Oliver Arend schreef:
If so, what's a useable algorithm to plt intrados and extrados? http://en.wikipedia.org/wiki/NACA_ai...t_NACA_airfoil dy_c/dx you can get by differentiating between two arbitrarily chosen points on the camber line. You'll probably need closer spacing of these points near the leading edge. So weit war ich ja schon...* How do I calculate from the basic parameters the behaviour of the profile, i.e. the Cl curves? What are you looking for? Slope will be very close to 2 pi ;-) **Bis hier bin ich auch noch dabei! The angle of attack of zero lift is -2 f/t (f/t is maximum camber relative to chord). The cm is more difficult to estimate -- it's easiest to just plug the airfoil into XFOIL and do the calculation XFOIL muss es sein was mir fehlte!*** (or do you prefer http://www.iag.uni-stuttgart.de/IAG/...lettheorie.pdf ?). Mm, mal schauen, nur nicht gerade jetzt.**** The rest, like clmax, are viscous effects and can't simply be deducted/estimated from the basic parameters. Schade***** Oliver, besten dank! KA * Nothing new there ** This also was more or less mastered before *** This must be what I was missing **** Will have a look, not right now though ***** Too bad. |
Calculations for Flying | javawizard | Piloting | 11 | October 18th 07 05:22 PM |
NACA Numbers??? | c hinds | Home Built | 3 | October 11th 04 09:40 PM |
NACA Chord Balance point | [email protected] | Rotorcraft | 3 | April 27th 04 06:05 AM |
Reverse NACA duct | Chris W | Home Built | 22 | October 28th 03 10:59 PM |
NACA duct ventrui | Chris W | Home Built | 7 | October 27th 03 04:11 PM |
