Scott wrote: Alan Baker wrote: In article , Scott wrote: Alan Baker wrote: Observation can lead you astray: and that is clearly the case here if you actually think that air can *pull* on a surface. Why can't air PULL on a surface? Air is made up of molecules. Molecules have mass. Anything with mass can attract anything else with mass, can't it? Gravity? You're not serious. Anti-gravity in this case. If air can push something, why can't it pull something? Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. But there is no set of circumstances that can make the number of collisions be negative. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. But there is no set of circumstances that can make the number of collisions be negative. Pedantically speaking, outgassing would occur for a while that would create a force on your wing surface when it is exposed to a vacuum. Pedantically speaking, I don't see why those couldn't be called negative collisions. (Last worked on a fancy high-vaccum system back in college, wherein my lab mate and I attempted to replicate the Lamb-Retherford experiment.) |
Jim Logajan wrote: Alan Baker wrote: Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. But there is no set of circumstances that can make the number of collisions be negative. Pedantically speaking, outgassing would occur for a while that would create a force on your wing surface when it is exposed to a vacuum. Pedantically speaking, I don't see why those couldn't be called negative collisions. The force they'd create would be in the same direction as the force of regular collisions: toward the surface. If the outgassing molecules have momentum away from the surface then the surface must experience a change in momentum in the opposite direction. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. I don't see what a change in air density (such as taking the extreme case of a vacuum) has to do with lift. Unless you are claiming density change as a requirement? I believe lift can be reasonably computed using inviscid _incompressible_ flow theory (e.g. as far back as Kutta's 1902 dissertation,) so I don't see why any change in _density_ - much less the vacuum edge case - needs to be invoked. |
Jim Logajan wrote:
Alan Baker wrote: Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. I don't see what a change in air density (such as taking the extreme case of a vacuum) has to do with lift. I'm going to build a thick wing, real thick! About 10,000 feet thick. While the bottom surface of the wing sits at 29.92" sea level atmospheric pressure, the upper surface will be *way* up there, in a lower-pressure area. This airplane is gonna to lift off the ground at zero airspeed with no power. |
Beryl wrote: Jim Logajan wrote: Alan Baker wrote: Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. I don't see what a change in air density (such as taking the extreme case of a vacuum) has to do with lift. I'm going to build a thick wing, real thick! About 10,000 feet thick. While the bottom surface of the wing sits at 29.92" sea level atmospheric pressure, the upper surface will be *way* up there, in a lower-pressure area. This airplane is gonna to lift off the ground at zero airspeed with no power. Only if you make it from monatomic Unobtanium. Only thing light enough for the job. |
Jim Logajan wrote: Alan Baker wrote: Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. I don't see what a change in air density (such as taking the extreme case of a vacuum) has to do with lift. Unless you are claiming density change as a requirement? I believe lift can be reasonably computed using inviscid _incompressible_ flow theory (e.g. as far back as Kutta's 1902 dissertation,) so I don't see why any change in _density_ - much less the vacuum edge case - needs to be invoked. Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. I never mentioned density. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
In article , Jim Logajan wrote: Alan Baker wrote: Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. I don't see what a change in air density (such as taking the extreme case of a vacuum) has to do with lift. Unless you are claiming density change as a requirement? I believe lift can be reasonably computed using inviscid _incompressible_ flow theory (e.g. as far back as Kutta's 1902 dissertation,) so I don't see why any change in _density_ - much less the vacuum edge case - needs to be invoked. Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. I never mentioned density. Sorry, but you used the word "vacuum." The notable characteristic of a vacuum is that its density is zero. |
Jim Logajan wrote: Alan Baker wrote: In article , Jim Logajan wrote: Alan Baker wrote: Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. I don't see what a change in air density (such as taking the extreme case of a vacuum) has to do with lift. Unless you are claiming density change as a requirement? I believe lift can be reasonably computed using inviscid _incompressible_ flow theory (e.g. as far back as Kutta's 1902 dissertation,) so I don't see why any change in _density_ - much less the vacuum edge case - needs to be invoked. Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. I never mentioned density. Sorry, but you used the word "vacuum." The notable characteristic of a vacuum is that its density is zero. That is *a* notable characteristic. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
In article , Jim Logajan wrote: Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. Hmmm...looks like Jim expected too much from you: the kinetic theory of gases has it that pressure may be computed from the temperature AND the density of gases... that is to say, by retaining the SAME molar quantity of gas, and raising its temperature (which translates to a higher velocity), the pressure is increased P.V = R.t and all that.... Put it another way: each "hotter" molecule reverses direction at a surface with greater force. Brian W |
Pressure Distribution Charts | sisu1a | Soaring | 0 | September 21st 08 05:53 PM |
Soundwaves Boost Wing Lift | [email protected] | Home Built | 30 | September 5th 05 10:21 PM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 09:07 PM |
Alternator load distribution in a Baron | Viperdoc | Owning | 7 | December 9th 03 10:27 PM |
