Wanted Nimbus2/ASW17 drogue chute.
Old September 29th 09, 06:35 PM posted to rec.aviation.soaring
Default Wanted Nimbus2/ASW17 drogue chute.
Need the Ribbon chute for an ASW17 or Nimbus 2.
Anyone got one in their hanger?
Cheers
Al
Old September 29th 09, 06:51 PM posted to rec.aviation.soaring
Berry[_2_]
In article
Cheers
Al
Is that the same chute as used on a 301 Libelle? I gave a spare chute to
Burt Compton once upon a time. Maybe he still has it.
Old September 30th 09, 12:24 AM posted to rec.aviation.soaring
Borderfort
I am also looking for one of these- I have an ASW-17; I have one drag
chute, and it's in good shape, but things happen, and I would like to
have a spare.
I recently wrote both the manufacturer (Walter Kostelezky GmbH,
Weingarten, Germany www.kostelezky.de) and Schleicher asking about
the availability and price of a replacement.
Both said the chutes are theoretically still available, but they would
prefer to make a small production run (to justify setting up the
tooling, probably), there would be about a 6-8 month lead time, and
the cost would be around 1300 Euro + shipping.
The ASW-17 uses the model BS1600 (Baenderschirm, 1.6 Meter, I'm
guessing). I've seen a BS1200 mentioned somewhere, but I don't know
which glider uses which.
The thing is beautiful- a real piece of art. Each ribbon is a great
circle, continuous to the opposite side. Half go to the left at the
edge and half to the right, so it's a crisscross pattern. Each ribbon
is ~ 1.5 inches wide, so at the apex vent, they overlap to make the
upper 1/2 of the canopy solid. At the edge, each pair of ribbons is
sewn to a shroud line. Every six of the shrouds is attached to a
catenary, which has a double shroud at each end. There are 36 of the
upper shrouds, and 6 of the long double shrouds. (This seems perfectly
clear to me, but I know it's not if you aren't looking at one. I'll
attach a photo if I can figure out how. (This is my first post.)
I'm starting to look admiringly upon old umbrellas...
-Rob
On Sep 29, 12:51 pm, Berry wrote:
In article
i
Cheers
Al
Old September 30th 09, 02:30 PM posted to rec.aviation.soaring
Derek Copeland[_2_]
I had a Nimbus 2 with a tailchute. but hardly ever used it because it was a
pain to re-pack into its housing. Maybe a couple of times a year when
landing at the airfield to impress people and to give it an airing.
I was always frightened to use it for field landings as the glide angle
went from pretty flat to about 40 degrees nose down when you popped it
out, with little chance of picking up speed if you got slow. Bit of a one
shot device! If you had to dump it you stood a good chance of losing the
chute and the housing.
The Nimbus was fitted with the double paddle brake mod and with
sideslipping would approach as steeply as most other high performance
sailplanes. I would have taken the tailchute out altogether if it hadn't
been an airworthiness requirement.
Derek Copeland
have a spare.
Weingarten, Germany ) and Schleicher asking about
-Rob
In article
i
Cheers
Al
to
Chute Maple1 Aviation Photos 0 August 3rd 07 04:50 AM
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue Mike Naval Aviation 26 July 11th 06 11:38 PM
Looking for ASW17 photo's Paul T Soaring 0 January 13th 06 12:23 AM
BRS chute Rich S. Home Built 6 May 30th 04 05:21 AM
Aerotow rope drogue chute? John Galloway Soaring 18 December 11th 03 05:37 AM
