visualisation of the lift distribution over a wing
Old December 7th 09, 12:56 AM posted to rec.aviation.homebuilt
Beryl[_3_]
Default visualisation of the lift distribution over a wing
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Jim Logajan wrote:
Alan Baker wrote:
If there is no downwash, it will not fly. No.
You are arguing a point not under contention (at least with respect to
heavier-than-air aircraft.)
See everyone: this is why understanding of the actual facts is
required.
The ground isn't required. Air has inertia, and it's just as much a part
of the earth as dirt and rocks are. So why are you fixated on the
earth's solid surface? It compresses too, you know. You could argue that
the downforce travels through the whole planet and back into the
atmosphere in China.
You simply haven't really read anyone else's posts to understand what
they
are stating.
The previous poster just said:
"Let's talk about helicopters. We can replace that rotor with a squirrel
cage fan. Air is drawn down into the fan as before, and most of the
pressure differential is due to lowering pressure above the fan. As
before... except that now the air is exhausted out the periphery of the
centrifugal-flow squirrel cage fan, not down as it was with the old
axial-flow rotor. Will it fly? Where's the downwash?"
She ("Beryl"?)
A mineral
is clearly implying that such an hypothetical craft could remain airborne
without downwash.
No, I only asked.
How else can it be read?
Read it as a question.
So what is your answer? Can the postulated craft fly if there is no
downdraft?
The inflow strikes the underside of the conventional rotor disk, but
strikes the topside of the centrifugal fan disk. That's all!
I'm betting you'll find a way to avoid answering...
I did.
No surprise there.
So where are we? Your downward accelerated air might continue traveling
until it's stopped by the earth's surface, which is the only thing that
can stop it. But it isn't simply thrown down. Much of the finite energy
put into to the air is "wasted" in spinning it. Kinetic energy becomes heat.
And now you're just ducking.
Like you do, every time it's pointed out that when air is pushed down,
an equal volume of air must go UP? You then avoid saying "air flow" and
start grasping for other terms.
So how far down do you think air can flow before the ground is out of
reach? Forever?
Old December 7th 09, 01:04 AM posted to rec.aviation.homebuilt
Alan Baker
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
required.
they
are stating.
squirrel
She ("Beryl"?)
A mineral
airborne
without downwash.
No, I only asked.
downdraft?
I did.
No surprise there.
heat.
Eventually it must go up. After it has transferred its momentum to the
earth.
I'm sorry, but that is the reality of the situation.
reach? Forever?
Essentially, yes. The fact is that if the aircraft and the Earth are to
remain the same distance apart, the plane must "push" against the Earth
with a force equal to the force of gravity. The air is the medium by
which the aircraft can transmit that push.
And to explain to you why your hypothetical craft with the radial
exhaust of air from a centrifugal fan won't work. The air that enters
downward gets turned to go sideways. That 90 degree turn can only be
accomplished by the a push upward from the aircraft and thus the air
must push down on the system with an equal but opposite force.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old December 7th 09, 05:12 AM posted to rec.aviation.homebuilt
Beryl[_3_]
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
required.
they
are stating.
squirrel
She ("Beryl"?)
A mineral
airborne
without downwash.
No, I only asked.
downdraft?
I did.
No surprise there.
heat.
earth.
You've seen pics of it curling right back up.
http://www.efluids.com/efluids/gallery/gallery_pages/Morris_4.jsp
It hasn't bounced off the ground.
Pressure waves can reach the ground, without the air in the column
descending to the ground.
reach? Forever?
Essentially, yes.
How? A wing doesn't keep pushing down on a parcel of air forever. It
gives that air a shove, then it moves on. That downward-shoved air
pushes the air below it out of the way, not just down, but sideways.
Then the sideways-moving air shoves its neighboring air out of the way,
not just sideways, but down and up. Add all the "downs" and subtract all
the "ups" until there's nothing left.
The fact is that if the aircraft and the Earth are to remain the same distance apart, the plane must "push" against the Earth
Right. And I can push against the hill across the road with my voice.
Not much, but enough to move the diaphragm in a microphone over there,
in a split second. The air expelled from lungs is never going to make it
across the road.
But is that 90 degree turn *exactly* the same as a 180 degree turn that
directs incoming air back in the opposite direction? No, so I'll just
turn my squirrel cage upside down with 180 degree flow redirection, and
get lift with no net downwash.
Old December 7th 09, 05:26 AM posted to rec.aviation.homebuilt
Alan Baker
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
to
required.
part
that
what
they
are stating.
squirrel
She ("Beryl"?)
A mineral
airborne
without downwash.
No, I only asked.
downdraft?
I did.
No surprise there.
heat.
earth.
You've seen the edges curling back up. For anything with downward
momentum to start moving upward, something else has to start moving
downward.
Have you heard of "Conservation of Momentum"?
I never said that the particular molecules that the aircraft touches are
the ones that have to reach the ground.
reach? Forever?
Essentially, yes.
Look up "Conservation of Momentum" and get back to me.
across the road.
No, sorry. You don't push the hill with your voice. The pressure waves
contain both positive and negative phases.
