On Sep 28, 4:01*pm, Dave Nadler wrote:
On Sep 28, 5:02*pm, JJ Sinclair wrote: I had a nasty land-out the other day, hit heavy sink while deep in the mountains east of Williams, Ca. I lost 2500 feet in no time and found myself below the mountain tops. Went to the 'Alternates' page on my trusty SN-10 only to find I wasn't within gliding distance of any listed alternates. I ran east following a canyon that lead to the totally unlandable terrain east of Red Bluff. Down, down ,down I sank maintaining about 1000 feet above the slope as I looked at nothing but trees! Finally I flew over a small pasture that looked to be landable. It had all my favorite attributes, short, bumpy, fenced, up hill with trees on the approach end, but at the time, it looked lovely. Popped the gear and turned down-wind at what looked to be about 800 feet, pulled full spoiler just before the trees and cleared them by a good 10 feet. Flared with half spoiler and rolled about 10 feet when I hit a mound that put the nose down hard (Genesis 2). I heard something pop and then we were flying again. Pulled full spoiler and touched down again and slid to a stop about 100 feet short of the fence. WOW, glad that's over! A few days later I checked my trace and found I was within easy gliding distance of an airport (Ruth, Ca) when I hit all that sink. Why didn't the SN-10 direct me to Ruth? Reading the manual, on page 21 it says; The 'A' attribute does not cause a point to appear in the list of landable fields on the alternates page! Only points marked with an 'L' for landable will be shown. Ruth was marked with an 'A' only. Checking the local data bases I find Montague, Air Sailing, Logan, Avenal, Hobbs and Parowan are all using *'A' without the 'L' for landable airports. Recommend everyone check to make sure the data base you are using with the SN-10 has airports identified with an 'L' for landable attribure. Cheers, JJ PS;The pop I heard on landing was a shear pin that fails when heavy loads are placed on the nose wheel thereby preventing retraction loads from being applied to the main gear. An easy fix after I located the shear pin which is deep inside the nose wheel -well. The "L" attribute is normally set by default for airports in the databases I've seen - something funny is going on here. HOWEVER: "L" is separate from "A" because: - not all airports are landable, certainly not in larger-span gliders, and - other non-airport points in the DB can be landable. You do need to check any database you load - whether into an SN10, a PDA, or an electronic-picture-frame... There are often errors in "official" databases. Locally we have a listed airport that hasn't existed for a decade. Bad news if you final-glide to this one. Be careful out there, Best Regards, Dave "YO electric" Dave - Good luck trying to convince people this was a good decision. It just appears to be contrary to how others interpret the meaning of "L" and "A". This is not how I believe all Cambridge products have used an "L" and "A" attributes, certainly not the C302/303 and I think older Cambridge devices. With Cambridge effectively defining the standard for this why was if felt necessary to use the reverse interpretation that "A" does not imply "L"? But JJ - the waypoint file for Williams on the Soaring Turnpoint Exchange for the SN10 *does* have Ruth marked with an "L" attribute. So why did it not show up for you? If you have been hand-editing the file and removing the "L" or not working with the Turnpoint Exchange SN10 file as a starting point then ya kinda burnt yourself (even if the behavior is a bad design decision) This can be one "interesting" area of the Mendocinos where we can be flying in not over the mountains. Darryl |
![]() But JJ - the waypoint file for Williams on the Soaring Turnpoint Exchange for the SN10 *does* have Ruth marked with an "L" attribute. So why did it not show up for you? If you have been hand-editing the file and removing the "L" or not working with the Turnpoint Exchange SN10 file as a starting point then ya kinda burnt yourself (even if the behavior is a bad design decision) Yeah, I didn't like the Williams file, so I made up my own where an airport is given an 'A' designator. That tells me to be looking for a large complex as apposed to something with an 'L' which might be a duster strip that looks more like a road. All (most) of these files are based on Cambride where an A or L will do the same thing.............see my proposed new Williams file where every possible landing spot is given a big 'L'. Cheers, JJ |
Oops, I stand corrected the world-wide turnpoint exchange does show an
'L' for airports when downloading Ilec files. I was looking at my Cambridge file for the local turnpoints. So there is no problem if one uses the files from the turnpoint exchange, but keep this in mind when making your own files. Sorry, JJ |
![]() Thanks for the "heads up" JJ -- Hartley Falbaum USA "KF" "JJ Sinclair" wrote in message ... Oops, I stand corrected the world-wide turnpoint exchange does show an 'L' for airports when downloading Ilec files. I was looking at my Cambridge file for the local turnpoints. So there is no problem if one uses the files from the turnpoint exchange, but keep this in mind when making your own files. Sorry, JJ |
It just appears to be contrary to how others interpret the meaning of "L" and "A". This is not how I believe all Cambridge products have used an "L" and "A" attributes, certainly not the C302/303 and I think older Cambridge devices. With Cambridge effectively defining the standard for this why was if felt necessary to use the reverse interpretation that "A" does not imply "L"? What makes you think Cambridge is defining the standard? I find the SN10 format easy and simple to use. As far as using the A or L to figure out what kind of airport/landing area the waypoint is - all you have to do is hit the help button and call up the waypoint description - then you get all the data about it, including runway length, width, freqs, etc! Take a look at the data contained in the CAI format compared to the NDB format, and you will see the advantage of the SN10s format. Kirk 66 Happy SN10 user - who wouldn't use a Cambridge to fill an empty hole in my panel! |
