PA28-180 Power Contactor Relay source?
Old August 1st 05, 02:42 AM
Mike Noel
Default PA28-180 Power Contactor Relay source?
I've been trying to find this part on-line without much luck. It is listed
in the Piper parts manual as 455151 but also referred to as 6041H105A. It's
the relay mounted along side the battery box. My Archer has been cranking
rather slowly even after replacing a dying G-35 with a new RG-35AXC battery.
This relay was almost too hot to touch 5 minutes after starting and then
shutting down the engine.
Best Regards,
Mike Noel
Old August 1st 05, 12:58 PM
Mike Noel wrote:
: I've been trying to find this part on-line without much luck. It is listed
: in the Piper parts manual as 455151 but also referred to as 6041H105A. It's
: the relay mounted along side the battery box. My Archer has been cranking
: rather slowly even after replacing a dying G-35 with a new RG-35AXC battery.
: This relay was almost too hot to touch 5 minutes after starting and then
: shutting down the engine.
Definately get the part called for in the parts manual (or its equivalent).
Those type of solenoid relays come in (at least) two varieties: intermittent duty
(e.g. for engaging starters), and continuous duty (what you need). If it gets that
hot, it's possible someone replaced it with an "AutoZone Special" intermittent duty
solenoid.
-Cory
* Cory Papenfuss *
Old August 1st 05, 03:10 PM
Paul kgyy
Check with the recyclers - Wentworth, White Industries, Central
Airmotive.
Old August 1st 05, 03:57 PM
Michelle P
Cessna, Maule, piper all use the same relay. Mine is a cessna part that
has the same part number as my original.
Check out Cessnaparts.com
get the number off the part enter in the parts search. if that does not
work there is always tech support.
Michelle
Best Regards,
Mike Noel
Old August 3rd 05, 12:18 AM
The number you gave, 6041H105A is a Cutler-Hammer number.
The planes all use variants of this. The differences are things
like the diameter of the stud bolts.
BTW, as these age the phenolic tends to shrink. The stack
of nuts gets loose.
I've had some luck just loosening the nuts and re-torquing them
from the bottom of the stack up. On the stud bolts that is.
Bill Hale
Old August 10th 05, 04:40 AM
Ray Andraka
Best Regards,
Mike Noel
You can get it from a piper dealer, but it isn't cheap. Last I looked,
it was running about $340, and that was 2 years ago.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Are you gliding when you touch down? John Doe Piloting 29 January 23rd 05 12:52 AM
IO 360 Power down (danger, long, rambling post!) Jim Harper Home Built 24 July 11th 04 12:04 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 03:29 PM
