Alan Baker wrote:
In article , brian whatcott wrote: Stealth Pilot wrote: /snip/ it is the air below pushing you up that lifts the wing. Stealth Pilot In most circumstances, suction on the upper surface contributes about 2/3 rds of the lift, and pressure on the lower surface contributes about 1/3 rd. That's one reason which rib stitching for rag wings is a biggy. Brian W Ummmm... It sort of depends what you mean. If you mean that suction is actually providing an upward force, you're quite mistaken. If you mean that the difference in pressure between upper and lower surfaces is 2/3 the result of lower pressure on the upper surface, then you might be right. I don't know. Interesting comment: what would YOU call it when the fabric on the upper wing surface wants to pull away from the ribs? Brian W |
Alan Baker wrote: In article , brian whatcott wrote: Stealth Pilot wrote: /snip/ it is the air below pushing you up that lifts the wing. Stealth Pilot In most circumstances, suction on the upper surface contributes about 2/3 rds of the lift, and pressure on the lower surface contributes about 1/3 rd. That's one reason which rib stitching for rag wings is a biggy. Brian W Ummmm... It sort of depends what you mean. If you mean that suction is actually providing an upward force, you're quite mistaken. If you mean that the difference in pressure between upper and lower surfaces is 2/3 the result of lower pressure on the upper surface, then you might be right. I don't know. Interesting comment: what would YOU call it when the fabric on the upper wing surface wants to pull away from the ribs? Brian W It's the "wind" blowing through the bottom surface, inflating the wing like a balloon ![]() |
brian whatcott wrote: Alan Baker wrote: In article , brian whatcott wrote: Stealth Pilot wrote: /snip/ it is the air below pushing you up that lifts the wing. Stealth Pilot In most circumstances, suction on the upper surface contributes about 2/3 rds of the lift, and pressure on the lower surface contributes about 1/3 rd. That's one reason which rib stitching for rag wings is a biggy. Brian W Ummmm... It sort of depends what you mean. If you mean that suction is actually providing an upward force, you're quite mistaken. If you mean that the difference in pressure between upper and lower surfaces is 2/3 the result of lower pressure on the upper surface, then you might be right. I don't know. Interesting comment: what would YOU call it when the fabric on the upper wing surface wants to pull away from the ribs? Air pressure from inside the wing pushing up on it more than the air above is pushing down... -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
![]() "Alan Baker" wrote Air pressure from inside the wing pushing up on it more than the air above is pushing down... I hope you are pulling someone's leg, and that your are not that inept in the field of aerodynamics and physics. -- Jim in NC |
"Morgans" wrote: "Alan Baker" wrote Air pressure from inside the wing pushing up on it more than the air above is pushing down... I hope you are pulling someone's leg, and that your are not that inept in the field of aerodynamics and physics. No, I'm quite serious. The reduction in *pressure* on the upper surface of the wing cannot produce any force except downward. A perfect vacuum over the entire upper surface wouldn't produce any upward force, but simply *zero* force; allowing the upward force on the lower surface to act alone. Anyone who thinks that the pressure of a fluid on a surface can act in any direction but towards the surface is simply wrong. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
![]() "Alan Baker" wrote Anyone who thinks that the pressure of a fluid on a surface can act in any direction but towards the surface is simply wrong. I see. You are not lookng at the wing as a system, but taking an observation at one point only, without reguard to what is happening around it. Point made. -- Jim in NC |
Morgans wrote:
"Alan Baker" wrote Anyone who thinks that the pressure of a fluid on a surface can act in any direction but towards the surface is simply wrong. I see. You are not lookng at the wing as a system, but taking an observation at one point only, without reguard to what is happening around it. Point made. He looked inside the wing, at the entire upper surface, at the lower surface... that pretty much covers most of it. Air can't be in tension. |
Beryl wrote:
Air can't be in tension. If it had a stressful day it might become tense. Air can be under a lot of pressure at times, and work can cause it to get hot. Put under too much pressure, air can blow a gasket. That's why it's best to let air blow off steam after a hard day at work and maybe offer it a smoke with a gin and tonic to cool off: http://www.bobblum.com/Images/Humor%.../subgenius.jpg |
![]() "Beryl" wrote He looked inside the wing, at the entire upper surface, at the lower surface... that pretty much covers most of it. Air can't be in tension. Yes, but the person that observed that the pressure on the bottom was one third responsible (for lift) and the low pressure on top was responsible for two thirds of the lift is also correct, when you look at the wing as a whole system, even if those fractions are approximate. I think his view of individual points of observations are splitting toadstools. But that is my opinion, and like everyone, we all have but-holes and opinions. -- Jim in NC |
"Morgans" wrote: "Alan Baker" wrote Anyone who thinks that the pressure of a fluid on a surface can act in any direction but towards the surface is simply wrong. I see. You are not lookng at the wing as a system, but taking an observation at one point only, without reguard to what is happening around it. Point made. Nope. I'm making the point that the upper surface contributes absolutely *no* lifting force. None. Zero. In fact, it provides a downward force. Every time. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Pressure Distribution Charts | sisu1a | Soaring | 0 | September 21st 08 05:53 PM |
Soundwaves Boost Wing Lift | [email protected] | Home Built | 30 | September 5th 05 10:21 PM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 09:07 PM |
Alternator load distribution in a Baron | Viperdoc | Owning | 7 | December 9th 03 10:27 PM |
