Alternative to welding aluminum frame of Komet?
Old October 23rd 09, 02:34 AM posted to rec.aviation.soaring
Capt. Geoffrey Thorpe
Default Alternative to welding aluminum frame of Komet?
"Bob Kuykendall" wrote in message
I'd use a bunch of MD43BS 1/8" Monel pop rivets. They have a good
service history when used in aluminum and to join aluminum and steel.
I've got loads of them, contact me via email.
Thanks, Bob K.
John Thorp (with no "e") recommended Monel pop rivets (From U.S. Shoe
manufacturing IIRC) for assembling the T-18 as an alternate to the aluminum
AN rivets.
Geoff
Old October 23rd 09, 10:30 PM posted to rec.aviation.soaring
Bruno
On Oct 22, 7:34*pm, "Capt. Geoffrey Thorpe" The Sea Hawk @See My
Thanks, Bob K.
AN rivets.
Geoff
I apologize up front for asking for advice and than ignoring all of it
and just doing my own thing...Thanks for the replies and help.
That said, I ended up reading the specs for JB Weld Puddy and decided
that if I wasn't going to jump on top of it or leave it out under 3
feet of snow that 10,000 pounds of shear strength might be enough to
repair the broken weld. Here is a pic of the break befo
http://www.taylormadeawning.com/imag...ailer_weld.jpg
Here is the fix while curing:
http://www.taylormadeawning.com/imag...iler_weld2.jpg
I am going to trailer up to Logan, Ut this weekend to hopefully fly
the ridges and will report back if the patch job fix has any problems.
Thanks,
Bruno - B4
Old October 24th 09, 01:43 AM posted to rec.aviation.soaring
Eric Greenwell
Check it frequently, and let us know when it breaks (wink)
Old October 24th 09, 01:49 AM posted to rec.aviation.soaring
Darryl Ramm
Thanks, Bob K.
AN rivets.
Geoff
repair the broken weld. *Here is a pic of the break befohttp://www.taylormadeawning.com/imag...ailer_weld.jpg
Here is the fix while curing:http://www.taylormadeawning.com/imag...iler_weld2.jpg
Thanks,
Bruno - B4
Mmmm. I think a plate and rivets would be an awfully better idea.
You do realize you might risk being accused of missing a Y chromosome.
You passed up on an opportunity to buy a decent pop riveter, a new
cordless drill, to cut up you hand on some aluminum plate. Spill a
little blood. You could have tried to justify a TIG welder and welding
course...nope out came the JB Weld. Sigh.
Seriously there is no way this is going to be a more robsut repair
than a few aluminum triangles and pop rivets. How much is your time
worth dealing with a broken trailer when you really need it to work.
Darryl
Gas Welding Aid 1 - welding clamp 1.JPG (0/1) Stealth Pilot[_2_] Aviation Photos 1 March 26th 09 07:20 AM
gas welding aid 2 - welding clamp 2.JPG (1/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:58 AM
gas welding aid 2 - welding clamp 2.JPG (0/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:57 AM
aluminum rib, aluminum spar, holes drilled but screws broken off jls Home Built 13 January 3rd 07 08:06 AM
Aluminum welding Ernest Christley Home Built 5 April 24th 06 11:47 AM
