cavelamb wrote: Alan Baker wrote: In article , brian whatcott wrote: Alan Baker wrote: /snip/ Any change in pressure is *by definition* a change in the number of particles in the fluid that are impacting the surface. That assertion is incorrect. You are no dummy so I'm sure you'll correct it when you realize the errors. Sorry, but it's not. Pressure is created by particle collisions. Hmmm...looks like Jim expected too much from you: the kinetic theory of gases has it that pressure may be computed from the temperature AND the density of gases... that is to say, by retaining the SAME molar quantity of gas, and raising its temperature (which translates to a higher velocity), the pressure is increased P.V = R.t and all that.... Put it another way: each "hotter" molecule reverses direction at a surface with greater force. Brian W I'm perfectly aware of that... It took me too long to realise the problem: you have a problem with saying: "Oh yes, I got it worng." I didn't get anything wrong. I am and was perfectly aware of the fact that the temperature of a gas indicates a different average speed for the gas molecules and thus a different momentum when the strike a surface. People who WON'T do that in technical discussions qualify as people who are just happy to stir up heated debate. I agree. What of it. I am going to leave this thread now: wrasslin' with pigs gets the hands jest too soiled... You can go. I feel the same as Brian. This had not been a discussion as much as a troll. OF BLOODY COURSE, the high pressure area under the wing pushes up. So what. It couldn't possibly do that without the reduction of pressure on the top. That's where all the magic is. And you, sir, are a bloody bore. So now, please also dismiss me. Look, I started out to clarify the point for those who have the wrong perception of the situation... ....and it turned that there were such people. I explicitly stated that if the OP meant that the low pressure above the wing is responsible for two thirds of the pressure *difference* then he was on solid ground (while allowing as how I didn't know what the precise figures actually were). Ever since then, types like you have been coming in and saying "IT DOESN'T MATTER", when very clearly (because there are people who don't understand the situation) it does. It's like the downwash argument. You can say "IT DOESN'T MATTER", when people argue that the air behind an aircraft is not deflected downward, but it *does* matter. Having an accurate understanding of the physical processes of flight matters. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
It's like the downwash argument. You can say "IT DOESN'T MATTER", when people argue that the air behind an aircraft is not deflected downward, but it *does* matter. Having an accurate understanding of the physical processes of flight matters. It isn't really deflected downward, not for long anyway. It's churning in a torus. Like a smoke ring. |
Beryl wrote: Alan Baker wrote: It's like the downwash argument. You can say "IT DOESN'T MATTER", when people argue that the air behind an aircraft is not deflected downward, but it *does* matter. Having an accurate understanding of the physical processes of flight matters. It isn't really deflected downward, not for long anyway. It's churning in a torus. Like a smoke ring. No. It really *is* deflected downward. The edges of the deflected area churn, and the air that is deflected ends up getting diffused among all the other air below *it*, but it really is deflected downward. And eventually, that downward deflection makes it way until it -- very diffusely -- impacts upon the surface of the earth. That is the only thing that finally stops it. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker schreef:
No. Yawn. |
Alan Baker wrote:
In article , Beryl wrote: Alan Baker wrote: It's like the downwash argument. You can say "IT DOESN'T MATTER", when people argue that the air behind an aircraft is not deflected downward, but it *does* matter. Having an accurate understanding of the physical processes of flight matters. It isn't really deflected downward, not for long anyway. It's churning in a torus. Like a smoke ring. No. It really *is* deflected downward. The edges of the deflected area churn, and the air that is deflected ends up getting diffused among all the other air below *it*, but it really is deflected downward. And eventually, that downward deflection makes it way until it -- very diffusely -- impacts upon the surface of the earth. That is the only thing that finally stops it. After more than 100 years of flight, the atmosphere still hasn't been pushed down to the earth's surface. |
Ok, so there is a low pressure field above the wing,
and the wing is pressed up from underneath. So, just out of curiosity, what happens to the air that was in the low pressure field above the wing - after the wing passes? Does it just magically co back to it's old ways (and places)? And the air that was in the high pressure field under the wing? After the wing passes, is it unaffected as well? |
