In article , betwys1
@sbcglobal.net says... Ross wrote: brian whatcott wrote: Ross wrote: ... there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? A SouthCoast 22. That's a swing keel. I keep it at the house. But it wants three people for anxiety-free mast raising, and that's a problem. Surely not! My trailer-sailer is 25' - I can raise and lower the mast myself (level ground helps!). Surely only one person is needed to hold the mast up, while the forestay is secured (I use the main on the jib halyard to tension the mast and allow the forestay to be secured). -- Duncan. |
On Dec 10, 2:41*pm, Dave Doe wrote:
In article , betwys1 @sbcglobal.net says... Ross wrote: brian whatcott wrote: Ross wrote: ... *there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? A SouthCoast 22. That's a swing keel. I keep it at the house. But it wants three people for anxiety-free mast raising, and that's a problem. Surely not! *My trailer-sailer is 25' - I can raise and lower the mast myself (level ground helps!). *Surely only one person is needed to hold the mast up, while the forestay is secured (I use the main on the jib halyard to tension the mast and allow the forestay to be secured). -- Duncan. The jib halyard would work at least as well as what I do. Just thinking, if one attached a pulley to the anchor cleat the hoisting line could be brought back to one of the main's winches. . .hmm, getting the mast up could be a one man task! |
Looking for Partner / Aircraft Fractional Ownership / NJ | [email protected] | Aviation Marketplace | 0 | August 17th 08 09:34 PM |
Aircraft Ownership Spreadsheet | KevinBlack | Owning | 11 | November 19th 06 06:17 PM |
Aircraft ownership in Ohio | [email protected] | Owning | 15 | September 8th 06 02:26 PM |
The Joys of Aircraft Ownership 1,532 & 1,533 | Brock Boss | Owning | 15 | July 15th 06 05:05 AM |
2 years of aircraft ownership | NW_PILOT | Owning | 2 | March 28th 06 06:26 PM |
