On Oct 14, 9:54*am, Jim Logajan wrote:
Oliver Arend wrote: I'm looking into educating myself about metal aircraft construction by getting a set of plans for a low-wing airplane. The idea is then to either design my own plane (no, looking at the plans is not the full education, there's also a master's degree in aerospace engineering, I'm more looking for detail solutions so I won't have to come up with everything by myself) or just build the one I got the plans for. [...] So my question is, who has experience with these plans(-built aircraft) and can recommend a set? You listed a lot of good options that I elided - just to make it harder: A couple years back, I ordered the preview plans for Vans RV-9A for $55. They are still that price (RV-3 is $45.) As far as I know, the only difference between Van's Aircraft preview plans and the final set is that the preview plan drawings are reduced in size by half (I think) - but they are all there and quite readable. Also, you get the complete build instructions plus other material. It's a fabulous deal education-wise even if you design or build something else. A correction is needed on the Van's plans. While the earlier kits can be built from scratch using the plans, the newer models are intended to be sold only as kits. The plans/manual is basically an assembly manual. Parts that must be fabricated by the builder have full construction details, but parts supplied in the kit ready to assemble are not detailed on the plans with enough info to scratch build the parts. Having said that, it's unlikely that you will find a better plane to own & fly once it's built. Charlie (somewhat biased; flying a -4 & building a -7) |
Low wing landing, high wing taking off...oops | [email protected] | Piloting | 1 | May 16th 08 09:41 PM |
Soft field landings - low wing vs high wing aircraft | Justin Gombos | Piloting | 19 | May 23rd 07 05:21 AM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 11:10 AM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
