Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Dumb question maybe re Stall Turn
Old November 19th 09, 12:59 PM posted to rec.aviation.aerobatics
Jeremy
Default Dumb question maybe re Stall Turn
That's not a stall turn, or a tail slide, that's the old gyro-hang
you're on about there. Both the stall turn and the tailslide could of
course be stopped just before the turn or the slide by doing the hang.
Eventually, and I mean eventually, the plane might start to spin, once
the torque had overcome the intertia, but as Orval says it depends on
the weight of the plane and the power output of the engine, which for
the gyro-hang is quite low (or you'd just climb). You could keep it up
for maybe a minute without too many problems.
Hope that answers your question!
On Nov 18, 6:06*pm, Surreyrider wrote:
Need someone to settle an argument. I do not fly, so your answers need
to be in laymans terms and hopefully put simply.
I've occasionally watched aerobatic displays and seen a maneouver
called a stall turn. *Now, I more or less understand how this works,
but there comes a point, just before the aircraft "turns around" where
it is momentarily stationary in space, pointing directly to the sky..
Impressive stuff. *Now, here's the crux: *My mate reckons the pilot
could hold the aircraft in this "head-up" attitude almost indefinately
as the prop is acting like a helicopter's rotor and it could
effectively hover in this attitude. *I, however, maintain that the
aircraft would begin to spin on it's axis if held in this attitude.for
more than a second or two.
Can anybody tell me who is correct?
Thanks all,
Roy
Dumb GPS Question William Bruce Piloting 14 November 27th 07 11:45 PM
Dumb Question JohnO Rotorcraft 11 December 24th 06 06:46 PM
Dumb Reg question John Gaquin Piloting 67 May 4th 05 04:54 AM
Calculating vertical time and distance in a stall turn (US Hammerhead) Dave Aerobatics 3 November 20th 03 10:48 AM
Harder to stall in a steep turn? Jim Soaring 19 July 30th 03 10:14 AM
