Alan Baker wrote:
In article , Jim Logajan wrote: Alan Baker wrote: Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. I don't see what a change in air density (such as taking the extreme case of a vacuum) has to do with lift. Unless you are claiming density change as a requirement? I believe lift can be reasonably computed using inviscid _incompressible_ flow theory (e.g. as far back as Kutta's 1902 dissertation,) so I don't see why any change in _density_ - much less the vacuum edge case - needs to be invoked. Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. I never mentioned density. Sorry, but you used the word "vacuum." The notable characteristic of a vacuum is that its density is zero. |
Jim Logajan wrote: Alan Baker wrote: In article , Jim Logajan wrote: Alan Baker wrote: Because the push is caused by the impact of countless air molecules with the surface of wing. If those collisions fall to zero (i.e. in a perfect vacuum) then there is zero push. I don't see what a change in air density (such as taking the extreme case of a vacuum) has to do with lift. Unless you are claiming density change as a requirement? I believe lift can be reasonably computed using inviscid _incompressible_ flow theory (e.g. as far back as Kutta's 1902 dissertation,) so I don't see why any change in _density_ - much less the vacuum edge case - needs to be invoked. Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. I never mentioned density. Sorry, but you used the word "vacuum." The notable characteristic of a vacuum is that its density is zero. That is *a* notable characteristic. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
In article , Jim Logajan wrote: Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. Hmmm...looks like Jim expected too much from you: the kinetic theory of gases has it that pressure may be computed from the temperature AND the density of gases... that is to say, by retaining the SAME molar quantity of gas, and raising its temperature (which translates to a higher velocity), the pressure is increased P.V = R.t and all that.... Put it another way: each "hotter" molecule reverses direction at a surface with greater force. Brian W |
brian whatcott wrote: Alan Baker wrote: In article , Jim Logajan wrote: Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. Hmmm...looks like Jim expected too much from you: the kinetic theory of gases has it that pressure may be computed from the temperature AND the density of gases... that is to say, by retaining the SAME molar quantity of gas, and raising its temperature (which translates to a higher velocity), the pressure is increased P.V = R.t and all that.... Put it another way: each "hotter" molecule reverses direction at a surface with greater force. Brian W I'm perfectly aware of that, but that hardly matters for the scope of our discussion of the effect of pressure on a wing. The point I'm making is that all else being equal, more collisions means higher pressure and fewer means lower pressure, but that pressure is therefore always a positive value that acts toward the surface to which it is applied. It is *never* acting away from that surface; i.e. "pulling". That is the only reason I mentioned a vacuum, because it is a situation in which there is *by definition* zero absolute pressure. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
/snip/ Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. Hmmm...looks like Jim expected too much from you: the kinetic theory of gases has it that pressure may be computed from the temperature AND the density of gases... that is to say, by retaining the SAME molar quantity of gas, and raising its temperature (which translates to a higher velocity), the pressure is increased P.V = R.t and all that.... Put it another way: each "hotter" molecule reverses direction at a surface with greater force. Brian W I'm perfectly aware of that... It took me too long to realise the problem: you have a problem with saying: "Oh yes, I got it worng." People who WON'T do that in technical discussions qualify as people who are just happy to stir up heated debate. I am going to leave this thread now: wrasslin' with pigs gets the hands jest too soiled... Brian W |
brian whatcott wrote: Alan Baker wrote: /snip/ Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. Hmmm...looks like Jim expected too much from you: the kinetic theory of gases has it that pressure may be computed from the temperature AND the density of gases... that is to say, by retaining the SAME molar quantity of gas, and raising its temperature (which translates to a higher velocity), the pressure is increased P.V = R.t and all that.... Put it another way: each "hotter" molecule reverses direction at a surface with greater force. Brian W I'm perfectly aware of that... It took me too long to realise the problem: you have a problem with saying: "Oh yes, I got it worng." I didn't get anything wrong. I am and was perfectly aware of the fact that the temperature of a gas indicates a different average speed for the gas molecules and thus a different momentum when the strike a surface. People who WON'T do that in technical discussions qualify as people who are just happy to stir up heated debate. I agree. What of it. I am going to leave this thread now: wrasslin' with pigs gets the hands jest too soiled... You can go. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
In article , brian whatcott wrote: Alan Baker wrote: /snip/ Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. Hmmm...looks like Jim expected too much from you: the kinetic theory of gases has it that pressure may be computed from the temperature AND the density of gases... that is to say, by retaining the SAME molar quantity of gas, and raising its temperature (which translates to a higher velocity), the pressure is increased P.V = R.t and all that.... Put it another way: each "hotter" molecule reverses direction at a surface with greater force. Brian W I'm perfectly aware of that... It took me too long to realise the problem: you have a problem with saying: "Oh yes, I got it worng." I didn't get anything wrong. I am and was perfectly aware of the fact that the temperature of a gas indicates a different average speed for the gas molecules and thus a different momentum when the strike a surface. People who WON'T do that in technical discussions qualify as people who are just happy to stir up heated debate. I agree. What of it. I am going to leave this thread now: wrasslin' with pigs gets the hands jest too soiled... You can go. I feel the same as Brian. This had not been a discussion as much as a troll. OF BLOODY COURSE, the high pressure area under the wing pushes up. So what. It couldn't possibly do that without the reduction of pressure on the top. That's where all the magic is. And you, sir, are a bloody bore. So now, please also dismiss me. |
Alan Baker wrote:
Jim Logajan wrote: Alan Baker wrote: Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. Brian Whatcott already addressed one of the errors I had in mind. The other I had in mind was your incorrect assertion "*by definition*". You should have asserted "*by derivation*". College level texts on statistical and thermal physics *derive* the gas laws from statistical mechanics; they do not present them as true "by definition." (Though that would make for short textbooks!) |
Pressure Distribution Charts | sisu1a | Soaring | 0 | September 21st 08 05:53 PM |
Soundwaves Boost Wing Lift | [email protected] | Home Built | 30 | September 5th 05 10:21 PM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 09:07 PM |
Alternator load distribution in a Baron | Viperdoc | Owning | 7 | December 9th 03 10:27 PM |
