Jim Logajan wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: It's like the downwash argument. You can say "IT DOESN'T MATTER", when people argue that the air behind an aircraft is not deflected downward, but it *does* matter. Having an accurate understanding of the physical processes of flight matters. It isn't really deflected downward, not for long anyway. It's churning in a torus. Like a smoke ring. No. It really *is* deflected downward. It's also deflected upward. ;-) Here's why: Because the airplane and the Earth have zero relative vertical velocity during straight and level flight, conservation of momentum requires the net vertical flow of air to also be zero. Therefore in subsonic flows where the fluid is assumed incompressible, to the extent any fluid is moving downward, conservation of mass requires an equal amount of mass must be moving upward (the continuity requirement.) Hence airplanes must cause air to move in circles. Nope. Wrong. The aircraft is experience an force upward the entire time it is in flight. That force means there must be an equal force acting on the air, and since the air was not moving vertically (in our idealized case for this discussion) before the aircraft arrived, the force exerted on it must mean that it is moving downward afterward it has passed. The edges of the deflected area churn, and the air that is deflected ends up getting diffused among all the other air below *it*, but it really is deflected downward. Yes some deflection downward occurs. But I don't know that it could be said to "diffuse" in any sense due to conservation of mass and momentum requirements. As the air the plane has forced downward encounters more air, the momentum is diffused so that a greater and greater mass of air moves downward at smaller and smaller velocities (net)... ....until it encounters the ground. And eventually, that downward deflection makes it way until it -- very diffusely -- impacts upon the surface of the earth. That is the only thing that finally stops it. That assertion is not true in general. What appears to happen instead is that any downward deflection is quickly reversed, leading to what is known as a shed vortex. Here are some links on the subject: http://www.grc.nasa.gov/WWW/K-12/airplane/shed.html Sorry, but the vortex is an edge effect. The net flow is downward. http://www.grc.nasa.gov/WWW/K-12/airplane/downwash.html While the deflected flow doesn't need to reach the surface of the earth for the airplane to stay aloft, an increase in air _pressure_ would eventually make its way to the surface. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
... As the air the plane has forced downward encounters more air, the momentum is diffused so that a greater and greater mass of air moves downward at smaller and smaller velocities (net)... ...until it encounters the ground. Yikes! Eventually, ALL of the air will be on the ground! And eventually, that downward deflection makes it way until it -- very diffusely -- impacts upon the surface of the earth. That is the only thing that finally stops it. That assertion is not true in general. What appears to happen instead is that any downward deflection is quickly reversed, leading to what is known as a shed vortex. Here are some links on the subject: http://www.grc.nasa.gov/WWW/K-12/airplane/shed.html Sorry, but the vortex is an edge effect. The net flow is downward. Mankind needs to set up fans IMMEDIATELY to move air back up into the sky! |
Alan Baker wrote:
Jim Logajan wrote: Because the airplane and the Earth have zero relative vertical velocity during straight and level flight, conservation of momentum requires the net vertical flow of air to also be zero. Therefore in subsonic flows where the fluid is assumed incompressible, to the extent any fluid is moving downward, conservation of mass requires an equal amount of mass must be moving upward (the continuity requirement.) Hence airplanes must cause air to move in circles. Nope. Wrong. The aircraft is experience an force upward the entire time it is in flight. That force means there must be an equal force acting on the air, and since the air was not moving vertically (in our idealized case for this discussion) before the aircraft arrived, the force exerted on it must mean that it is moving downward afterward it has passed. Nothing you wrote in your paragraph contradicts anything in my paragraphs. So I'm at a loss therefore as to what specific statements you claim are wrong. So how about I break it down into smaller claims and you tell me which of these statements you agree with and which you disagree with: 1) Conservation of momentum requires that at all times during flight that net vertical momentum of the total system must be zero. Agree or disagree? 2) We can treat air as incompressible, so conservation of mass means the net vertical mass flow of the system during level flight must be zero. Agree or disagree? 3) Therefore if, say, the downwash is 1 kg/s at any given instant due to the wing, somewhere else in the fluid there must be an upwash at that same instant of 1 kg/s. Agree or disagree? 