No, you won't.
No downwash, no lift. No go learn something.
Alan Baker
Old December 7th 09, 09:09 AM posted to rec.aviation.homebuilt
Beryl[_3_]
Alan Baker wrote:
In article , Beryl
That photo shows ALL of the flow curling back up. The bottom of the
vortex couldn't be any clearer, and there's nothing extending further
down underneath it.
are the ones that have to reach the ground.
You said "The net flow is downward until it hits the ground and the
momentum is transfer to the earth."
The molecules that "reach" the ground are the ones that
were *already there* at ground level.
by which the aircraft can transmit that push.
voice. Not much, but enough to move the diaphragm in a microphone
over there, in a split second. The air expelled from lungs is never
going to make it across the road.
Of course I do.
The pressure waves contain both positive and negative phases.
So you think that a positive won't push because a negative will be
coming along shortly?
enters downward gets turned to go sideways. That 90 degree turn
can only be accomplished by the a push upward from the aircraft
and thus the air must push down on the system with an equal but
opposite force.
that directs incoming air back in the opposite direction? No, so
I'll just turn my squirrel cage upside down with 180 degree flow
redirection, and get lift with no net downwash.
No, you won't.
Let's learn here. From you. Is that 90 degree turn *exactly* the same as
a 180 degree turn that directs incoming air back in the opposite direction?
Old December 7th 09, 05:49 PM posted to rec.aviation.homebuilt
Alan Baker
Beryl wrote:
Alan Baker wrote:
In article , Beryl
down underneath it.
Sorry, but you're wrong.
First of all, the downward motion of the vortex clearly carries right
out the bottom of the frame. Second, I've stated all along that as time
passes the momentum is diffused among more and more air.
And it is: the *net* flow.
I never implied that the same molecules are the ones that eventually
strike the ground.
Of course I do.
I think their will be no net push, yes.
See the difference: sound waves, no net flow: no net push.
opposite force.
No, you won't.
Read this:
"To determine [the angle represented by a greek letter in the original
text], we observe that no downwash is generated when the wing generates
no lift."
http://www.aoe.vt.edu/~cwoolsey/Cour...al/Aerodynamic
Properties.pdf
Read it over and over again until you get it.
Alan Baker
Old December 7th 09, 10:48 PM posted to rec.aviation.homebuilt
Beryl[_3_]
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
In article , Beryl
down underneath it.
Are you impaired? The airplane is approaching the camera. The camera is
looking up at the airplane. The bottom of the frame contains the distant
background. Objects farther than the airplane appear lower in the frame.
If the camera was above the approaching airplane and looking down at
it, distant objects would appear higher in the frame than the airplane.
Second, I've stated all along that as time passes the momentum is diffused among more and more air.
Yes, you don't explain much, but you do stick to whatever you've said.
The "net" flow is circulating air. Circulation circulates. It doesn't go
somewhere and stay there. The "net" displacement is zero.
strike the ground.
So then, the net flow stops when "it" hits the ground.
"It" isn't the molecules that the wing touches.
Would "it" be the molecules at the bottom of the air column? (they're
already on the ground)
Identify "it" and maybe we'll know when the flow stops.
Of course I do.
There will be two pushes. There will be no net displacement.
"No net push" doesn't make much sense here. There are opposing pushes,
but at _different_ times. That's the difference. By your reasoning,
microphones wouldn't work because the diaphragms inside won't move.
opposite force.
No, you won't.
Read this:
no lift."
I'm not disagreeing with that. I'll rephrase it, and say no circulation
is generated. It is not even relevant.
Properties.pdf
Get what? It's about wings and geometry. Find something about air moving
through air.
Old December 8th 09, 12:05 AM posted to rec.aviation.homebuilt
Brian Whatcott
Hmmmm...It's not too out of line to think of air particles
at ambient temps as moving at the speed of sound.
Its those air "molecules" that carry sound waves longitudinally.
Air particles don't stay anywhere, in a manner of speaking...
Brian W
Old December 9th 09, 06:27 AM posted to rec.aviation.homebuilt
Beryl[_3_]
microphone over there, in a split second. The air expelled from
lungs is never going to make it across the road.
Of course I do.
Sound waves, no net flow: more push than I can apply to the hill across
the road.
http://www.tech-faq.com/acoustic-levitation.shtml
http://science.howstuffworks.com/aco...evitation2.htm
http://en.wikipedia.org/wiki/Acoustic_levitation
Old December 8th 09, 09:48 PM posted to rec.aviation.homebuilt
Morgans[_2_]
I've been polite as long as I can stand it.
HEY DUMBASS ! Get out of the textbook, and into the real world.
You completely ignore the real world effects of friction. That is a hint,
to where the momentum eventually goes to.
You push a car on perfectly level ground. It does not roll forever. What
happened to conservation of momentum?
Same thing with your stupid downflow hits the earth argument. Friction
kills that wave off in relatively short order, dumbass. Get real.
Group, I am sorry for my tone, and for biting on this not too smart troll.
I'll be good now.
Jim in NC
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
