Fin/wing water ballast ratio? DG-300
Old May 2nd 06, 06:52 PM posted to rec.aviation.soaring
Default Fin/wing water ballast ratio? DG-300
Is there a quick and easy rule for the ratio of fin to wing tank
ballast. The DG-300 manual shows that it is roughly 1qt. fin per 6gal.
of wing tank.. I assume this will vary between models.
Water Ballast Upgrade P.Corbett Soaring 5 December 5th 05 02:32 PM
Schempp-Hirth water Ballast Cap vent Mod Paul M. Cordell Soaring 11 May 25th 05 10:33 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
astir cs-77 water ballast pete83 Soaring 4 May 27th 04 05:21 AM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