4) Because upwash mass rate equals downwash mass rate, at some point the downward flow reverses direction and becomes the upwash. Agree or disagree? Yes some deflection downward occurs. But I don't know that it could be said to "diffuse" in any sense due to conservation of mass and momentum requirements. As the air the plane has forced downward encounters more air, the momentum is diffused so that a greater and greater mass of air moves downward at smaller and smaller velocities (net)... ...until it encounters the ground. Keep in mind that balloons need no downwash to stay aloft. Yet we know from conservation laws that the *static* pressure on the surface of the earth must be increase due to their presence. Nothing you've written rules out the possibility that the *dynamic* pressure of the downwash translates into a *static* pressure increase well before the downwash reaches the surface of the earth. The physics of the situation do not seem to rule out that a priori. |
Jim Logajan wrote: Alan Baker wrote: Jim Logajan wrote: Because the airplane and the Earth have zero relative vertical velocity during straight and level flight, conservation of momentum requires the net vertical flow of air to also be zero. Therefore in subsonic flows where the fluid is assumed incompressible, to the extent any fluid is moving downward, conservation of mass requires an equal amount of mass must be moving upward (the continuity requirement.) Hence airplanes must cause air to move in circles. Nope. Wrong. The aircraft is experience an force upward the entire time it is in flight. That force means there must be an equal force acting on the air, and since the air was not moving vertically (in our idealized case for this discussion) before the aircraft arrived, the force exerted on it must mean that it is moving downward afterward it has passed. Nothing you wrote in your paragraph contradicts anything in my paragraphs. So I'm at a loss therefore as to what specific statements you claim are wrong. So how about I break it down into smaller claims and you tell me which of these statements you agree with and which you disagree with: 1) Conservation of momentum requires that at all times during flight that net vertical momentum of the total system must be zero. Agree or disagree? 2) We can treat air as incompressible, so conservation of mass means the net vertical mass flow of the system during level flight must be zero. Agree or disagree? Agree, but that system needs to include the Earth itself, doesn't it? 3) Therefore if, say, the downwash is 1 kg/s at any given instant due to the wing, somewhere else in the fluid there must be an upwash at that same instant of 1 kg/s. Agree or disagree? Agree. At the surface of the Earth. 4) Because upwash mass rate equals downwash mass rate, at some point the downward flow reverses direction and becomes the upwash. Agree or disagree? Agree. At the surface of the Earth. Yes some deflection downward occurs. But I don't know that it could be said to "diffuse" in any sense due to conservation of mass and momentum requirements. As the air the plane has forced downward encounters more air, the momentum is diffused so that a greater and greater mass of air moves downward at smaller and smaller velocities (net)... ...until it encounters the ground. Keep in mind that balloons need no downwash to stay aloft. Yet we know from conservation laws that the *static* pressure on the surface of the earth must be increase due to their presence. Nothing you've written rules out the possibility that the *dynamic* pressure of the downwash translates into a *static* pressure increase well before the downwash reaches the surface of the earth. The physics of the situation do not seem to rule out that a priori. Conservation of momentum does. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
Jim Logajan wrote: 3) Therefore if, say, the downwash is 1 kg/s at any given instant due to the wing, somewhere else in the fluid there must be an upwash at that same instant of 1 kg/s. Agree or disagree? Agree. At the surface of the Earth. The qualifier indicates to me that you don't agree with the statement as written. Unfortunately, I consider conservation of mass at all points in time in an incompressible fluid an essential element to understanding the behavior of downwash. If you don't, then I think any further debate between us is ended. (Just FYI, imagine a ~957 kg (Fg ~= 9379 N) helicopter dropped from a balloon from 3,000 m altitude (rho ~= 0.83 kg/m^3) and it's engine immediately started. After a small drop it levels out and maintains a downwash of air moving through its 6 m diameter disk (A ~= 28 m^2) at, say, 20 m/s. (So m_dot ~= 469 kg/s and hence Fe = Fg.) It would take ~150 s for that downwash to reach the ground if it maintained that speed. In the mean time, once the helicopter stopped descending, conservation of mass in an incompressible fluid seems to require an equal volume of air to have an upward vector of 20 m/s. So the surface of earth appears to be irrelevant for over two minutes.) |
