Many years ago I attended at talk on gelcoat maintenance by Mr. Schneider
(the "S" in LS) He clearly stated that it does not matter at all if polish used on glider surfaces contain silicone. The reason: exactly what Bob also notes, no professional repairs can be done unless the surface is ground way beyond the depth to which silicone can penetrate. I guess he should know. I have since then used silicone based polishes on my gliders, and I have also had them repaired (dont ask..) without any complaints from the shops Happy (silicone assisted) soaring, Lars Peder DG-600 EE, Denmark "Robert Gaines" wrote in message ... Easy to use and silicone free as far as I know. I would bet that repair shops clean, clean and grind all old areas back to degree that there will be no problems with any product used on a surface. There are so many contaminants floating around that a repair shop must go through a careful cleaning of the damaged area before any work is started. So, I doubt that it makes any difference as to the brand/type of polish used. Your opinion may vary. Jump in. Bob |
On Sep 28, 1:26*pm, "Lars Peder Hansen"
wrote: Many years ago I attended at talk on gelcoat maintenance by Mr. Schneider (the "S" in LS) He clearly stated that it does not matter at all if polish used on glider surfaces contain silicone. The reason: exactly what Bob also notes, no professional repairs can be done unless the surface is ground way beyond the depth to which silicone can penetrate. I guess he should know. I have since then used silicone based polishes on my gliders, and I have also had them repaired (dont ask..) without any complaints from the shops Happy (silicone assisted) soaring, Lars Peder DG-600 EE, Denmark "Robert Gaines" wrote in message ... Easy to use and silicone free as far as I know. I would bet that repair shops clean, clean and grind all old areas back to degree that there will be no problems with any product used on a surface. *There are so many contaminants floating around that a repair shop must go through a careful cleaning of the damaged area before any work is started. So, I doubt that it makes any difference as to the brand/type of polish used. Your opinion may vary. * Jump in. Bob- Hide quoted text - - Show quoted text - I'm by no means an expert (just a guy who does an ocaisional minor cosmetic repair or refinish now and again), but my mentors taught me to start every project with copious amounts of 3M Prep Solvent (or equivalent) to remove wax, oil, grease, etc. This usually meant two passes using new (clean) paper towels for each pass. Never had any problems with gelcoat adhesion... P3 |
Free Stuff, Free Offers and Rewards Program | Tri-Pacer[_3_] | Aviation Photos | 1 | February 5th 09 04:47 AM |
FREE TRIAL - Rent Adult DVDs Online, Delivered Free by Mail. | [email protected] | Piloting | 0 | March 1st 08 05:26 PM |
Free photo competition + free images and hosting | Jpgs.com.au | Piloting | 0 | January 7th 07 06:57 AM |
F18 Hornet Pics -Royalty Free Images and free image hosting - members wanted please | Jpgs.com.au | Home Built | 0 | January 7th 07 01:28 AM |
Question about polishes | jls | Restoration | 0 | April 16th 04 03:00 PM |
