Wing Ballast Distribution
Old December 12th 09, 07:23 AM posted to rec.aviation.soaring
Morgans[_2_]
Default Wing Ballast Distribution
"tstock" wrote
Could you explain this statement for us newbies... this is opposite of
what I would have expected so I would like to understand why it is so.
Go back to the ice skater analogy. Weight out at tips (like arms
outstretched while spinning) provides for a slower spin, and make it a
little easier to stop a spin.
Jim in NC
Old December 11th 09, 02:25 AM posted to rec.aviation.soaring
Brian Whatcott
Dave Nadler wrote:
On Dec 10, 1:02 pm, SoaringXCellence wrote:
The weight toward the tips provides an interial resistance to roll.
That means the ride is a little smoother as the wing has greater
resistance to differential vertical gusting across the wingspan. It
is the same principle that tightrope walkers use by carrying a long
heavy pole.
Also helps stabilize the glider in a spin.
Hmmm... I don't think so. Twin jets are noted for more severe spin
characteristics.
Brian W
Old December 11th 09, 02:44 AM posted to rec.aviation.soaring
Andreas Maurer
On Thu, 10 Dec 2009 10:02:55 -0800 (PST), SoaringXCellence
heavy pole.
I beg to differ - at least for certain gliders it's vice-versa.
In the AS 22-2 (the mother of all ASH-25s) it is strictly required to
fill the outer wing tanks first (and empty them last) - the limiting
factor is the bending momentum of the wing of course.
The interesting part:
Even with completely filled outer wing bags (about 120 lbs per wing)
the roll rate doesn't suffer at all.
But filling the inner wing tanks (about 100 lbs per wing) instead of
having a co-pilot on board reduces the roll rate significantly.
Don't ask me why.
Old December 11th 09, 02:00 PM posted to rec.aviation.soaring
jcarlyle
Wow - thanks to all who answered, especially Craig and Andy. I
understand now why weighted wing tips are good.
I’m puzzled about Andreas’ comments on the ASW-22, though:
This behavior seems to defy physics!
-John
Old December 11th 09, 03:02 PM posted to rec.aviation.soaring
Andreas Maurer
On Fri, 11 Dec 2009 06:00:23 -0800 (PST), jcarlyle
You got it.
I have the feeling that the cause might be some minor dihedral change
due to the water ballast, but I can't nail it down.
Bye
Andreas
Old December 11th 09, 06:09 PM posted to rec.aviation.soaring
Brian Whatcott
Don't ask me why.
Adverse aeroelastic wing twist due to aileron action anti-servoing the
wing??
Brian W
visualisation of the lift distribution over a wing Stealth Pilot[_2_] Home Built 195 December 16th 09 03:17 AM
Wanted: Schempp Hirth Wing Ballast Cap Paul Cordell Soaring 7 August 17th 07 08:30 PM
Fin/wing water ballast ratio? DG-300 [email protected] Soaring 0 May 2nd 06 06:52 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