cavelamb wrote:
Ok, so there is a low pressure field above the wing, and the wing is pressed up from underneath. So, just out of curiosity, what happens to the air that was in the low pressure field above the wing - after the wing passes? Does it just magically co back to it's old ways (and places)? And the air that was in the high pressure field under the wing? After the wing passes, is it unaffected as well? It's all a slowly descending smoke ring. If the earth was "the only thing that finally stops it" as Alan says, none of the ring's energy would be lost as it pushes through the surrounding air to reach the earth. http://www.av8n.com/how/htm/airfoils.html#sec-circulation-vortices Figure 3.27 ties the wingtip vortices in with the rest of the circulation pattern, showing the whole smoke ring in red. Also look up at section Section 3.11, http://www.av8n.com/how/htm/airfoils.html#sec-spinners Add the Fluttering Card circulation, Figure 3.25, to familiar tip vortices, and you get the whole ring. Other articles do a nice job explaining tip vortices or downwash behind the wing as isolated subjects, but that's where they end their stories. |
Beryl wrote:
cavelamb wrote: Ok, so there is a low pressure field above the wing, and the wing is pressed up from underneath. So, just out of curiosity, what happens to the air that was in the low pressure field above the wing - after the wing passes? Does it just magically co back to it's old ways (and places)? And the air that was in the high pressure field under the wing? After the wing passes, is it unaffected as well? It's all a slowly descending smoke ring. If the earth was "the only thing that finally stops it" as Alan says, none of the ring's energy would be lost as it pushes through the surrounding air to reach the earth. http://www.av8n.com/how/htm/airfoils.html#sec-circulation-vortices Figure 3.27 ties the wingtip vortices in with the rest of the circulation pattern, showing the whole smoke ring in red. Also look up at section Section 3.11, http://www.av8n.com/how/htm/airfoils.html#sec-spinners Add the Fluttering Card circulation, Figure 3.25, to familiar tip vortices, and you get the whole ring. Other articles do a nice job explaining tip vortices or downwash behind the wing as isolated subjects, but that's where they end their stories. I've seen the results first hand. Flying along just above a smooth cloud surface at high subsonic, the "wake" behind the leader makes a shallow trough in the cloud, then the edges swirl back up into the tip vortices. The high pressure air underneath rebounds up, and the low pressure field above the wing rebounds back down. Net result = zero. |
Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: It's like the downwash argument. You can say "IT DOESN'T MATTER", when people argue that the air behind an aircraft is not deflected downward, but it *does* matter. Having an accurate understanding of the physical processes of flight matters. It isn't really deflected downward, not for long anyway. It's churning in a torus. Like a smoke ring. No. It really *is* deflected downward. The edges of the deflected area churn, and the air that is deflected ends up getting diffused among all the other air below *it*, but it really is deflected downward. And eventually, that downward deflection makes it way until it -- very diffusely -- impacts upon the surface of the earth. That is the only thing that finally stops it. After more than 100 years of flight, the atmosphere still hasn't been pushed down to the earth's surface. Sorry, Beryl, but you're just wrong. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
In article , Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: It's like the downwash argument. You can say "IT DOESN'T MATTER", when people argue that the air behind an aircraft is not deflected downward, but it *does* matter. Having an accurate understanding of the physical processes of flight matters. It isn't really deflected downward, not for long anyway. It's churning in a torus. Like a smoke ring. No. It really *is* deflected downward. The edges of the deflected area churn, and the air that is deflected ends up getting diffused among all the other air below *it*, but it really is deflected downward. And eventually, that downward deflection makes it way until it -- very diffusely -- impacts upon the surface of the earth. That is the only thing that finally stops it. After more than 100 years of flight, the atmosphere still hasn't been pushed down to the earth's surface. Sorry, Beryl, but you're just wrong. As I said, the atmosphere isn't getting any shorter. Do you disagree with that? Repeating that "the net flow is downward" isn't making progress. |
Pressure Distribution Charts | sisu1a | Soaring | 0 | September 21st 08 05:53 PM |
Soundwaves Boost Wing Lift | [email protected] | Home Built | 30 | September 5th 05 10:21 PM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 09:07 PM |
Alternator load distribution in a Baron | Viperdoc | Owning | 7 | December 9th 03 10:27 PM |
