visualisation of the lift distribution over a wing
Old December 8th 09, 08:42 PM posted to rec.aviation.homebuilt
Beryl[_3_]
Default visualisation of the lift distribution over a wing
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
Beryl wrote:
Alan Baker wrote:
It's true that the exhaust stream doesn't directly push on the inner
surface of a rocket engine.
Yeah, I like that aerospike design, the inside-out nozzle thing.
wing encounters some unmoving air, and the wing then throws the air
downwards, the velocity of the air has been changed, and the wing
will experience an upwards reaction force. At the same time, a
downwash- flow is created.
The wing, remember, is moving forward. "Downwards" is one component of
circulation.
Those weren't my words.
What do you suppose happens to "downwash" when it goes up? Say, pulling
positive G force at the top of a loop? Now you lost the surface of the
earth, the only thing that, according to you, finally stops it.
The earth still stops it:
Gravity: perhaps you've heard of it?
Gravity is not the earth.
LOL
You're stuck in one dimension. Up, down. A line.
Old December 8th 09, 08:59 PM posted to rec.aviation.homebuilt
Alan Baker
circulation.
LOL
LOL
You're stuck in fantasy land if you believe that an unbalanced force can
do anything but cause the air around the plane to move down.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
