On Nov 30, 11:40*am, Mike Ash wrote:
In article , *george wrote: On Nov 29, 10:40*pm, a wrote: I would have expected the burble that causes the waves had to be within a couple of thousand feet of the ridge altitude, but you got rides to much higher than the mountains in WV -- ridge altitude plus what -- 5 or 6000 feet? Neat stuff. You get to play in what we could call 'fly through/over' conditions. *I guess wave height has also a lot to do with the ridge to valley distance on the upwind side. The best wave is what we call 'Secondary wave' which is downwind from the 'primary' wave. Its more powerful and a lot smoother and can be quite a distance from the 'primary' wave. The bit in between is where you don't want to be :-).. I may just be revealing my ignorance here (and if so, would be glad to have it corrected) but I thought the primary was generally the strongest. Wave tails off as it gets farther from the source, so each jump in tends to get you into stronger lift, with the best one being the very first one after the generator. Is it actually the case that the second one is stronger than the first, and THEN it begins to fall off? It's possible, I'm certainly no expert, but it doesn't match my fairly limited experience of wave flying. I can only relate my experience of wave, which, like yours, is limited to my own experiences. When I flew at Masterton the Hood wave could have up to 4 or 5 secondaries. A mate captaining a loaded Bristol Freighter actually managed to gain height just traversing the secondaries. The very interesting American pilot who died a few years back in the desert (Steve Fossett) was attempting to use secondaries in the South Island to do the ultimate Height gain. He even wore a pressurised suit. Always wondered what comes after a diamond height gain :-) |
In article
, george wrote: On Nov 30, 11:40*am, Mike Ash wrote: In article , *george wrote: On Nov 29, 10:40*pm, a wrote: I would have expected the burble that causes the waves had to be within a couple of thousand feet of the ridge altitude, but you got rides to much higher than the mountains in WV -- ridge altitude plus what -- 5 or 6000 feet? Neat stuff. You get to play in what we could call 'fly through/over' conditions. *I guess wave height has also a lot to do with the ridge to valley distance on the upwind side. The best wave is what we call 'Secondary wave' which is downwind from the 'primary' wave. Its more powerful and a lot smoother and can be quite a distance from the 'primary' wave. The bit in between is where you don't want to be :-).. I may just be revealing my ignorance here (and if so, would be glad to have it corrected) but I thought the primary was generally the strongest. Wave tails off as it gets farther from the source, so each jump in tends to get you into stronger lift, with the best one being the very first one after the generator. Is it actually the case that the second one is stronger than the first, and THEN it begins to fall off? It's possible, I'm certainly no expert, but it doesn't match my fairly limited experience of wave flying. I can only relate my experience of wave, which, like yours, is limited to my own experiences. When I flew at Masterton the Hood wave could have up to 4 or 5 secondaries. A mate captaining a loaded Bristol Freighter actually managed to gain height just traversing the secondaries. Yesterday I jumped forward four times, I think, and there were still several more to go before reaching the source. I would estimate that there were 10-15 in total, stretching back into West Virginia. Each time I jumped forward, though, it got stronger, and I thought that trend would continue all the way to the first one. I wish I could find a good archive of the satellite imagery. The wave was clearly visible, and pulling up the satellite picture on my phone just before takeoff was a huge help during the flight. The very interesting American pilot who died a few years back in the desert (Steve Fossett) was attempting to use secondaries in the South Island to do the ultimate Height gain. He even wore a pressurised suit. Always wondered what comes after a diamond height gain :-) Do you know of any articles that talk about him flying in the secondary wave there? Or, for that matter, any articles that talk about those flights at all... they're bound to be an interesting read. Fossett, along with Einar Enevoldson, also holds the current glider altitude record of 50,727ft, set in South America. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
On Nov 30, 7:21*pm, Mike Ash wrote:
Fossett, along with Einar Enevoldson, also holds the current glider altitude record of 50,727ft, set in South America. Yup. I knew that. :-) He saw some sort of interaction between the wave at Omarama and the jet stream producing cloud at a great height. It occured to him that there might be lift being produced. That's about all I can remember about it. Thanks for reposting your photo link |
Gldier Pilot Missing after High Altitude Flight | Paul Remde | Soaring | 2 | January 19th 09 03:12 AM |
High definition flight videos on vimeo. | Jim Logajan | Piloting | 2 | April 24th 08 06:55 AM |
Determining high point from flight recorder data | Sam Discusflyer | Soaring | 3 | October 19th 06 01:11 AM |
High Flight NOTAM | Kirk Stant | Military Aviation | 1 | September 10th 03 03:31 AM |
