visualisation of the lift distribution over a wing
Old December 3rd 09, 01:14 AM posted to rec.aviation.homebuilt
Alan Baker
Default visualisation of the lift distribution over a wing
brian whatcott wrote:
Alan Baker wrote:
Jim Logajan wrote:
Any change in pressure is *by definition* a change in the number of
particles in the fluid that are impacting the surface.
That assertion is incorrect. You are no dummy so I'm sure you'll correct
it
when you realize the errors.
Sorry, but it's not. Pressure is created by particle collisions.
Hmmm...looks like Jim expected too much from you: the kinetic theory of
gases has it that pressure may be computed from the temperature AND the
density of gases... that is to say, by retaining the SAME molar quantity
of gas, and raising its temperature (which translates to a higher
velocity), the pressure is increased P.V = R.t and all that....
Put it another way: each "hotter" molecule reverses direction at a
surface with greater force.
Brian W
I'm perfectly aware of that, but that hardly matters for the scope of
our discussion of the effect of pressure on a wing. The point I'm making
is that all else being equal, more collisions means higher pressure and
fewer means lower pressure, but that pressure is therefore always a
positive value that acts toward the surface to which it is applied.
It is *never* acting away from that surface; i.e. "pulling".
That is the only reason I mentioned a vacuum, because it is a situation
in which there is *by definition* zero absolute pressure.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old December 4th 09, 10:13 PM posted to rec.aviation.homebuilt
Jim Logajan
correct it when you realize the errors.
Brian Whatcott already addressed one of the errors I had in mind. The other
I had in mind was your incorrect assertion "*by definition*". You should
have asserted "*by derivation*". College level texts on statistical and
thermal physics *derive* the gas laws from statistical mechanics; they do
not present them as true "by definition." (Though that would make for short
textbooks!)
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
