clearly warned on the AFE Online web site. So if that is what you are worried about which one of the two you use seems to be pretty significant. So back to the argument of is really an issue or not?... Darryl |
On Sun, 27 Sep 2009 15:34:39 -0700, Darryl Ramm wrote:
On Sep 27, 1:56Â*pm, Gilbert Smith wrote: [snip] Maybe it has other brand names, but I use Carlack (or PolyLack because it has a sailplane on the label). Easy to use and silicone free as far as I know. I use Mer 'Ultimate Car Polish', a UK product, on my airframe. Its MSDS shows it to be non hazardous and doesn't list silicone, *but* their FAQ says that their polish contains silicone and that all polishes contain it. I also use Sparkle on my canopy. Its a US product and was apparently developed during WW2 to clean B-29 canopies. I haven't found an MSDS but they say the product contains only water, a mixture of glycols and a purple tint. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Free Stuff, Free Offers and Rewards Program | Tri-Pacer[_3_] | Aviation Photos | 1 | February 5th 09 04:47 AM |
FREE TRIAL - Rent Adult DVDs Online, Delivered Free by Mail. | [email protected] | Piloting | 0 | March 1st 08 05:26 PM |
Free photo competition + free images and hosting | Jpgs.com.au | Piloting | 0 | January 7th 07 06:57 AM |
F18 Hornet Pics -Royalty Free Images and free image hosting - members wanted please | Jpgs.com.au | Home Built | 0 | January 7th 07 01:28 AM |
Question about polishes | jls | Restoration | 0 | April 16th 04 03:00 PM |
