visualisation of the lift distribution over a wing
Old December 6th 09, 12:28 AM posted to rec.aviation.homebuilt
Alan Baker
Default visualisation of the lift distribution over a wing
Jim Logajan wrote:
Alan Baker wrote:
If there is no downwash, it will not fly. No.
You are arguing a point not under contention (at least with respect to
heavier-than-air aircraft.)
See everyone: this is why understanding of the actual facts is
required.
You simply haven't really read anyone else's posts to understand what they
are stating.
The previous poster just said:
"Let's talk about helicopters. We can replace that rotor with a squirrel
cage fan. Air is drawn down into the fan as before, and most of the
pressure differential is due to lowering pressure above the fan. As
before... except that now the air is exhausted out the periphery of the
centrifugal-flow squirrel cage fan, not down as it was with the old
axial-flow rotor. Will it fly? Where's the downwash?"
She ("Beryl"?) is clearly implying that such an hypothetical craft could
remain airborne without downwash.
How else can it be read?
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old December 6th 09, 04:16 AM posted to rec.aviation.homebuilt
Beryl[_3_]
required.
The ground isn't required. Air has inertia, and it's just as much a part
of the earth as dirt and rocks are. So why are you fixated on the
earth's solid surface? It compresses too, you know. You could argue that
the downforce travels through the whole planet and back into the
atmosphere in China.
are stating.
She ("Beryl"?)
A mineral
is clearly implying that such an hypothetical craft could remain airborne without downwash.
No, I only asked.
Read it as a question.
Old December 6th 09, 08:03 AM posted to rec.aviation.homebuilt
Alan Baker
required.
are stating.
She ("Beryl"?)
A mineral
without downwash.
No, I only asked.
So what is your answer? Can the postulated craft fly if there is no
downdraft?
I'm betting you'll find a way to avoid answering...
Alan Baker
Old December 6th 09, 09:54 PM posted to rec.aviation.homebuilt
Beryl[_3_]
Alan Baker wrote:
required.
are stating.
She ("Beryl"?)
A mineral
without downwash.
No, I only asked.
downdraft?
The inflow strikes the underside of the conventional rotor disk, but
strikes the topside of the centrifugal fan disk. That's all!
I did.
So where are we? Your downward accelerated air might continue traveling
until it's stopped by the earth's surface, which is the only thing that
can stop it. But it isn't simply thrown down. Much of the finite energy
put into to the air is "wasted" in spinning it. Kinetic energy becomes heat.
Old December 6th 09, 10:45 PM posted to rec.aviation.homebuilt
Alan Baker
Beryl wrote:
Alan Baker wrote:
required.
they
are stating.
She ("Beryl"?)
A mineral
without downwash.
No, I only asked.
downdraft?
I did.
No surprise there.
And now you're just ducking.
Alan Baker
Old December 7th 09, 12:56 AM posted to rec.aviation.homebuilt
Beryl[_3_]
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
required.
they
are stating.
She ("Beryl"?)
A mineral
without downwash.
No, I only asked.
downdraft?
I did.
No surprise there.
Like you do, every time it's pointed out that when air is pushed down,
an equal volume of air must go UP? You then avoid saying "air flow" and
start grasping for other terms.
So how far down do you think air can flow before the ground is out of
reach? Forever?
Old December 7th 09, 01:04 AM posted to rec.aviation.homebuilt
Alan Baker
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
required.
they
are stating.
squirrel
She ("Beryl"?)
A mineral
airborne
without downwash.
No, I only asked.
downdraft?
I did.
No surprise there.
heat.
Eventually it must go up. After it has transferred its momentum to the
earth.
I'm sorry, but that is the reality of the situation.
reach? Forever?
Essentially, yes. The fact is that if the aircraft and the Earth are to
remain the same distance apart, the plane must "push" against the Earth
with a force equal to the force of gravity. The air is the medium by
which the aircraft can transmit that push.
And to explain to you why your hypothetical craft with the radial
exhaust of air from a centrifugal fan won't work. The air that enters
downward gets turned to go sideways. That 90 degree turn can only be
accomplished by the a push upward from the aircraft and thus the air
must push down on the system with an equal but opposite force.
Alan Baker
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
