Optimum CG Range
Old December 15th 09, 01:16 AM posted to rec.aviation.soaring
Brian Whatcott
Default Optimum CG Range
Herb wrote:
...find the cg that gives you good handling and
enough up elevator to stall the plane in a steep turn. It'll be at
75%-90% aft.
Herb, J7
Reminds me of the old rule of thumb, if you could call it that:
CG too far forward, can't pull the nose up for takeoff.
CG too far aft, can't recover from a stall/spin.
This method can be expensive in airplanes though... :-)
Brian W
Need a little more range for your 304S jet? Marc Ramsey[_2_] Soaring 1 July 22nd 07 01:39 PM
VOR volume range kevmor Instrument Flight Rules 7 February 7th 07 10:46 PM
Long range Wx Paul kgyy Piloting 4 December 31st 04 04:25 PM
What is the range of the B-1B? user Military Aviation 10 December 24th 03 04:15 AM
Fuel Range Toks Desalu Home Built 2 November 14th 03 12:51 PM
