visualisation of the lift distribution over a wing
Old November 30th 09, 07:02 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default visualisation of the lift distribution over a wing
Alan Baker wrote:
"Morgans" wrote:
"Alan Baker" wrote
Anyone who thinks that the pressure of a fluid on a surface can act in
any direction but towards the surface is simply wrong.
I see. You are not lookng at the wing as a system, but taking an
observation at one point only, without reguard to what is happening around
it.
Point made.
Nope.
I'm making the point that the upper surface contributes absolutely *no*
lifting force.
None.
Zero.
In fact, it provides a downward force. Every time.
Sorry, Alan, old boy, I find must disagree.
In actuality, BOTH surfaces are below ambient pressure.
('splain why?)
But without that reduction of the pressure across the top curve of the wing,
the pressure below it can't do much at all, can it?
Old November 30th 09, 12:48 PM posted to rec.aviation.homebuilt
Brian Whatcott
Alan Baker wrote:
Nope.
lifting force.
None.
Zero.
....and you are making the point that when you are breathing in, you are
not SUCKING air at all. It's atmospheric pressure on your chest that
inspires the air. Wow! Who would have guessed? :-)
Brian W
Old November 30th 09, 01:19 AM posted to rec.aviation.homebuilt
Brian Whatcott
Alan Baker wrote:
Interesting comment: what would YOU call it when the fabric on the upper
wing surface wants to pull away from the ribs?
Air pressure from inside the wing pushing up on it more than the air
above is pushing down...
Let me take a wild guess he you did physics for an uundergraduate
degree. Is that right?
Brian W
Old November 30th 09, 02:19 AM posted to rec.aviation.homebuilt
Steve Hix[_2_]
For a couple of seconds, perhaps.
Wings aren't typically hermetically sealed.
Brian W
Old November 30th 09, 03:19 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Brian W
I'll take Physics Majors for $500, Alex!
Old November 30th 09, 03:08 AM posted to rec.aviation.homebuilt
Alan Baker
Brian W
No. But it doesn't matter.
If the fabric is moving upward, it can only be because there is more
pressure on its bottom surface than there is on its top surface.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old November 30th 09, 03:20 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Brian W
I'm kind of curious about how that higher pressure got on the bottom
of that wing though...
Old November 30th 09, 06:39 AM posted to rec.aviation.homebuilt
Alan Baker
Brian W
If the curvature of the upper surface lowers the pressure, then even if
the pressure on the lower surface is just the ambient pressure, it will
be *higher* than the upper surface.
Alan Baker
Old November 30th 09, 04:38 AM posted to rec.aviation.homebuilt
Brian Whatcott
Brian W
It seems that you are uncomfortable with the entire concept of suction.
For example, how do you suppose suction cups work?
Or how about a suction pump that happens to be limited to a 30 ft lift?
Well duh, it's also atmospheric pressure that enables suction pumps and
suction cups etc., etc. Yes indeed , but it's an academic issue at
the junior high level, isn't it?
Brian W
Old November 30th 09, 05:48 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
upper wing surface wants to pull away from the ribs?
Brian W
Have you ever seen the top surface of a fabric covered wing?
The skin does not bulge upwards.
Not usually anyway.
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