Jim Logajan wrote: Alan Baker wrote: Jim Logajan wrote: 3) Therefore if, say, the downwash is 1 kg/s at any given instant due to the wing, somewhere else in the fluid there must be an upwash at that same instant of 1 kg/s. Agree or disagree? Agree. At the surface of the Earth. The qualifier indicates to me that you don't agree with the statement as written. You're right. I shouldn't have stated it that way. Unfortunately, I consider conservation of mass at all points in time in an incompressible fluid an essential element to understanding the behavior of downwash. If you don't, then I think any further debate between us is ended. Look if you think that conservation of *mass* plays any role in this, you're missing out from the start. It's conservation of *momentum* that's in play here. The aircraft has a force exerted on it equal to its weight. That means that the aircraft must be exerting a force on the air in the opposite direction. That means that there is a constant change of momentum being done on the air by the aircraft. That means air *must* be moving down (net) after the aircraft has passed. (Just FYI, imagine a ~957 kg (Fg ~= 9379 N) helicopter dropped from a balloon from 3,000 m altitude (rho ~= 0.83 kg/m^3) and it's engine immediately started. After a small drop it levels out and maintains a downwash of air moving through its 6 m diameter disk (A ~= 28 m^2) at, say, 20 m/s. (So m_dot ~= 469 kg/s and hence Fe = Fg.) It would take ~150 s for that downwash to reach the ground if it maintained that speed. In the mean time, once the helicopter stopped descending, conservation of mass in an incompressible fluid seems to require an equal volume of air to have an upward vector of 20 m/s. So the surface of earth appears to be irrelevant for over two minutes.) Nope. The conservation of momentum says that there cannot be an equal amount of air moving upward at an equal speed. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
Look if you think that conservation of *mass* plays any role in this, you're missing out from the start. It's conservation of *momentum* that's in play here. It appears you have never studied fluid dynamics (maybe elementary fluid statics?) and I doubt that you own any books on the subject. The aircraft has a force exerted on it equal to its weight. That means that the aircraft must be exerting a force on the air in the opposite direction. In other news, 1 + 1 = 2. That means that there is a constant change of momentum being done on the air by the aircraft. That means air *must* be moving down (net) after the aircraft has passed. You must have a devil of a time figuring out what keeps balloons afloat, what with no handy downward moving air! (Just FYI, imagine a ~957 kg (Fg ~= 9379 N) helicopter dropped from a balloon from 3,000 m altitude (rho ~= 0.83 kg/m^3) and it's engine immediately started. After a small drop it levels out and maintains a downwash of air moving through its 6 m diameter disk (A ~= 28 m^2) at, say, 20 m/s. (So m_dot ~= 469 kg/s and hence Fe = Fg.) It would take ~150 s for that downwash to reach the ground if it maintained that speed. In the mean time, once the helicopter stopped descending, conservation of mass in an incompressible fluid seems to require an equal volume of air to have an upward vector of 20 m/s. So the surface of earth appears to be irrelevant for over two minutes.) Nope. Dang - I try to use real numbers to establish a baseline example, and you manage to use a single word to demolish my attempts! Really helpful mathematical counter-example you produced - not. The conservation of momentum says that there cannot be an equal amount of air moving upward at an equal speed. I don't know what your problem is - maybe you are thinking this is a rocket problem where no external fluids are involved and you can't get your mind around the fact that THIS ISN'T A BLOODY ROCKET PROBLEM. Whatever the case, you seem to be fixated on applying one conservation law to one element in the entire system to the exclusion of everything else. Best of luck to you. |
Jim Logajan wrote:
Alan Baker wrote: Look if you think that conservation of *mass* plays any role in this, you're missing out from the start. It's conservation of *momentum* that's in play here. It appears you have never studied fluid dynamics (maybe elementary fluid statics?) and I doubt that you own any books on the subject. The aircraft has a force exerted on it equal to its weight. That means that the aircraft must be exerting a force on the air in the opposite direction. In other news, 1 + 1 = 2. That means that there is a constant change of momentum being done on the air by the aircraft. That means air *must* be moving down (net) after the aircraft has passed. You must have a devil of a time figuring out what keeps balloons afloat, what with no handy downward moving air! (Just FYI, imagine a ~957 kg (Fg ~= 9379 N) helicopter dropped from a balloon from 3,000 m altitude (rho ~= 0.83 kg/m^3) and it's engine immediately started. After a small