REPLACE GO-300 ENGINE WITH O-300 ENGINE IN CESSNA 175
Old October 13th 09, 12:39 AM posted to rec.aviation.owning
nucleus
Default REPLACE GO-300 ENGINE WITH O-300 ENGINE IN CESSNA 175
Has anyone here done this?
I am considering the acquisition of a C175a with a runout engine
and replacing the engine with an O-300 engine. Is there a kit for
doing this?
Does the engine mount have to be replaced? I am guessing
the airframe is just a C172 airframe. Am I wrong? Does the
cowling have to be replaced? I assume the prop has to be
replaced (I would not want to have the prop repitched; I
don't like the idea of cold-twisting prop-type aluminum).
It is my understanding that the GO-300 engine TBO is 1200
hours, because of its higher RPMs; is that correct?
Old October 13th 09, 02:10 AM posted to rec.aviation.owning
Chuck Charlton
In article
Cold-twisting is fine. Hot-twisting would be a problem.
Old October 13th 09, 04:53 AM posted to rec.aviation.owning
Mike Adams[_2_]
doing this?
I have heard of replacing the GO with a Lycoming O-360 or a Franklin, but I'm not sure about the O-300.
I'm pretty sure the cowling would have to be modified or replaced. The 175 has a hump on the upper
cowl with the prop hub/spinner aligned at a higher position due to the gearbox. That would have to
change with a different engine. You would need approval data, so you need to find a STC for the mod
you're interested in. There's lots of good information at the Cessna Pilots Association,
http://www.cessna.org. They may be able to help.
Mike
Old October 14th 09, 02:54 AM posted to rec.aviation.owning
Ęslop
"nucleus" wrote in message
doing this?
Or even better:
http://franklinengines.com/cessna.cfm
Old October 15th 09, 03:20 AM posted to rec.aviation.owning
John[_9_]
and replacing the engine with an O-300 engine. *Is there a kit for
doing this?
Does the engine mount have to be replaced? *I am guessing
the airframe is just a C172 airframe. *Am I wrong? *Does the
cowling have to be replaced? *I assume the prop has to be
The TBO of the GO 300 is probably defined by the reduction gearing
rather than the rated RPM.
Want to buy Cessna 182 with no engine [email protected] Aviation Marketplace 1 April 11th 08 04:49 AM
Need a Cessna 120 engine mount Jerry Aviation Marketplace 0 November 28th 04 02:16 AM
Help! rebuild or replace Stamo engine In Falke? Ian Walton Soaring 2 September 5th 04 07:02 AM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 04:44 PM
How much to replace cracked crankshaft in 1972 skyhawk O-320-E2D engine Dave Gribble Owning 2 February 4th 04 08:30 AM
