On Dec 9, 8:58*pm, Darryl Ramm wrote:
On Dec 9, 7:22*pm, Eric Greenwell wrote: guy wrote: Oh...Karen. *Why fret. Just return the plane to the factory and they will add those drain holes they forgot to place as a free warranty repair. Great customer service! Guy "No drain holes" may be the standard. My ASH 26 E does not have drain holes in the spoiler boxes, and does not need them as long as the spoilers are closed when it rains on the ground. If rain gets into the boxes when flying, I've never heard of it happening; personally, I've never looked in the boxes after flying through rain, but none ever poured out when I derigged, either. If they are open when it rains, the boxes will fill with water. The boxes are sealed, so it doesn't run into the wing. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly The boxes are sealed but the lower floor of the box usually is or touches the bottom wing skin so if you really wanted to you could drill a hole right there through the lower skin. Your A&P may have a different idea. But why? I suspect the largest issue with spoiler freezing is by rain wicking around the spoiler door and freezing or by direct icing action. Having enough water inside the spoiler box and having that freeze seems a remote case. And you need to have enough for that to freeze and lock onto something important to stop the blades extending. I suspect that would take quite a lot of water. Although my ASH-26E usually lives in a trailer sometimes it is left out overnight and in the the morning even after light rain I normally see no water in the spoiler boxes. After washing with a hose I'll see a bit of water inside the spoiler box. Same on a club DG-1000S. Just to be nice I usually mop any water out with a dry rag more because I don't want moisture in there encouraging rust etc. not from concern about freezing. If the glider is permanently kept outside then a set of good wing covers are probably an answer to lots of questions. Darryl- Hide quoted text - - Show quoted text - Boy, I thought you guys were glider pilots! There is no "drain" because that would be a path for high pressure air from the bottom of the wing to escape to low pressure air on top, creating drag. Tom |
On Dec 9, 10:11*pm, 2G wrote:
On Dec 9, 8:58*pm, Darryl Ramm wrote: On Dec 9, 7:22*pm, Eric Greenwell wrote: guy wrote: Oh...Karen. *Why fret. Just return the plane to the factory and they will add those drain holes they forgot to place as a free warranty repair. Great customer service! Guy "No drain holes" may be the standard. My ASH 26 E does not have drain holes in the spoiler boxes, and does not need them as long as the spoilers are closed when it rains on the ground. If rain gets into the boxes when flying, I've never heard of it happening; personally, I've never looked in the boxes after flying through rain, but none ever poured out when I derigged, either. If they are open when it rains, the boxes will fill with water. The boxes are sealed, so it doesn't run into the wing. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly The boxes are sealed but the lower floor of the box usually is or touches the bottom wing skin so if you really wanted to you could drill a hole right there through the lower skin. Your A&P may have a different idea. But why? I suspect the largest issue with spoiler freezing is by rain wicking around the spoiler door and freezing or by direct icing action. Having enough water inside the spoiler box and having that freeze seems a remote case. And you need to have enough for that to freeze and lock onto something important to stop the blades extending. I suspect that would take quite a lot of water. Although my ASH-26E usually lives in a trailer sometimes it is left out overnight and in the the morning even after light rain I normally see no water in the spoiler boxes. After washing with a hose I'll see a bit of water inside the spoiler box. Same on a club DG-1000S. Just to be nice I usually mop any water out with a dry rag more because I don't want moisture in there encouraging rust etc. not from concern about freezing. If the glider is permanently kept outside then a set of good wing covers are probably an answer to lots of questions. Darryl- Hide quoted text - - Show quoted text - Boy, I thought you guys were glider pilots! There is no "drain" because that would be a path for high pressure air from the bottom of the wing to escape to low pressure air on top, creating drag. Tom I don't think the wing interior to spoiler box connection (where the control rods enter the spoiler box) is all that airtight on most gliders and will see ambient internal wing/fueslage pressure, some of which will leak out around the spoiler box top, but modern spring loaded tops seal pretty well. So I am not sure that a small hole in the bottom would increase that leak rate significantly. But hey, if done really well you've got yourself a blown turbolator :-) There are gliders around with holes drilled in the bottoms of the spoiler box, for attaching wing tie down hardware. Normally I'd tape those but you'd never measure the difference if not. Darryl |
On Dec 9, 10:37*pm, Darryl Ramm wrote:
I don't think the wing interior to spoiler box connection (where the control rods enter the spoiler box) is all that airtight on most gliders and will see ambient internal wing/fueslage pressure... In my experience, the better racing gliders generally have pretty well- sealed airbrake boxes. I think that it's a common practice to use a rubber bellows to seal the push-pull tube entry. I don't use a bellows, but my airbrake boxes are also sealed off from the wing interior. Thanks, Bob K. |
2G wrote:
Boy, I thought you guys were glider pilots! There is no "drain" because that would be a path for high pressure air from the bottom of the wing to escape to low pressure air on top, creating drag. Tom Good one Tom. Draggy or CofG in limits. Which would you prefer? Brian W |
brian whatcott wrote:
2G wrote: Boy, I thought you guys were glider pilots! There is no "drain" because that would be a path for high pressure air from the bottom of the wing to escape to low pressure air on top, creating drag. Tom Good one Tom. Draggy or CofG in limits. Which would you prefer? Brian W It would take far more water than a spoiler box can hold to cause handling problems - Tom's context. Perhaps you are talking about something on the tail boom? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly |
using less spoiler just before the flare??? | Gary Emerson | Soaring | 16 | October 29th 07 01:08 PM |
Landing with one spoiler | [email protected] | Soaring | 82 | October 7th 05 12:58 AM |
DG500 AD notes | Sailplane Mechanic | Soaring | 2 | August 27th 04 05:35 PM |
Spoiler placement and design. | B2431 | Home Built | 9 | November 11th 03 04:02 PM |
FS2002 freezes up only with Hardeware Acceleration Engaged! | Peter | Simulators | 2 | November 7th 03 08:30 PM |
