Cobra Trailer Replacement Wheel
Old September 27th 09, 03:22 AM posted to rec.aviation.soaring
Chip Bearden
Default Cobra Trailer Replacement Wheel
Finally did it. Rolled up the rim on my 1992 Cobra when the tire
failed catastrophically on the way home from New Castle today. I know
some have installed aftermarket wheels on their Cobras. Anyone have
the specs for interchange?: bolt circle/pilot diameter/offset. These
are the 13" rims installed on older Cobras. Thanks.
Chip Bearden
ASW 24 "JB"
USA
Old September 29th 09, 03:40 PM posted to rec.aviation.soaring
mattm[_2_]
Chip Bearden
ASW 24 "JB"
USA
I had the same thing happen on the Solo trailer on the way to Perry
a couple of years ago. I found an equivalent wheel at Tractor Supply,
I think it was. However, I wouldn't doubt that Cobra uses something
different. The best approach is to take the old rim around to various
tire places and see what they say.
-- Matt
Old September 29th 09, 04:41 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
Should be able to measure from your spare, Eh?
Hartley Falbaum
"mattm" wrote in message
Chip Bearden
ASW 24 "JB"
USA
-- Matt
Old September 29th 09, 06:09 PM posted to rec.aviation.soaring
Hartley Falbaum
Chip Bearden
ASW 24 "JB"
USA
a couple of years ago. *I found an equivalent wheel at Tractor Supply,
I think it was. *However, I wouldn't doubt that Cobra uses something
different. *The best approach is to take the old rim around to various
-- Matt
Trailer not local- eh!
UH
Old September 29th 09, 08:35 PM posted to rec.aviation.soaring
Chip Bearden[_2_]
On Sep 29, 2:30*pm, Nyal Williams wrote:
Had oughta carry TWO spares, doncha know? *If you lose a wheel or tire and
mount the spare, wouldn't it be foolish to continue on without a
spare??????????
Yeah, that's why I carry backpack AND chestpack parachutes. I mean,
what happens if I bail out successfully and then have to cut away the
main chute to avoid falling glider debris? That would ruin my whole
day, doncha know? Of course, it's a little crowded in the cockpit and
I can't see out as well and the glider's a bit noseheavy and the
second chute cost me over $1,000. But, wouldn't it be foolish to
compromise emergency preparedness??????????
Seriously, the glider and trailer are stashed at a gliderport 3+ hours
away. I've got the damaged wheel with me. Near as I can measure, the
specs a
13 x 4 1/2 wheel with a J flange manufactured 9-91 (the stampings read
K13S133 and FAD | 4 1/2 JX13H2 ). Offset measures approx. 29 mm. 4
on 100 bolt circle. 57mm centerbore. I've got a list of vehicles with
the same bolt circle pattern and centerbore. The only catch is that
the offsets are somewhat higher and because I don't have access to the
trailer, I'm hesitant to order a new wheel (or two) because I don't
know how much clearance I'll have between the trailer wall and tire.
UH generously offered a spare spare until I can replace mine.
Actually, because my spare is damaged, that would technically only
bring me back up to the single spare level. Guess I'll have to live
dangerously for the one-week contest coming up.
Chip Bearden
ASW 24 "JB"
USA
WTB: Cobra Trailer for LS-4 [email protected] Soaring 0 July 31st 08 05:04 PM
Replacement for a Cobra Tongue [email protected] Soaring 7 May 20th 08 09:25 PM
Replacement nose wheel pant for 1971 172 [email protected] Owning 1 May 9th 07 11:23 PM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 03:51 AM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 02:06 PM
