Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: It's true that the exhaust stream doesn't directly push on the inner surface of a rocket engine. Yeah, I like that aerospike design, the inside-out nozzle thing. wing encounters some unmoving air, and the wing then throws the air downwards, the velocity of the air has been changed, and the wing will experience an upwards reaction force. At the same time, a downwash- flow is created. The wing, remember, is moving forward. "Downwards" is one component of circulation. Those weren't my words. What do you suppose happens to "downwash" when it goes up? Say, pulling positive G force at the top of a loop? Now you lost the surface of the earth, the only thing that, according to you, finally stops it. The earth still stops it: Gravity: perhaps you've heard of it? Gravity is not the earth. LOL -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
In article , Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: It's true that the exhaust stream doesn't directly push on the inner surface of a rocket engine. Yeah, I like that aerospike design, the inside-out nozzle thing. wing encounters some unmoving air, and the wing then throws the air downwards, the velocity of the air has been changed, and the wing will experience an upwards reaction force. At the same time, a downwash- flow is created. The wing, remember, is moving forward. "Downwards" is one component of circulation. Those weren't my words. What do you suppose happens to "downwash" when it goes up? Say, pulling positive G force at the top of a loop? Now you lost the surface of the earth, the only thing that, according to you, finally stops it. The earth still stops it: Gravity: perhaps you've heard of it? Gravity is not the earth. LOL You're stuck in one dimension. Up, down. A line. |
Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: In article , Beryl wrote: Alan Baker wrote: It's true that the exhaust stream doesn't directly push on the inner surface of a rocket engine. Yeah, I like that aerospike design, the inside-out nozzle thing. wing encounters some unmoving air, and the wing then throws the air downwards, the velocity of the air has been changed, and the wing will experience an upwards reaction force. At the same time, a downwash- flow is created. The wing, remember, is moving forward. "Downwards" is one component of circulation. Those weren't my words. What do you suppose happens to "downwash" when it goes up? Say, pulling positive G force at the top of a loop? Now you lost the surface of the earth, the only thing that, according to you, finally stops it. The earth still stops it: Gravity: perhaps you've heard of it? Gravity is not the earth. LOL You're stuck in one dimension. Up, down. A line. LOL You're stuck in fantasy land if you believe that an unbalanced force can do anything but cause the air around the plane to move down. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Pressure Distribution Charts | sisu1a | Soaring | 0 | September 21st 08 05:53 PM |
Soundwaves Boost Wing Lift | [email protected] | Home Built | 30 | September 5th 05 10:21 PM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 09:07 PM |
Alternator load distribution in a Baron | Viperdoc | Owning | 7 | December 9th 03 10:27 PM |