On Sep 29, 10:49*am, "
wrote: Dave - Good luck trying to convince people this was a good decision. It just appears to be contrary to how others interpret the meaning of "L" and "A". This is not how I believe all Cambridge products have used an "L" and "A" attributes, certainly not the C302/303 and I think older Cambridge devices. With Cambridge effectively defining the standard for this why was if felt necessary to use the reverse interpretation that "A" does not imply "L"? What makes you think Cambridge is defining the standard? *I find the SN10 format easy and simple to use. *As far as using the A or L to figure out what kind of airport/landing area the waypoint is - all you have to do is hit the help button and call up the waypoint description - then you get all the data about it, including runway length, width, freqs, etc! *Take a look at the data contained in the CAI format compared to the NDB format, and you will see the advantage of the SN10s format. Kirk 66 Happy SN10 user - who wouldn't use a Cambridge to fill an empty hole in my panel! It has nothing to do with whether you like one instrument over another. Cambridge was here first, and they provided a data format for their instrument which have widely been used by others. Dave Ellis et al. got the whole IGC recorder business started, they proved (in World level contests) that it was workable, etc. The Cambridge .DAT format consequently *is* the defacto standard, e.g. it is kind of intrinsic to Winscore in the USA. Cambridge have an "L" and an "A" waypoint (err "landpoint") attribute with specific meaning. To change that was not a good choice, at least use a different letter code to avoid the obvious confusion. While the soaring turnpoint exchange does a good job hiding differences, this is just the kind of incompatibility that will bite sooner or later. Darryl |
JJ,
I am so happy things worked out in the end for you. As a low time pilot I am grateful for the uneventful reminder that things can go wrong in a big hurry no matter how many hours you have logged. Although I may raise my personal goals for 2010, my personal risk margins/limits shall stand a bit longer. Thanks for sharing your experience. It helps. Matt Herron Jr. |
On Sep 29, 11:53*pm, Matt wrote:
JJ, I am so happy things worked out in the end for you. *As a low time pilot I am grateful for the uneventful reminder that things can go wrong in a big hurry no matter how many hours you have logged. Although I may raise my personal goals for 2010, my personal risk margins/limits shall stand a bit longer. *Thanks for sharing your experience. *It helps. Matt Herron Jr. Thanks Matt, I learned a valuable lesson that day, DON'T BE COMPLACENT. It was a good day with Cu's and I was just having fun, not paying attention to exactly where I was and what my options were. This is a beautiful sport, but it can bite you. Constant vigilance is the name of the game. See you under the next Cu, JJ |
On Sep 29, 2:59*pm, Darryl Ramm wrote:
On Sep 29, 10:49*am, " wrote: Dave - Good luck trying to convince people this was a good decision. It just appears to be contrary to how others interpret the meaning of "L" and "A". This is not how I believe all Cambridge products have used an "L" and "A" attributes, certainly not the C302/303 and I think older Cambridge devices. With Cambridge effectively defining the standard for this why was if felt necessary to use the reverse interpretation that "A" does not imply "L"? What makes you think Cambridge is defining the standard? *I find the SN10 format easy and simple to use. *As far as using the A or L to figure out what kind of airport/landing area the waypoint is - all you have to do is hit the help button and call up the waypoint description - then you get all the data about it, including runway length, width, freqs, etc! *Take a look at the data contained in the CAI format compared to the NDB format, and you will see the advantage of the SN10s format. Kirk 66 Happy SN10 user - who wouldn't use a Cambridge to fill an empty hole in my panel! It has nothing to do with whether you like one instrument over another. Cambridge was here first, and they provided a data format for their instrument which have widely been used by others. *Dave Ellis et al. got the whole IGC recorder business started, they proved (in World level contests) that it was workable, etc. The Cambridge .DAT format consequently *is* the defacto standard, e.g. it is kind of intrinsic to Winscore in the USA. Cambridge have an "L" and an "A" waypoint (err "landpoint") attribute with specific meaning. To change that was not a good choice, at least use a different letter code to avoid the obvious confusion. While the soaring turnpoint exchange does a good job hiding differences, this is just the kind of incompatibility that will bite sooner or later. Darryl- Hide quoted text - - Show quoted text - First doesn't necessarily mean best, just as the best solution isn't always the one that ends up becoming the standard - (beta max, anyone - or PC vs Mac?). The real solution would be to have an IGC-defined format for turnpoints that would be universally compatible with all FRs and glide computers - but barring that, one has to understand their equipment, and GIGO is always a possibility! Meanwhile, Leibacher's Soaring Turnpoint Exchange does a wonderful job of managing all the various turpoint formats. But let's face it - it really boils down to taking the time to make sure that your data is correct - an essential part of preflight planning, just like checking the weather and having a current sectional in the cockpit! Cheers! Kirk 66 (Ok, I admit I do kinda like the 302 vario...) |
Don't get me wrong, I love my SN-10. I have flown Dave's stuff going
way back to the B-100. I was just surprised to learn that airports aren't considered landable! ;) JJ |
GA User fees | Jose | Piloting | 48 | December 24th 05 02:12 AM |
User Charges | Chris | Piloting | 3 | October 8th 05 11:13 PM |
ATC User Fees | Larry Dighera | Piloting | 80 | May 12th 05 07:20 AM |
User Fees | Dude | Owning | 36 | March 19th 05 05:57 PM |
New Lak-12 user group | Chris Davison | Soaring | 0 | January 16th 05 05:55 PM |