drop it levels out and maintains a downwash of air moving through its 6 m diameter disk (A ~= 28 m^2) at, say, 20 m/s. (So m_dot ~= 469 kg/s and hence Fe = Fg.) It would take ~150 s for that downwash to reach the ground if it maintained that speed. In the mean time, once the helicopter stopped descending, conservation of mass in an incompressible fluid seems to require an equal volume of air to have an upward vector of 20 m/s. So the surface of earth appears to be irrelevant for over two minutes.) Nope. Dang - I try to use real numbers to establish a baseline example, and you manage to use a single word to demolish my attempts! Really helpful mathematical counter-example you produced - not. The conservation of momentum says that there cannot be an equal amount of air moving upward at an equal speed. I don't know what your problem is - maybe you are thinking this is a rocket problem where no external fluids are involved and you can't get your mind around the fact that THIS ISN'T A BLOODY ROCKET PROBLEM. Whatever the case, you seem to be fixated on applying one conservation law to one element in the entire system to the exclusion of everything else. Best of luck to you. Two dimensional Newtonian thinking in a three dimensional non-Newtonian world. |
Jim Logajan wrote: Alan Baker wrote: Look if you think that conservation of *mass* plays any role in this, you're missing out from the start. It's conservation of *momentum* that's in play here. It appears you have never studied fluid dynamics (maybe elementary fluid statics?) and I doubt that you own any books on the subject. Sorry, lad, but conservation of mass is a principle that comes up mostly in *chemistry*. The aircraft has a force exerted on it equal to its weight. That means that the aircraft must be exerting a force on the air in the opposite direction. In other news, 1 + 1 = 2. What a pity then that you don't understand it. That means that there is a constant change of momentum being done on the air by the aircraft. That means air *must* be moving down (net) after the aircraft has passed. You must have a devil of a time figuring out what keeps balloons afloat, what with no handy downward moving air! I have no trouble figuring that out at all. A gas of a different density within the balloon causes the net upward force on the balloon exerted by the air outside the balloon to be greater than the net downward force on it. (Just FYI, imagine a ~957 kg (Fg ~= 9379 N) helicopter dropped from a balloon from 3,000 m altitude (rho ~= 0.83 kg/m^3) and it's engine immediately started. After a small drop it levels out and maintains a downwash of air moving through its 6 m diameter disk (A ~= 28 m^2) at, say, 20 m/s. (So m_dot ~= 469 kg/s and hence Fe = Fg.) It would take ~150 s for that downwash to reach the ground if it maintained that speed. In the mean time, once the helicopter stopped descending, conservation of mass in an incompressible fluid seems to require an equal volume of air to have an upward vector of 20 m/s. So the surface of earth appears to be irrelevant for over two minutes.) Nope. Dang - I try to use real numbers to establish a baseline example, and you manage to use a single word to demolish my attempts! Really helpful mathematical counter-example you produced - not. No math is necessary for this. Look up "qualitative analysis". The conservation of momentum says that there cannot be an equal amount of air moving upward at an equal speed. I don't know what your problem is - maybe you are thinking this is a rocket problem where no external fluids are involved and you can't get your mind around the fact that THIS ISN'T A BLOODY ROCKET PROBLEM. Whatever the case, you seem to be fixated on applying one conservation law to one element in the entire system to the exclusion of everything else. The law I'm focussed on is the one that counts. It doesn't matter whether the fluid is expelled from inside or whether it's an external fluid diverted down by the surfaces of the craft. In order for there to be a continuous force W equaling the weight of the craft acting on it, the craft must exert a force -W on the fluid. That -W means that there is a downward change of momentum in the fluid. Since the fluid is no accelerated indefinitely, there must be a continuous flow (mass per unit time M/t) of the fluid accelerated to a velocity V where the equation looks like: -W = M/t * V The velocity of the fluid will be: V = -W/(M/t) That is inescapable. If the craft weighs 9800N (newtons), and it moves 100kg of air every second, then the air must be moving downward (net, now!) at 98 m/s. I'm sorry if you don't get this, but it is very simple and absolutely irrefutable. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Pressure Distribution Charts | sisu1a | Soaring | 0 | September 21st 08 05:53 PM |
Soundwaves Boost Wing Lift | [email protected] | Home Built | 30 | September 5th 05 10:21 PM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 09:07 PM |
Alternator load distribution in a Baron | Viperdoc | Owning | 7 | December 9th 03 10:27 PM |
