Barry,
We had the same experience with an L-13 last winter. Our solution was as you suggested, grind of the swage fittings. Wayne "tomcatvf51" wrote in message ... Our club is repainting/recovering the ailerons, wings and horizontal tail of our 1999 Blanik L23. Our supervising A&P and I are stymied in the disassembly of the horizontal tail. The trim tab cable runs from a rocker arm near the forward horizontal tail attachement point through the stab and elevator to the trim tab. It appears that we will have to grind off the swage fitting to release the cable so we can separate the stab and elevator. Everything else on the ship comes apart easily, what are we missing. Suggestions? Thanks, - Barry -- tomcatvf51 |
On 24 Oct, 09:41, "Wayne Paul" wrote:
Barry, We had the same experience with an L-13 last winter. Our solution was as you suggested, grind of the swage fittings. Wayne "tomcatvf51" wrote in . .. Our club is repainting/recovering the ailerons, wings and horizontal tail of our 1999 Blanik L23. *Our supervising A&P and I are stymied in the disassembly of the horizontal tail. *The trim tab cable runs from a rocker arm near the forward horizontal tail attachement point through the stab and elevator to *the trim tab. *It appears that we will have to grind off the swage fitting to release the cable so we can separate the stab and elevator. *Everything else on the ship comes apart easily, what are we missing. *Suggestions? Thanks, - Barry -- tomcatvf51 I thought the two trim cables could be disconnected through the inspection ports where you adjust the tension on each cable so the trim tabs are aligned. |
We just did this work on our 92 L-23. On our Blanik the cable was
attached to the trim tab control horn by an eyelet type of thing. The cable was wrapped around the outside of this eyelet and then joined to itself with a wrapped wire and soldier. We removed the soldier and the wrapped wire and were then able to detach the trim tab. |
Blanik L23 AD | tomcatvf51 | Soaring | 0 | February 12th 09 12:52 PM |
Blanik L-13 AD | [email protected] | Soaring | 7 | February 3rd 08 08:01 AM |
Blanik L-23 | BDS[_2_] | Soaring | 7 | June 27th 07 03:35 PM |
Blanik L-13 | brien | Soaring | 0 | December 5th 04 02:00 PM |
Blanik L-23 | Duane Eisenbeiss | Soaring | 8 | April 27th 04 05:53 AM |
