jan olieslagers wrote:
schreef: The large ST35 and ST36 are the only continuous duty units rated at 14-16 ohms. All the smaller ones are 16-25 ohms. Isn't there a difference in resistance betwen the active state and the passive? I feel some people have determined coil resistance by measuring with a cheapo multimemer - this uses a small battery, the ensueing measurement will reflect the inactive state. Better would be to activate with a battery (or better still, a stable 12V reference) and measure the current. Yes there is a difference in resistance with temperature for most metals. But I certainly hope you couldn't spot the difference with any ease. This is not a filament whose resistance can double (or more) at operating temp. Brian W |
On Oct 29, 10:35 am, brian whatcott wrote:
jan olieslagers wrote: schreef: The large ST35 and ST36 are the only continuous duty units rated at 14-16 ohms. All the smaller ones are 16-25 ohms. Isn't there a difference in resistance betwen the active state and the passive? I feel some people have determined coil resistance by measuring with a cheapo multimemer - this uses a small battery, the ensueing measurement will reflect the inactive state. Better would be to activate with a battery (or better still, a stable 12V reference) and measure the current. Yes there is a difference in resistance with temperature for most metals. But I certainly hope you couldn't spot the difference with any ease. This is not a filament whose resistance can double (or more) at operating temp. Brian W And it isn't operating on AC, where inductive resistance would reduce the current flow. If the ohmmeter says 14 ohms, then it'll draw one amp at 14 volts. That might decrease a small amount as it gets hot, but not much. Dan |
rich wrote:
My homebuilt's master contactor is going bad. Sometimes when I turn it on it doesn't make connection. It's got 1700 hours on it, so I'd just as soon replace it. But the way the builder wired it, he's has positive power from the battery going through the master switch to the small terminal on the contactor. (cole-Hersey type) But the master contactors, such as Spruce sells, are set up to actuate with ground power going to the small terminal. They also have plastic around their mounting feet so their case doesn't make ground. A starter contactor would work perfectly with the way the plane is wired. I just wonder, are starter contactors made to withstand continous use, like a master contactor does? And how can one tell the difference in the two, they look identical? And if not, can the master/continuous duty type be made to work with postitive power to the small terminal? A thought. Your master switch has hot on one side, and a lead to the master contactor on the other. If you replaced the existing contactor with a Spruce type contactor, you would pull off the hot lead to the switch, and ground it. Doesn't sound too hard, unless you have other wires tagging on with the hot lead to the master switch. Brian W. |
One trick worth trying is to put a pretty good sized (say, 100 amps or so)
load across the contactor when in the closed position and then open the contactor. The arc thus formed will be enough to melt any oxidation on the contacts and you will be left with a fresh metal surface nearly as good as the original. Do NOT put the load across the line and then turn the contactor on. You have every chance of welding the contact surfaces together. Jim "rich" wrote in message ... My homebuilt's master contactor is going bad. Sometimes when I turn it on it doesn't make connection. It's got 1700 hours on it, so I'd just as soon replace it. But the way the builder wired it, he's has positive power from the battery going through the master switch to the small terminal on the contactor. (cole-Hersey type) But the master contactors, such as Spruce sells, are set up to actuate with ground power going to the small terminal. They also have plastic around their mounting feet so their case doesn't make ground. A starter contactor would work perfectly with the way the plane is wired. I just wonder, are starter contactors made to withstand continous use, like a master contactor does? And how can one tell the difference in the two, they look identical? And if not, can the master/continuous duty type be made to work with postitive power to the small terminal? |
RST Engineering - JIm wrote:
One trick worth trying is to put a pretty good sized (say, 100 amps or so) load across the contactor when in the closed position and then open the contactor. The arc thus formed will be enough to melt any oxidation on the contacts and you will be left with a fresh metal surface nearly as good as the original. Do NOT put the load across the line and then turn the contactor on. You have every chance of welding the contact surfaces together. Jim If it's not a sealed unit one can use contact a burnisher. Dan, U.S. Air Force, retired |
