![]() "Ed Rasimus" wrote in message news ![]() On Sun, 11 Jan 2004 06:05:28 -0600, "John Carrier" wrote: If they extend when airpressure is reduced as airspeed slows, then it would be redundant to add "also when a certain AOA is achieved" because that is the inevitable, inexorable, undeniable result of slowing. Just musing here Ed; :-)))))) I might be missing something in what you're saying about slat extension Ed, but FWIW, although it's true that dynamic pressure will bring out an aerodynamic LE slat as airspeed is reduced and angle of attack is increased as the result of that slowing, the only common denominator that SHOULD be used for an aerodynamic slat extension parameter is aoa, not airspeed! You can pull 12 units in an A4 and get a slat extension at ANY airspeed!! Using airspeed as the single parameter seems to me to be like using airspeed as a stall parameter instead of aoa. (Airspeed works for stall at a specific GW for a 1g stall, but goes to hell when you start pulling g!! The alpha units or degrees aoa for CLmax producing that stall however, remain the same. The same thing goes for an aerodynamic slat extension. You can extend slats in an A4 by reducing the airspeed all right, but ONLY when you reach 12 units aoa which works for an airspeed explanation at 1g level flight decel. BUT!!!! You can ALSO extend the same slats at much higher airspeeds by accelerating the airplane to 12 units. The airspeed for each extension scenario will be quite different, but the same 12 units still apply! AOA is the right parameter for aerodynamic slat extension, and what's used in the test community. I have to admit though, I can't for the life of me remember however how the Natops for the A4 presented this information :-))) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
On Sun, 11 Jan 2004 23:36:55 GMT, "Dudley Henriques"
wrote: "Ed Rasimus" wrote in message news ![]() On Sun, 11 Jan 2004 06:05:28 -0600, "John Carrier" wrote: If they extend when airpressure is reduced as airspeed slows, then it would be redundant to add "also when a certain AOA is achieved" because that is the inevitable, inexorable, undeniable result of slowing. Just musing here Ed; :-)))))) I might be missing something in what you're saying about slat extension Ed, but FWIW, although it's true that dynamic pressure will bring out an aerodynamic LE slat as airspeed is reduced and angle of attack is increased as the result of that slowing, the only common denominator that SHOULD be used for an aerodynamic slat extension parameter is aoa, not airspeed! You are correct. It's AOA, not specifically lower airspeed. They can droop under acceleration when a design AOA is reached. I got so wrapped up in trying to be all-encompassing while not grabbing the tar baby that I mis-spoke. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
![]() "Ed Rasimus" wrote in message ... On Sun, 11 Jan 2004 23:36:55 GMT, "Dudley Henriques" wrote: "Ed Rasimus" wrote in message news ![]() On Sun, 11 Jan 2004 06:05:28 -0600, "John Carrier" wrote: If they extend when airpressure is reduced as airspeed slows, then it would be redundant to add "also when a certain AOA is achieved" because that is the inevitable, inexorable, undeniable result of slowing. Just musing here Ed; :-)))))) I might be missing something in what you're saying about slat extension Ed, but FWIW, although it's true that dynamic pressure will bring out an aerodynamic LE slat as airspeed is reduced and angle of attack is increased as the result of that slowing, the only common denominator that SHOULD be used for an aerodynamic slat extension parameter is aoa, not airspeed! You are correct. It's AOA, not specifically lower airspeed. They can droop under acceleration when a design AOA is reached. I got so wrapped up in trying to be all-encompassing while not grabbing the tar baby that I mis-spoke. I know the feeling. That ole' tar baby is one sticky character all right! If you and Carrier ever manage to talk him into the back seat of a T38 for just one flight......just ONE!!!.....I'll buy you both a case of Scotch if you let me take him !! :-)) Dudley |
![]() "Dudley Henriques" wrote in message snip I know the feeling. That ole' tar baby is one sticky character all right! If you and Carrier ever manage to talk him into the back seat of a T38 for just one flight......just ONE!!!.....I'll buy you both a case of Scotch if you let me take him !! :-)) Now that you mention it, we did have Servair begging us to help them interface new digital gyros to Houston's T-38Ns, but we rejected the work; as the CCB system is too much overhaed. we offered a Part 25 type change, but they did not understand. |
Ed Rasimus wrote:
You are correct. It's AOA, not specifically lower airspeed. They can droop under acceleration when a design AOA is reached. I got so wrapped up in trying to be all-encompassing while not grabbing the tar baby that I mis-spoke. Ed Rasimus A gain of several notches. -- -Gord. |
![]() "Gord Beaman" wrote in message ... Ed Rasimus wrote: You are correct. It's AOA, not specifically lower airspeed. They can droop under acceleration when a design AOA is reached. I got so wrapped up in trying to be all-encompassing while not grabbing the tar baby that I mis-spoke. Ed Rasimus A gain of several notches. And isn't it so much nicer to have a civil professional discussion? |
![]() "John Carrier" wrote in message ... Slats are typically UN-powered devices on the leading edge that extend simply by the reduced dynamic pressure against them as airspeed slows. Example would be the leading edge extensions of the F-86 and F-100. I wouldn't agree with "typically." Aero slats also extend when a certain AOA is achieved ... the A-4 slats would extend at approximately 12 units AOA (IIRC) and bringing them out symmetrically at higher airspeeds was not a sure thing. Grumman liked powered slats. Both the A-6 and F-14 had them. Unlike otherers ego driven operators here, when I corrected John Carrier WRT the areodynamics of the F-14, he just incorporated the new information into his explaination. I found that far more impressive than The B-52 discussion, where it took a dozen threads here and in the .sci groups to get Buff to relent. Then of course there is Weiss and one has to wonder how smart that boy is. |
FS - Propeller leading edge protective tape | Sammy | Home Built | 0 | July 6th 04 12:06 PM |
Leading edge protection search | Tim Hickey | Home Built | 0 | June 28th 04 02:45 AM |
A Bush C150? With Leading Edge Slats? | [email protected] | Home Built | 33 | May 27th 04 05:39 PM |
-7 wing leading edge 'glitch' ? | Charlie England | Home Built | 0 | March 7th 04 12:27 AM |
tail buffeting and leading edge fillets, strakes | Wallace Berry | Home Built | 1 | September 26th 03 10:48 PM |
