On Dec 14, 8:56*am, wrote:
On Dec 13, 9:19*am, JJ Sinclair wrote: Another useful approach is start at about 66% aft using manufacturer's CG range. When making the tightest turn you normally do, if you run out of elevator, you need to shift CG back a bit. You will probably end up around 75%.There isn't a huge benefit in having the CG way back, but there is a significant deterioration of handling which requires better pilot skills to offset.The last little bit of glider performance costs quite a bit in pilot workload until you are very proficient. I usually take a couple pounds out of the tail in the Spring and put it back in when my skills are back up to snuff. FWIW UH- Hide quoted text - Also FWIW and purely as a first approximation, I've noted that the following works reasonably well in most glass birds I've flown. - At altitude, trim the glider so that it flys at "about" best L/D airspeed. This is usually somewhere between 50-55kts. - If that trim position results in significant up-elevator, you need more weight in the tail. "Significant" in this context means that you have more than a small percentage of the available up-elevator travel dialed in to maintain best L/D airspeed. Obviously, this is only a secondary check after you've already run the numbers or done a proper W&B, but it seems to work pretty well. In my LS8, the above works out to about 80% of manufacturer's aft limit and results in very pleasant handling and obvious improvement in get- home performance on weak days. Anything wrong with this approach? P3 |
Need a little more range for your 304S jet? | Marc Ramsey[_2_] | Soaring | 1 | July 22nd 07 01:39 PM |
VOR volume range | kevmor | Instrument Flight Rules | 7 | February 7th 07 10:46 PM |
Long range Wx | Paul kgyy | Piloting | 4 | December 31st 04 04:25 PM |
What is the range of the B-1B? | user | Military Aviation | 10 | December 24th 03 04:15 AM |
Fuel Range | Toks Desalu | Home Built | 2 | November 14th 03 12:51 PM |