On Sat, 31 Oct 2009 18:38:56 -0500, Dan wrote:
RST Engineering - JIm wrote: One trick worth trying is to put a pretty good sized (say, 100 amps or so) load across the contactor when in the closed position and then open the contactor. The arc thus formed will be enough to melt any oxidation on the contacts and you will be left with a fresh metal surface nearly as good as the original. Do NOT put the load across the line and then turn the contactor on. You have every chance of welding the contact surfaces together. Jim If it's not a sealed unit one can use contact a burnisher. Dan, U.S. Air Force, retired But the VAST majority are sealed. |
... My homebuilt's master contactor is going bad. Sometimes when I turn it on it doesn't make connection. It's got 1700 hours on it, so I'd just as soon replace it. But the way the builder wired it, he's has positive power from the battery going through the master switch to the small terminal on the contactor. (cole-Hersey type) But the master contactors, such as Spruce sells, are set up to actuate with ground power going to the small terminal. They also have plastic around their mounting feet so their case doesn't make ground. A starter contactor would work perfectly with the way the plane is wired. I just wonder, are starter contactors made to withstand continous use, like a master contactor does? And how can one tell the difference in the two, they look identical? And if not, can the master/continuous duty type be made to work with postitive power to the small terminal? I've been reading this thread with modest interest and a little amusement. At the moment, I am not entirely sure why a "typical" homebuilt would use a master contactor and I suggest that you take a look at what the professional designers may have done. For example, to the best of my recollection, the Cessna 150 and 152 and also the Piper Tomahawk had starter contactors (a/k/a solenoids) and a had master breakers that also functioned as switches; but did not have master contactors--and I really have difficulty understanding why a well designed aircraft in that size and weight range would need one. I suggest that you determine whether your battery is located in an unusual way and then ask a mechanic what was used in reasonably similar factory built aircraft. For example: I would certainly expect a master contactor in a Piper Cheyene; but I would not extpect to find one in a Cherokee 140. Of course, as always, YMMV. Peter |
On Nov 1, 7:37 am, "Peter Dohm" wrote:
At the moment, I am not entirely sure why a "typical" homebuilt would use a master contactor and I suggest that you take a look at what the professional designers may have done. For example, to the best of my recollection, the Cessna 150 and 152 and also the Piper Tomahawk had starter contactors (a/k/a solenoids) and a had master breakers that also functioned as switches; but did not have master contactors--and I really have difficulty understanding why a well designed aircraft in that size and weight range would need one. I suggest that you determine whether your battery is located in an unusual way and then ask a mechanic what was used in reasonably similar factory built aircraft. For example: I would certainly expect a master contactor in a Piper Cheyene; but I would not extpect to find one in a Cherokee 140. It's there so the battery can be totally isolated from the electrical system in case of electrical fire or forced landing. The Cessna 150, I can tell you, did have a master contactor, as did all the 172s including the nice new 172S G1000 one in our fleet. Every airplane I ever worked on has had a master contactor except for my 1946 Auster, which had a huge toggle switch on the panel, and my Jodel, whose tiny battery powers a handheld radio. You DO want to be able to cut off all electrical power in flight if it becomes necessary, because getting out and running is hardly an option when the smoke and flames start up, or if a forced landing is going to tear up metal and start shorting stuff and making sparks around spilled fuel. At the same time, I don't understand why we don't have a solid-state device for this application by now. Dan |
Master cylinders | [email protected] | Home Built | 25 | July 29th 08 02:08 AM |
Battery Contactor Diode? | Skrud | Home Built | 25 | September 11th 06 06:17 PM |
PA28-180 Power Contactor Relay source? | Mike Noel | Owning | 5 | August 10th 05 04:40 AM |
Master Switch | Lakeview Bill | Piloting | 23 | July 20th 05 01:46 AM |
RC Plane Master | Steve | Simulators | 0 | December 20th 03 02:40 PM |
