Cindy,
Any thoughts on the subject procedure for those of us who fly the PIK-20B, 1-35 or HP-14? Wayne "CindyB" wrote in message ... On Nov 12, 6:58 am, Burt Compton - Marfa wrote: Tom Knauff says the rare double release failure has occurred. On your checkride, it is required -- sort of. Burt: I'll invite you for some refresher training . . . (gentle smile) and since it is non-fly season in some parts of the world, and folks are still seeking their flight training from a monitor, I will add details that I have written before, and do not occur in any published soaring text of which I am aware. I am aware of several single release failures on gliders, both SGS and Tost mechanisms, for many causes. I am aware of a couple failures to release on tugs. Why do a few of us offer this training? To improve understanding of many concepts in towed flight, descents, maneuvers, respect for the tugs contribution/training, proficiency in signals/conversations, broadening skills and confidence, enthralling power pilot observers. We also recall this if for TRAINING, not for real, and we supervisors (hopefully) recall we can abort the exercise by pulling the release, should the learner need more ground school or proficiency, if it gets messy or we are uncomfortable about our ability to remain assured of a safe outcome. I recommend only one new person/greenhorn being introduced into the 3-person procedure at a time. A two seater tug is nice for tow pilot training also. (Love them Cessnas.) Some important points. The wake (prop wash / wing wash) of the towplane in descent will trail behind almost level. The glider should be under this wake during the descent. This is nice, less unsettling for the "learner". But it is the second step. Airbrakes should be kept unlocked and in hand, then deployed as required for drag. The towrope must be kept tight. After you tell the tug you cannot release, and he brought you home.... adjacent the airfield, and he discovered he couldn't release you, then he tells you he cannot release. Yes, there is a US standard signal for this. After the tug told you he couldn't release, it is the glider's option to break the line or request a descent on tow. How will the tug know which you prefer? With NORDO, you make the descent configuration, 75% spoilers open. With RDO, you still make the descent configuration, 75% spoilers open. This will work in anything from 2-33s to Duo Discus. No one has offered me a Schempp 3D or similar, but I would wager the tow price it works just fine. But, I do prefer my tug driver has training or supervision also. The glider pilot should not be in a hurry to touchdown, but definitely touch down just a bit before the towplane. Glider touch down while the towplane is still higher than 1 meter may slow the towplane to near stall. THE most common misconception, perpetrated by a single line in a couple training manuals is the thought that the gliders 'need' to touch first. A glider typically has a slower stall speed than a tug, more so in ground effect. Whoever touches first is irrelevant, as long as neither does anything very quickly. Personally, I have had more gliderpilots screw up rushing the touch, into a PIO, than had trouble with the tug who is very reluctant to have a glider rear-end him. If the glider touches first , only use enough brake to keep the line taut. The tug made his approach carrying power to maintain a minimal sink rate on descent, like less than 300-400 fpm. The tug may be fine tuning his graceful touch while easing the power off very gently. (Long runways are appreciated for this exercise). The tug should check aft to confirm the glider is landed/rolling before continuing easing power off, allowing the glider to keep the line taut. Towpilots must understand the mission, particularly pattern shape, power settings, descent rate and the options for go-around on tow. I've done it many times at several sites after receiving excellent instruction from Cindy at Caracole in California City many years ago. Training is the key for all glider pilots and towpilots for this maneuver. And there is value in refresher-recurrent training for anything rarely reviewed. Should we ask FAA to eliminate this requirement? NO, we don't need the FAA digging into our PTS. AMEN. Do I require this maneuver at Marfa, Texas on your Practical Test (checkride)? Awwww - you hedged! Come visit! I'll show you a good time, and help you toward your goals. Sure he will. And so will we. And we can show you how to break your legal limit tow rope without scaring you, your glider A&P, or the tuggie. Cindy B www.caracolesoaring.com |
![]() Well - try it in a spoiler equipped, dual flown ship first. Learn the procedures. Make sure your tuggie knows the procedures. This was a discussion about training, not experimentation. Why should LOT be any different using a different drag/descent tool? Flaps may be 'more' draggy, but you are already used to the quicker decel and settle-on for landing. The tug driver will be the one doing the compensating, not you very much. Just be smoooooth in the configuration change for descent, and anticipate the pitch/trim changes necessary to remain steady in towing position. And you had best also be proficient with slipping with flaps, as the supplemental drag tool, rather than changing configurations/lift/drag abruptly. And if you are not happy with the idea, learn to break a rope, safely, calmly, under supervision - please not 'self-taught.' Cindy On Nov 13, 6:18*am, "Wayne Paul" wrote: Cindy, Any thoughts on the subject procedure for those of us who fly the PIK-20B, 1-35 or HP-14? Wayne "CindyB" wrote in ... SNIPPED Why do a few of us offer this training? To improve understanding of many concepts in towed flight, descents, maneuvers, respect for the tugs contribution/training, proficiency in signals/conversations, broadening skills and confidence, enthralling power pilot observers. We also recall this if for TRAINING, not for real, and we supervisors (hopefully) recall we can abort the exercise by pulling the release, *should the learner need more ground school or proficiency, *if it gets messy or we are uncomfortable about our ability to remain assured of a safe outcome. *I recommend only one new person/greenhorn SNIPPED off |
Mayocraft P26 Peashooter Flight 2 Landing on Youtube | Niccolo | Aviation Photos | 0 | April 15th 08 06:40 AM |
OLC and YouTube | Paul Cordell | Soaring | 0 | January 4th 08 07:59 PM |
OLC - 2008 - DO NOT USE 2007 URL LINK, or current ssa.org link | [email protected] | Soaring | 1 | October 25th 07 05:37 PM |
Another YouTube video | [email protected] | Soaring | 38 | August 20th 07 03:57 PM |
holy smokes YouTube landing | [email protected] | Soaring | 36 | July 11th 07 08:18 PM |
